Question about Panasonic KX-T7630 Corded Phone
How do I get my panasonic kx-t7630 to ring more than 3 times before going to my voicemail?
  • Panasonic Master
  • 2,460 Answers
If you've set call forwarding from the set, try dialin *713 and a 2 digit number from 00-99. It's the number of seconds before the call forward and a ring cycle is approximately 6 seconds, so start with 24 and go up from there.
There's another feature that will work against you, and that's the transfer recall time. It may be set to 20 seconds, so you will never forward before the recall timer. It's set on a systemwide basis.
Carl
Posted on Sep 17, 2010
2 Suggested Answers
SOURCE: number of rings before going to voicemail on KX-T7630
Press the FWD/DND button, then scroll through the menu button until the screen shows "FWD No Answer time". Then use the number key pad to change from 000 seconds to 010 seconds (or longer if required). Then exit out of the menu.
Posted on Jan 22, 2009
How to turn on voicemail for panasonic kx-t7630?
http://www.panasonic.com/business/toughbook/computer-support-home.asp
Jul 21, 2014 | Panasonic KX-T7630 Corded Phone
KX-T7710
The KX-T7710 isn't an answering machine. The ring count is controlled by the answering machine or voicemail system connected to the phone line. Could you tell us the make and model?
Nov 21, 2013 | Panasonic KX-T7630 Corded Phone
Panasonic kx-t7630 message light
Apparently you're subscribed to a voicemail service offered by your telephone company. Please contact them for instructions on accessing their voicemail system.
Nov 11, 2011 | Panasonic KX-T7630 Corded Phone
Manual for panasonic kx-T7630
who knows how to get voicemail to pick up
Oct 31, 2011 | Panasonic KX-T7630 Corded Phone
My Panasonic Phone KX-T7630 rings seventeen (17) times before going to voice-mail. Desired amount of rings before going to voice-mail is four (4) to five (5).
This is just for your phone ringing when it's dialed, not for outside lines ringing on your phone.
From your intercom, dial *7104 (CF No Ans) 500 (if that's your VM extension) # That will flash your FWD/DND light to tell you it's forwarded on No Ans. Now on the intercom, dial *71324 The 713 part tells your phone to forward after xx seconds. 24 is about 4 rings. You can adjust the timing using 6 seconds as a ring cycle.
Carl
Jun 28, 2011 | Panasonic KX-T7630 Corded Phone
How do you put a panasonic KX-T6730 on voicemail instantly if you need to leave the office early?
Press
Dial 50(forwarding program number) on the keypad
Press or
Dial one of the following single digits for the condition you want
0-off
1-DND(Do Not Disturb)
2-All calls forwarded
3-Busy calls forwarded
4-No answer calls forwarded
5-Busy/No answer calls forwarded
Dial the voicemail access code(default is usually 500; this is the number that will ring voicemail)
Press or
Lift handset or press to end
Dec 10, 2010 | Panasonic KX-T7630 Corded Phone
Number of rings before going to voicemail on KX-T7630
Jan 22, 2009 | Panasonic KX-T7730 Corded Phone
My Phones only ring twice before it goes to VoiceMail
What you can do is go into the management console for your system and find the forwarding this is under extentions option 2 fwd/dnd select your extention number and on the bottom option FWD No Answer Time (s) set it to 10 or more and this will change the number of rings.
I use a KX - TDA600 PABX so I hope this helps
Jan 06, 2009 | Panasonic KX-T7630 Corded Phone
Outside calls are going directly to voicemail
there should be a switch at the side of the phone that controls this.
you need to set the amount of rings u want before it goes to voicemail.
sam !
May 12, 2008 | Panasonic KX-T7630 Corded Phone
Panasonic KX-T7630 Corded Phone Logo
370 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
