Question about Zebra 140XiIII Plus Thermal Label Printer
I have an old Zebra 140Xill, will this do direct thermal transfer, do not have the manual
  • 96 Answers
Press cancel for 5 seconds while power on to print config. Then check the following parameter.
direct thermal = no ribbon
thermal transfer = ribbon
Posted on Oct 14, 2010
Warning ribbon in V53.16.7Z
The "ribon in" warning is because you set the printer to print DIRECT THERMAL insted THERMAL TRANSFER. The first mode is for printing directly on the thermal labels, not for using a ribon. The ribon sensor detects that a ribon is pressent and you get this message. You need to change the printing mode to Thermal Transfer from the printer Setup Menu, or from the Print Driver instaled on PC.
Jan 19, 2015 | Zebra Office Equipment & Supplies
I have a Zebra GK420t Alternately Flashing Red and Green light error message. How do i clear this.
From the owner's manual:
Alternately Flashing Green and Red: Needs Service 8
8. FLASH memory is not programmed.
• Return the printer to an authorized reseller
You can find the complete owner's manual on Zebra's web site.
Jul 25, 2011 | Zebra GK420t thermal transfer and thermal...
I would like to know how can i change my printer to direct labels, since i got the wrong ones and they said this printer(TLP 2844)is able to do it. Thank you.
Yes you can use this printer in thermal transfer mode (uses a ribbon) or direct thermal mode (uses special paper). Look in the manual to see how to configure. The manual is also on the Zebra web site.
Jul 18, 2011 | Zebra TLP 2844-Z Thermal Label Printer
When i try print the label..no output at the label..how to test whether the ink is function or not
I'm including this link to the users manual:
http://www.zebra.com/id/zebra/na/en/index/resource_library/manuals.results.html
But here is the basic troubleshooting info for that issue
No print on the label.The media may not be direct thermal media when printing without ribbon (i.e. thermal
transfer). See the test procedure
Determining Thermal Media Types on page 29.
• For thermal transfer printers, the media may not be outside wound or approved for use in
the G-Series printer. See the following ribbon test procedures: Ribbon Test with Adhesive
on page 32
and Ribbon Scratch Test on page 33.
• Is the media loaded correctly? Follow the instructions for
Loading Roll Media on page 11
in the Getting Started section. For printing using transfer ribbon, see
Loading Transfer Ribbon
on page 14.
Mar 28, 2011 | Zebra GK420t thermal transfer and thermal...
Changed rolls of labels on Zebra GX 420T and now nothing prints
Were the new labels thermal paper? Thermal printers need specially made paper to work right.
May 28, 2010 | Zebra LP 2844 Thermal Printer
How do you print a test page?
go to control panel, double click on printer & faxes, right click on the Zebra 140Xill then click on properties there should be a button to click for test page.
May 04, 2010 | Zebra 140XiIII Plus Thermal Label Printer
I cant seem to get rid of the "Ribbon In" error on my zebra S4M
1st change the print method to direct thermal on the LCD panel,  then check the driver on your computer, make sure you are printing with direct thermal
u can check the driver at printer & faxes , right click the printer and select printing preference .
Feb 11, 2010 | Zebra Z4M Printer
Zebra Z4 Error message
ribbon in means, you choose direct thermal print method which is printing without a ribbon and yet you print with thermal transfer print method.
just check on lcd panel , change the print method to thermal transfer. and make sure the setting on your driver is thermal transfer too, or else it will keep reverting back to direct thermal
Feb 04, 2010 | Zebra Z6M Plus Thermal Label Printer
My zm400 keeps reverting back to direct thermal
did it stay on direct thermal if you not doing any print job ?
then i assume you the problem is when you printing .In ZEBRA DESIGNER, there's a printing preference that can be set up... i think u selected direct thermal when you print with zebra designer, that's why whenever u start printing, it show RIBBON IN again.
the solution is, Just changed the printing method from zebra designer.
if you aren't using zebra designer, then the problem at your driver. Open Printer & Faxes, then right click your Printer and klik on Printing Preferenced. There u can set up the printing method to Thermal Transfer.
The thing is....... changing the Setting from LCD panel won't change the setting on the driver.
i hope this will help you
Aug 19, 2009 | Zebra 203DPI Printer
Zebra z4mplus printer resets to thermal transfer
Please go to the inhouse program & click printer properties and
change the printer setup to direct thermal and that's it.
Joe
Dec 12, 2007 | Zebra Z4Mplus Label Printer
Zebra 140XiIII Plus Thermal Label Printer Logo
119 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
