I replaced the belt In an HP designjet 500, and I am getting an error 86:01 to replace the carriage?carriage movement error. Is there a known solution or cause that can fix this. Please assist. Thanks
  • yan dikshteyn Sep 17, 2010
    Well the original error before i replaced the belt was to close the printhead lever even then it was close.Then After I replaced the belt I got that error message.I used the service manual and the instructions that came with the belt.What else can I try should i take the belt off and try again, what should i look for?? thanks
    appreciate ur help thanks
    President:
  • 2,777 Answers
Well it is caused by just what it indicated, a problem with the carriage movement. It is very very difficult to successfully replace one of those belts unless you have done it before... but maybe you have? Did it work after you replaced the belt right away? I am assuming you saw this error right after replacing the belt correct?
Let me know and I can help.
Thanks
Tim
Posted on Sep 16, 2010
  • Tim Grayson
    Tim Grayson Sep 17, 2010
    It is very difficult to say without seeing it in person, I would take it off and try again, it definitely can't hurt it at this point. The print head / carriage should be the far side I believe when it's done... is that how it is now? It should be all the way over, usually to the right hand side if you are looking at the printer from the front. I will verify, but let me know, does that sound right? I am quite certain.
    Thanks
    Tim
Hp designjet 500 carriage assembly it's vibrating
Get carriage assembly out from the service station area, remove right door, check right side pulley of carriage belt, weather its cracked or dirt particles deposited on it, clean/replace it, lubricate carriage rail, fix back every thing check .. best of luck.
Nov 26, 2012 | HP DesignJet 500 InkJet Printer
Hp designjet 500plus ,first time i change carriage belt ,but now it shown allignment error..
Two thing you need to check:
1. Are you replaced genuine carriage belt?.. Original belt having two type of inner tracks.. Right side horizontal & left side vertical tracks. Are you fixed it properly or not..
2. Check carriage assembly play.If it is over play(carriage bushes may be warn out) alignment won't complete, If bushes are available in your country replace them & do the calibration..If not go down how to alter bush. see the snap shot
3. While carriage movement pl check trailing cable flexibility.
Carriage Bush:
Note:This modification only professional not for users:
Un screw screws both sides as shown in fig, take out bushes estimate how much warn out happened.
Thing needed:
Fevi quik(glue),small peace of miler sheet,scissor & tweezers.
Cut miler sheet in to small peace & insert warn out place of bush(between bush & rail) & apply glue, fix it permanently,do it both sides & check for the carriage play.. once its finished try for alignment.. For this activity no need to remove carriage assembly from the rail. Main aim is alter bush warn out..
May 30, 2012 | HP DESIGNJET 500 InkJet Plotter Printer
86:01 error in designjet 500 plus Paper jam...
System Error: 86:01
Problem Description: Carriage-Axis shutdown.
Corrective Action:
If this error code appeared but was NOT caused by a paper jam, then try the following:
  • Too much friction in the Slider Rod. Enter the Printer Information utility and check the Scan-Axis usage. If the percentage is close to 100%, then lubricate the Slider Rod.
  • The Carriage is bumping into the Service Station. If the carriage is stuck at the right hand side of the Printer and cannot be moved out to the center of the Print Platen it is because the Service Station cannot uncap the Printheads. In this case replace the Service Station/Aerosol Fan Assembly
  • Perform the Carriage Movement test
Aug 26, 2011 | HP DESIGNJET 500 InkJet Plotter Printer
Need instructions to replace carriage belt for hp designjet 500, specifically how to remove and replace on the carriage assembly
When you order the belt from hp it will come with the instructions, if not email me and I will send it to you.
Jul 12, 2010 | HP DesignJet 500 InkJet Printer
HP 500ps showing error is System error 86:01
System Error: 86:01
* Too much friction in the Slider Rod. lubricate the Slider Rod.
* The Carriage is bumping into the Service Station. If the carriage
Apr 16, 2010 | HP DesignJet 500ps InkJet Printer
There's an error appears. It was error number 86
86.01 can be a couple of issues pertaining to the movement of the carriage assembly.
1. Too much friction in the Slider Rod. Lubricate the slider rod.
2. The Carriage is bumping into the Service Station. If the carriage
Service Station/Aerosol Fan Assembly.
3. Check the carriage belt for wear. Check the carriage path for debris. If the belt is worn, replace the belt. Also, clean the teeth on the carriage drive motor, the debris from the belt will accumulate on the teeth.
Sep 28, 2009 | HP DesignJet 500ps (42 in.) InkJet Printer
Hp designjet 500 plus
Problem Description: Carriage-Axis shutdown. Corrective Action: If this error code appeared but was NOT caused by a paper jam, then try the following:
1) Too much friction in the Slider Rod. Enter the Printer Information utility and check the Scan-Axis usage. If the percentage is close to 100%, then lubricate the Slider Rod.
2) The Carriage is bumping into the Service Station. If the carriage
3) Perform the Carriage Movement test
Aug 19, 2009 | HP DesignJet 500 InkJet Printer
Carriage belt replacement
Use the carriage replacement procedure in the service manual. Download here: www.lpscomputer.com/ec/manuals.htm
Aug 10, 2009 | HP DesignJet 500ps (42 in.) InkJet Printer
133 people viewed this question
k24674
