Question about Whirlpool Washing Machines
Machine is not filling with water.power is on and it spins fine.
  • Obertelli
    Obertelli Sep 16, 2010
    Please state the exact Whirlpool model.
  • Whirlpool Master
  • 43,501 Answers
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Sep 16, 2010
Frigidaire stackable glet1031cs0 spin cycle spinning AND filling with water at the SAME time...!?
ok unplug the machine and take the back off locate the the water pump and check that its not blocked with any debris and also look for a small pipe 5mm going upwards, take it off and blow gently into it you should hear a click and one when you let the air out again, if so then unblock the place where you took it from with a pipe cleaner or metal rod, replace the pipe and try to run the machine again eric
Jan 13, 2018 | Washing Machines
My frontload washing machine fills water but then it will not turn.
I would check the motor. Sound like it may be at fault.
Nov 04, 2012 | Washing Machines
My machine does every thing except wash. I just washed a load it worked fine, put another load in, it filled up with water but would not wash. I had to drain and spin to get my clothes out.
If it the machine fills up but does not wash, then most likely the selector switch is faulty. You can also test power to motor well in wash mode cycle. Test with a voltmeter to make sure motor is getting power. If not, then selector switch is bad. If motor is getting power but not spinning, then it may be faulty.
Sep 21, 2009 | Washing Machines
GE wcxr1070a washing machine. fills with water
Check the water level switch and the plastic tubing to the switch.
Sometimes soap scum stops up the plastic hose and the water level switch does not close to send power to the timer.
If the plastic hose is good and the water level fills and stops replace the water level switch.
Mar 21, 2009 | GE WCXR1070A
Washer trips circuit while filling tub
Sound like the inlet valve coil may be shorted. Remove console and check wires from water valve to control. If wires look ok, the inlet valve has a problem
Mar 18, 2009 | Maytag PAV2300 Top Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
The machine works fine until it reaches the rinse cycle.
The buzzing sound is the cold water inlet valve is getting power but water is not able to enter. You need to have the valve replaced or make sure the cold water is turned on at the sink. Hope that helps, let me know.
http://tclaundryrepair.com/
Feb 28, 2009 | Kenmore 24032\24036 Top Load Washer
Washing machine refills after spin cycle
Can you hear the pump running if not the machine may be syphoning out, if the outlet is into the down pipe too far this can cause it to syphon. The outlet should only be into it by about 6". The machine will fill with more water on the rince than the wash cycle that will cause the problem. If you can hear the pump running the machine mite be over filling there may a blockage in the presure system if you take the lid off (making sure the powers turned off) you will find a round switch with a thin hose comming off it tace the hose and you should find a small bottle this may be blocked. Hope this helps you.
Dec 22, 2008 | Washing Machines
Washing Machines Logo
Dan Webster
Dan Webster
Sal De GO PATS
