Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
What does Error code 2106 mean? - Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
  • 105 Answers
1. Go to www.kodak.com/go/2005 to run SSEUtility.exe.
2. Do one of the following depending on your browser:
- WINDOWS Internet Explorer: Click Run, then click Fix.
- MOZILLA Firefox: Click Save, then double-click SSEUtility.exe.
3. Try to install the KODAK All-in-One Printer Software.
4. If the following message window appears, your processor supports SSE and the utility will not be able to help.
Click the X in the upper-right corner to close window.
5. If the problem continues or you were not able to use the utility, contact Kodak (1-800-421-6699)
Regards
Abhilash
Posted on Sep 16, 2010
  • alanmcwatter Feb 13, 2011
    The utility doesn't help and thus I'm no further forward with this problem.
2006 suzuki reno code 2106
read the FSM book yet or alldata.com???????
2106
2L automatic?
says
Trouble Code: P2106 (2.0L L4 VIN - Auto)
Throttle Actuator Control (TAC) System Performance - Throttle Limitation Active
Number of Trips to Set Code: 1
Trouble Code Conditions:
Ignition ON. The ECM detects the system is in Limit Performance Mode.
Possible Causes:
  • Throttle body
this means the ECU is in limphome mode.
and is cause because the ECU sees throttle sensors. that dont JIBE
There are effectively (insane yes) 4 TPS sensors
2 under foot.
2 in TB.
if any disagree at any time BAM, limphome mode sets.
"limited performance, old suz name was FAIL SAFE.
no matter its just the same.
use a REAL scan tool that sees ALL codes, i suspect you missed some, is this an AUTOZONED scan? with cheap, tool?
try an Innova 3160 tool. and see them all.
it is suspisious to me , only ONE DTC error !!!
Jul 12, 2014 | 2003 Suzuki Aerio
I have the error P 2106 on my ford explorer 2005 because there is message "fail Engine safe mode"
That means the accelerator pedal is in fail safe and you will only get 35% throttle accleration you should have other accompaining codes with this 2106 and those should be done first if you have ABS codes that has to be done first,2106 can be causes by a open TAC wiring disconnect, a TPS sensor that has failed (Throttle position sensor), Here is the big concern you will need to check to see if all the module are communicating with each other, you mainly will have to go to the dealer for this concern and only thier scan too can fix it and find the problem
Jun 08, 2011 | Ford Explorer Cars & Trucks
WHAT DOES CODE P2106 MEAN?
P 2106---Throttle Actuator Control System
Forced Limited Power
Not likely the TACM is bad
You got Ignition Coil Misfires
What other codes do you have?
Feb 18, 2011 | 2004 Lincoln LS
Denon AVR-2106 - Zone 2 shuts down system
Check your speaker wires on zone 2 and look inthe manual for speaker configurations with zone 2. you may have a speaker conflict. If you still have an issue, post a comment with your speaker setup and I'll help some more. Hope this helps
Jun 28, 2009 | Denon AVR-2106 Receiver
Just need the for a universal remote on the Denon AVR 1206
My 2106 reciever is toast but the remote is fine, lets talk.
Apr 04, 2009 | Denon AVR-2106 Receiver
Cisco 2106 does not recognize a 1250
is portfast enabled on the port? ;-)
Nov 14, 2008 | Cisco 2106 (AIR-WLC2106-K9)
Denon AVR 2106 amp failure
Does it still power up for a little bit or so with no sound what so ever?....I there is no dents in it or metal pushed in causing cracked connector boards....I can take it off you hands for a couple parts I need ...because your transformer and 2 resisters are shot and it will cost almost as much as the unit cost's.
I do have a brand new never opend $649.99 Denon AVR-788 for $365.00.
And 2 used AVR units Denon and Onkyo.....ALL HDMI
call 630 742 6587
Aug 30, 2008 | Denon AVR-2106 Receiver
HAVE TO UP VOLUME ON DENON 2106 TO HEAR ALL AUDIO IN NIGHT MODE
There should be a volume adjust on the center channel. This is done by the remote exclusively. You may also wish to compress the sound using the dynamic range compression button or so labeled.
Aug 31, 2007 | Denon AVR-2106 Receiver
Symbol ls 2106 handheld scanners
I cannot get it going on the pc with windows xp pro
Aug 10, 2007 | Symbol Hotshot LS2106 Handheld
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
3,675 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
