Question about Husqvarna Garden
I paid 160.00 for a husqvarna 257.It has compression of 120.It nedds to be 140.Would it be worth it financially to have the top end rebuilt?I was also wondering if I am somewhat mechanically inclined,would it be difficult to rebuild it myself.I definitely don't want to make it worse so should I just leave it to the professionals?
reg501
  • 413 Answers
SOURCE: Front loader tub bearing replacement -- worth it?
Rear tub runs around $293.00, labor and service charge, around $168.00. Check your owners manual for any limited warranties that may cover the part.
If you need further assistance, let me know
Regards,
reg501
Posted on Jul 04, 2008
mgbstyle65
SOURCE: Brown foamy sludge build-up in
Cracked head or blown head gasket. This is a result of coolant or water mixing with the oil. There may also be signs of this in the coolant in the radiator
Posted on Aug 06, 2008
SOURCE: no problem just done top end rebuild
turn the tick over screw on the carb not to much and make sure the back wheel is off the floor and start the bike and let it tick over in forth gear for a while
Posted on Apr 03, 2009
techman
  • 3130 Answers
SOURCE: RCA 52
go in and disconnect the front panel board. see if that helps.
Larry D
Posted on Aug 03, 2009
tabbycat282
  • 56 Answers
SOURCE: MY KFX 80 HAS 65 PSI COMPRESSION AFTER TOP END
You may have a problem with your reeds.If you have done a rebuild because something internally has destroyed itself then the chances of those loose metal fragments chipping or cracking a reed are quite high.Pull the reed block and check it out and replace if neccesary.Other than that i can only presume a problem with the rebuild.hope i've given you some direction Armstrong.....Good luck with it .
Posted on Dec 06, 2009
What is the compression on a poulan pro
120 to 140 is ideal. Less than 100 its probably not worth repair. Less than 90 it wont run. Those blowers are notorious for the cylinder coming loose. Be sure the 4 cylinder bolts are tight before checking the compression.
Jul 11, 2014 | Poulan Pro Super Blowervacuum
Husqvarna 257 chainsaw wont start
The flywheel has an alloy key moulded into it, check the key has not sheared and the timeing is now out,
Dec 27, 2012 | Husqvarna Garden
Manual husqvarna 257
You can search for the manual, as well as exploded diagrams for your Husqvarna 257 here. Be sure to check PartsBuggy.com for replacement parts.
Jan 07, 2012 | Husqvarna Garden
I have a husqvarna 350 that wont start, wondering if anyone can tell me what is the factory compression rating?
Hi and welcome to FixYa, I am Kelly You should have 120 PSI or greater compression. There is a ported compression release so you may see as little as 110 PSI but it is best to see 120 or greater.
The Owners manual is here:
http://www.northerntool.com/downloads/manuals/195946.pdf
carb basic settings are on page 29 of the manual.
The saw has a Zama C3-EL18 carb.
The manual for the carb is here:
http://www.zamacarb.com/pdfs/TechGuide_2007.pdf (Click and wait 2.50 mb)
Your carb is the C3
The workshop manual for the saw is here:
http://www.scribd.com/doc/8152011/Husqvarna-Chainsaw-Workshop-Manual-340345346XP350351353 (Must have a facebook account to download but can be viewed online)
Thanks for choosing FixYa,
Kelly
Sep 23, 2011 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
What should the compression range be on a 2004 cr
compression range is 120-160 ok but anything under 120 needs top end,if not you will start to where on those cylinder walls with the ring
May 08, 2010 | 2004 Honda CR 125 R
My husqvarna 359 chainsaw blows fuel out the exhaust when I try to start it. Just rebuilt the carburetor with a kit. Still same problem.
You need a carburetor kit. The needle valve in the car. is stuck open. The needle valve helps to control the flow of fuel.
Jim
Jun 18, 2009 | Husqvarna Garden
Hard starting and when warms up rpm's drop
Remove the muffler and inspect the piston, rings and cylinder for vertical scoring. If so You may need a top end rebuild.
Dec 21, 2008 | Husqvarna Backpack Blower 25cc, 140 Mph,...
Piston ring
The piston ring whilst the piston is still in the pot should be relitivly tight. This is because it creates the seal to maintain compression. When the ring is taken off the piston it only has about 4mm gap between the two ends, any more than this it's probaby knackered. worth checking pot and piston for scoring around the exhaust outlet as if it's going to loose compression it will be at this point. If all these are fine check the decompression valve (if you model has one) if this is broken your compression will be ruined.
Oct 24, 2007 | Husqvarna Husky 165
Garden Logo
71 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
