Question about Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer
It will cut out when i give it full trottle,it idles just fine .its a ryobi 31cc 17 in
    Scholar:
  • 71 Answers
You can adjust the 'H' - high speed needle by removing the plastic carburetor cover by removing the 4 torx screws. On the carburetor, there may be a 'L' and 'H' needle. (Ryobi used two different carburetors on this model and one may not have a 'L' and one may not be adjustable with common tools). If the 'H' needle is adjustable, start the machine, warm it up and go to WOT (wide open throttle). At WOT, turn the screw about 1/4 turn out or in and see if the engine speeds up. If it does, fine the point in which the machine gets the highest RPM's and then back it off about 1/8 turn.
Note: This is a sign of a carburetor that needs to be cleaned and rebuilt with a new fuel metering diaphragms which would be common if the machine is > 4 years old and you did not completely run the machine dry of fuel in the fall. Rebuild kits available for about $15 through local sources or $10 through ebay.
Posted on Sep 25, 2010
Chokes and Dies when cutting
Adjust the choke or carburetor. In case your chainsaw stalls when the engine is idling, ensure that the choke is set properly. To do so, first try releasing it to adjust it, and then move the plate and tighten all screws once again. To loosen any grit, spray carburetor cleaner spray on the choke's shaft. The carburetor may also need to be adjusted; consult your owner's manual which will guide you on resetting the idle mix screw.
Mar 13, 2014 | Ryobi 940968018 C4620 Label
I have a troy bilt trimmer model tb20cs. has been laying for about four years. gave it a good cleaning ,new spark plug amd fresh gas. starts up fine and idles a short while then cuts off. If you try to...
Carburetor needs cleaning and probably diaphragms. Be sure to completely disassemble and pay very close attention as to where each diaphragm and gasket goes also make sure you remove the needle valve and clean screen.
Aug 25, 2017 | Troy Bilt Tb20cs 2 Cycle 31cc Gas String...
Does Bolen's weed wacker BL100 17" cut 31 cc require a mix of gas and oil. Thank you
I was able to get information from someone's manual. I can't find mine. Would like a manual.
May 16, 2009 | Mtd Garden
Engine stalls when giving gas
Make sure you have the carb. fuel line on the correct side of carb. Not on primer bulb side.
May 14, 2009 | Garden
I have a 89 nissan 4x4
Have you checked the EGR valve yet? Or check your Fuel regulator or pump.
Feb 05, 2009 | 1989 Nissan Pathfinder
Ryobi 31cc lawn trimmer carb adjustment
As with all 2 strokes if you have compression and a reasonable spark, you only need fresh fuel with correct oil ratio) and they must go !(as long as you haven't fiddled first and all gaskets are sealing) I start mine by(1) pumping the primer till it is firm,(2) full choke,(3) pull till it kicks ONCE,(4) half choke, pull till it runs,allow to warm up and(5) switch to run (you may need to apply a bit of throttle while pulling as in (4)(or give it a few more pumps if it dies) If all is ok, check that when properly warmed up there is a smooth transition from idle to full revs, if it hesitates it may need the LOW SPEED mixture leaning (clockwise) SLIGHTLY.If it dies the LOW SPEED mixture may need richening(anti-clockwise)(adjust 1/8 turn at a time) Make sure that motor is just peaking at full revs and is on the RICH side of peaking (HIGH SPEED mixture)(this will avoid seizing it Adjust both till it revs cleanly and is JUST rich at full, and idleing nicely and it should start without too much trouble.(If you have fiddled and are lost,-about 2 1/2 turns out from closed on both needles should get you started)
Nov 23, 2008 | Garden
How do I connect the fuel lines on the Ryobi 31cc petrol edge trimmer.
I have a Ryobi 31cc 17inch cut with gas line problems and this answered my questions. Thank You
R Green
Oct 18, 2008 | Garden
Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer Logo
1,036 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
