Question about Cross Infoguard Shredder SX102M
I need the switch acuator for the Axeus SX120D Shredder. Can you tell me where to get it? Thanks.
Shredder wont start
Hello Mary, please tell me the make, model and serial number of your shredder
Thanks
Jan 14, 2014 | Office Equipment & Supplies
Unit no longer shuts off when on "Auto" setting. I have to use this switch manually to turn unit on and off for every use, and would like to restore original functionality.
Don't know what kind of shredder is is but most have one or two eyes or switches that tell the shredder to start and also tell is to stop. these eyes get paper dust on them and will not shut off
, or they could be bad eyes or switches. Use can air and blow down in center of shredder gears and see if it solves problem. Also shredders shuld be lubricated with shredder oil every now and then....
Sep 20, 2013 | Staples Executive EPS711X Shredder
I need a new drive gear
Owner:AXEUS, INC.Owner Address:P. O. Box 130026
Carlsbad CA 92013Owner Web Sitewww.axeus.comOwner Phone760-496-1300Owner Toll Free
Donna:
This is the latest information that I have on Embassy. Good luck.
Sep 12, 2012 | Office Equipment & Supplies
Shredder will run in reverse mode but not in forward/auto. Has not been jammed or overheated.
Unplug the shredder. CAREFULLY clean out the shredding teeth and paper pathway. On some models you can loosen one end and open the paper path for better access. Ther is an acuator arm for a switch at one edge of the paper path and that will get clogged with paper and the arm cannot move to tell shrdder paper paper is in, ready to go. A blaast or two of canned air in the direction of the arm will help too.
The reverse action is ususlly initiated manually and is not affected by switch operation.
Let me know
Jan 15, 2011 | Techko SH2106PA Shredder
I have a Fellows Powershred ps 60cc and removed the shredder top to empty the shredded documents. When I put it back on, the red light will not go out and it will no longer work. It was working perfectly...
the shredder has a safety switch that closes when the unit is put back on the basket. check under the cutter head for the hole that has the switch and check your basket for the acuator put together so they will line up
Nov 03, 2009 | Fellowes Powershred PS-60 Shredder
Appears not to be getting power Could it be a safety switch of some kind. Don't have owner's manual.
Make sure the Bin is put back properly, there is a micro switch that powers the unit once the bin is in place
Apr 13, 2009 | Office Equipment & Supplies
Shredder flap has fallen off -- company no longer makes part
Those plastic tabs are so pesky. They always break.
You can try taking some wire, perhaps an old coat hanger, and cutting 2 lengths of 4-6" each. Then attach the wire pieces in place of where the tabs were using heavy tape, which should allow enough flexibility to get the new tabs back in the holes.
If the tabs were bigger/thicker than the coat hanger wire, go to the hardware store (Lowes, Home Depot, Ace, etc.) and ask to see the metal rods. Then just pick a piece of the right thickness and they'll probably even cut it for you with their chain cutting tool.
Mar 24, 2009 | Cross Infoguard Shredder SX102M
96 GMC k2500 Suburban 4x4 upgraded front acuator
on the top side of the transfer case near the shift arm ....there is a transfer case indicator swtch.... connect into the only brown wire on the switch.........Be sure to solder the wires together, scotch locks are a no no ,, will corrode and cause intermittent connection, wich can result in other 4 wd component damage
Jan 25, 2009 | 1996 GMC Suburban
Infoguard SX100M unit will not shred. Green light comes on.
I have the Infoguard SX100M Axeus, sold by Staples.
Only the reverse was working, UNPLUG and open back cover, the paper mechanical switch was working fine, red side switch, the gears and fuse were all ok, I think something on the circuit board was fried.
Anyways, I switched the BLACK and WHITE wires with each other going to the shredder motor, thus when I switched it to reverse, it would go foward and shred. Its working now, only in reverse.
Jan 10, 2009 | Cross Infoguard Shredder SX102M
Sx-102M
I have the Infoguard SX-100M Axeus, sold by Staples.
Only the reverse was working, UNPLUG and open back cover, the paper mechanical switch was working fine, the gears and fuse was ok, I think something on the circuit board was fried.
Dec 21, 2007 | Cross Infoguard Shredder SX102M
Cross Infoguard Shredder SX102M Logo
96 people viewed this question
Top Cross Office Equipment & Supplies Experts
Computer Links
Ivan
Ivan
Level 1 Expert
gbob59
Are you a Cross Office Equipment and Supply Expert? Answer questions, earn points and help others
