Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
HELP! phillips 60PP92902
I have a both red and blue convergence problem. I replaced the IC's put everything back in the TV. The red problem went away but the blue is still there.... Do you have any advice of what may have gone wrong?
  • berryd May 22, 2008
    My television picture has a downward bowing effect with a look of viewing a 3D picture without the 3D glasses where red and green bands are out of alignment.
  • Anonymous Jun 13, 2008
    Picture look like a 3D image with colors not lining up. The red is uneven with the rest of the colors. I tryed to adjust the picture with manual convergence but when I push up on the remote control the cursor want move the red in order for me to center it. What going on with my TV. The Laker's play tonight and the tv just had to act up today. Can you help me with my problem.
    Habit-Forming:
  • 55 Answers
Would these resistors cause mis color that makes me have to adjust the RGB and focus on the panel inside the compartment? If not, is there a way to get these colors lined up right? I cannot get them perfect. I need help! I either end up with blue grass or red/orange faces. Any advice would be greatly appreciated. Thanks
Posted on Jun 22, 2008
  • Philips Master
  • 8,617 Answers
That model will usually have a couple 6.8ohm 1watt resistors that will get burned open when the ICs go out they are located right next to the ICs and they are all identical resistors often with no color bands just marked with 6R8 1WJ. Lift one side of the resistors out of circuit to check them with an ohms meter. radio shack wont have those resistors but you can get them at the following link.
http://servicemanuals.vstore.ca/
Posted on May 21, 2008
JVC AV-48WP30 convergence drifting after IC replacement
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 16, 2010 | JVC AV-48WP30 48" Rear Projection...
Phillips 60pp9202/17f projection convergence
what about blue? this is an indication that maybe one of the convergence ic have failed. generally you replace both. falure of the ic can also be sympton of other problems.. The oputput ic resistors. the covergence power fuses. but the first step is to replace the ics
Nov 03, 2008 | Philips 60PP9202 60" Rear Projection...
BEYOND HELP has a new problem
yes if u can find someone that can solder a part in that is all u need to do .u need to replace the convergence ic and when u replace them u will u can set the convergances with your remote control now the cost for the parts is about 20 to $ 40.00 dollars just for the parts and i dont know what the part number is without the service diagram but it is very easy to put the parts in there is no adjusting in the back everything is on your remote that u need. i hope this will hp u marty
Oct 13, 2008 | Panasonic PT-51HX41 51" Rear Projection...
Double Image
need to change convergence ICs
If you need more info., let me know and I can go over the details
mahi@pacbell.net
Sep 08, 2008 | Sony KP-57WS510 57" Rear Projection HDTV
Phillips 60PP920217F Convergence Problems
You will need two STK392-120 Convergence ICs and about 4 6.8 ohm 1watt resistors. You can get replacement ICs and resistors at the following link and they provide free instalation instructions with pictures so you can do the job yourself. Here is the link.
Jul 17, 2008 | Philips 51PW9363 51" Rear Projection...
Phillips 60pw9363 Which IC is red and which is blue
Thats the DPTV 335 series chassis when the IC blows it will usually take out 1 or 2 6.8 ohm resistors along with it. Look at the resistors right next to the ICs you will notice 1 or 2 with a little discoloration in the middle replace those and your set should be back to working just fine. Let me know if you need more help. These resistors are easy to spoy they all look alike and shouldnt have any bands on them they will be stamped 6R8 ohm 1W J
Apr 12, 2008 | Televison & Video
Phillips rear projection tv model #60pp9202/17f
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Feb 25, 2008 | Philips 60PP9202 60" Rear Projection...
Philips 50P8341 50 in. Rear Projection Television
Sounds like the blue convergence IC s bad. They are relatively easy to replace if you can solder they cost around 10.00 each and you should change both the red and the blue.
Feb 09, 2008 | Philips 50P8341 50" Rear Projection...
Philips 60 rear projection hdtv looks 3D
If your red convergence controls will not remove the red in all four directions, you have a faulty convergence IC. You will need to replace both. They cost around ten dollars each. Let me know if you need anything further.
Feb 02, 2008 | Televison & Video
Sony tv KP-61HS10 lenses wont align
This is common in those sets. One of your convergence IC's has stopped working and needs to be replaced. The convergence IC should be replaced and the convergence circuits realigned by someone with experience in Sony projection sets.
Aug 09, 2007 | Sony KP-61HS10 61" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
103 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
