Question about Kitchen Appliances - Others
Been trying to purchase 2 Double Rectangle wood lamps, #19364 with Lamps Plus.com. They cannot supply them. Can you find a source where I can purchase these 2 floor lamps. Amazon.com had 1. I need a set of 2. The item number seems consistent with the lighting stores on google.
I added two of them to my cart on Amazon and it continues to the check out. Click on the link below to start your order
http://www.amazon.com/Double-Rectangle-Wood-Floor-Lamp/dp/B001H2DNLI#lbhuc_175281
Posted on Sep 16, 2010
How wood u wire power going 2, 3way switch, 2pin double tube instant start ballast lite cieling lamps 2 of them going 2 end run 3way switch?
I recommend that you add more details to your question so it will be easier for Experts to understand the question and answer it.
Jun 04, 2012 | Furniture
1996 Ford Explorer Headlights flicker and clicking noise.
Where was the clicking noise heard ? in the instrument panel , behind the dash ? Center ,left , right side etc.... possible dimmer module problem . Looking at wiring diagrams . Does the vehicle have auto lamps , daytime running lamps etc.... Do you know what wiring diagrams are ? Free one's here http://www.bbbind.com/free_tsb.html enter vehicle info. year , make , model , engine size . Under system click on lighting ,then under subsystem click on instrument panel lamps and or head lamps . Check the circuits , find the source of the clicking an you most likely found the problem .
Dec 27, 2017 | 1996 Ford Explorer
Ventilateur de lampli technics sa-ex300 ne marche plus
Vous pouvez acheter de nouvelles lampes num?ro d'article www.rswww.com 655-9693 (T3.8, axial lampe, 10/15V, 55mA)
You can purchase new lamps from www.rswww.com item number 655-9693 (T3.8, axial lamp, 10/15V, 55mA)
Aug 02, 2011 | Technics SA-EX300 Receiver
I have just purchased 3 new Philips MR16 10w LED lamps to try in existing 12v 50w fittings - each with its own electronic dimmable 6o v/a elec t/x. As soon as the lights are switched on with the new lamps...
The LED light bulbs operate at 3 to 5 V usually. The noise your hearing is a result of the voltage reduction within the internal workings of the lamp base. The lamps should be installed with an
LED driver vs a transformer power supply.
This is usually on most packaging:
LED MR16 lamps operate in the same fittings as regular 12V lamps. However, they work best when they are mated with an led driver in place of the transformer.
Example of an LED driver:
http://www.google.com/products/catalog?hl=en&safe=off&rls=com.microsoft:en-ph&q=LED+Driver&um=1&ie=UTF-8&tbm=shop&cid=16162019396751156854&sa=X&ei=HzQpTqOWOK_NmAX0-LWqDA&ved=0CEcQ8wIwAg#
The noise will not go away unless you use an LED driver with the MR16 lamps.
Thanks for choosing FixYa.
Kelly
Jul 22, 2011 | Hardware & Accessories
Naka 700ZXL- Intermittent Problem: After turning on the deck and at the same time the reel motor turns to eliminate tape slack one or more of the 15 lamps on the RAMM indicator panel turn on. If you...
from what is described of the lamps and the RAMM indicator the the negative 4.5 volt supply and the sometimes double spiked signal sound as though you have a weak regulator component or a voltage control circuit with a bad or weak component that needs replacement.
1. check electrolytic caps
2. all diodes/ resistance > all dropped/ no voltage in the voltage controlled circuit
3. trace voltage and current back to source to see if the supply is correct.\
If this is intermittent it means that a component or several components are growing weak and need replacement
4. a schematic for the unit is very helpful in isolating circuit component failure.
Jul 03, 2011 | Nakamichi Audio Players & Recorders
I have a 4 ft 2 lamp flourescent system. I am changing the ballast. The existing wiring has blue / red / yellow / black & white wires. I have a new ballast (yes I confirmed at the store it is the...
The first thiing I suggest is checking the installation instructions (either included with the ballast or on-line) of the ballast you just purchased. Many fluorescent ballasts require that the lamps be wired in series - which I believe is what you had before. One lamp connects between the red & the yellow, the other connects between the yellow & the blue. Other fluorescent ballasts require that the lamps be wired in parallel - which may be what you have now (both lamps connect between the red & the blue). The installation instruction sheets should designate the appropriate wiring configuration.
That being said, just double-check one thing: Make sure the new ballast is rated for 2-lamps. Ballasts rated for 1-lamp will only include the red & the blue (no yellow). So I know you sad you already checked with the destributor, but double-check that one point.
May 15, 2011 | Electrical Supplies
What type of lamps are they in this oven as I wish to source them but don't know what I am looking for. Thanks
they will be either E14 25watt or E14 15watt cooker oven lamps
to locate the lamp ensure oven is off and look to the back of the oven and unscrew the glass cover, then unscrew the lamp the wattage will be on the brass part of the lamp.
you will be able to purchase them from a local hardware store (if in doubt take the lamp with you and show it to the store assistant)
Feb 16, 2011 | Stoves 720EF Electric Double Oven
About a week ago my Dell 2007WFPb LCD monitor (purchased in 2007) flickered on and off PIP mode, and would not stay on one setting for PIP for longer than 2 seconds. It was not fixed and now the power...
Not the power cord problem at this point, more likely to have failed Power supply or Inverter board.
http://lcdrepair.us/2007fpw-power.html
http://lcdrepair.us/2007fp-inverter.html
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 15, 2010 | Dell 2007WFPB LCD Monitor
Pop up inspection lamps blown
Greetings!
The original equipment replacement part number for this lamp is SFDN122-01E and is in stock from www.encompass.com for around $7 plus freight. These are in white only, but you may be able to purchase small, rubberized covers (like a little lamp condom) from an accessory/parts distributor such as MAT electronics or MCM.
To access the lamp first UNPLUG THE TURNTABLE. Lock the tonearm in place. Invert the turntable. Remove the 4 audio insulators, remove the 17 screws with spacer and then remove the other 11 screws. Remove the bottom plate. Remove the 2 screws that hold the lamp circuit board in place. Then remove the lamp screw.
Hope this helps!
Rob
Jan 14, 2009 | Technics SL-1210 Turntable
Replacement UV Lamp Source?
Dear Bill,
We have our custom dual frequency UVC lamps made here in AMERICA specifically for our SUN AIRE purifiers.
Our lamps are 9,000 hour lamps and should be replaced at about 18-24 months because it will lose its effectiveness to energize the air, thus no longer purifying your air.
The cost of our custom dual frequency UVC lamps is only $48 plus $5 SH. That equates to about $25 for your maintenance cost on our LIFETIME SUN AIRE PURIFIERS ~ MADE IN AMERICA!
www.betterair.com Please contact us at:
1-800-684-8253 and we'll get your new UVC lamp out to you within 24 hours.
We appreciate your business and look forward to serving you.
We'll be here ~ whenever you need us
Oct 10, 2007 | Sun Aire Sun-Aire Air Purifier - Stainless...
Kitchen Appliances - Others Logo
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
