Question about Dell POWER SUPPLY Power Supply
Push power button on dell desk top and the computer will not come on
  • Dell Master
  • 27,725 Answers
Replace your PSU then test all leads that are attached to your hard drive sounds like a faulty lead of some sorts then
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
Posted on Sep 16, 2010
My computer will not power up when i push the power button its an acer aspire desk top
First make sure that computer is getting power, check that AC cable is connected and led light is on behind the computer. Remove the cable for a while, then but it back in. Push down the power button for 10 seconds. Then try to start the computer.
Apr 14, 2014 | Acer Computers & Internet
Eject a disc from the desk top
Push the eject button on the drive. OR open MY COMPUTER, right click on DVD/CD rom drive, eject. If all else fails, remove drive open case remove disk, inspect for debris in drive.
Nov 25, 2012 | Dell INSPIRON 6000 CENTRINO...
My dell desk top wont power on when.i try to turn.it.on
When you press the power button and if the power LED does not light up then you most likely have a faulty switch mode power supply.
If you do not know how to fix it then I suggest you as a tech savy friend to help you or take it to your friendly computer repair shop.
Apr 13, 2012 | Dell Computers & Internet
How do you do a cold boot on a dell desk top model Inspiron 530? The computer will not boot up
Hmmm....you press the power button on the front of the case. I am not sure what you need exactly. If the computer has had a different power supply installed there could also be a power switch on the back of the case.
If everything is plugged in correctly and you don't hear fans or hard drive sounds, you most likely need a new power supply.
Jan 18, 2011 | Dell Dimension 5100 (D51L1) PC Desktop
How to acsess bios for dell 1100 desk top
immediately after you push the power button push the del key until the bios screen appears.
Nov 23, 2010 | Dell Dimension 1100 PC Desktop
How do i reboot my dell desk top computer.
press control+Alt+ Del keys at same time and select shut down. Once it turns off press power button. You have just rebooted your computer
Sep 26, 2010 | Computers & Internet
Cannot start my dell inspiron 570 desk top computer with the power button in front of computer
cannot start my dell inspiron 570 desk top computer with the power button in front of computer
Sep 16, 2010 | Dell POWER SUPPLY Power Supply
Dell dimension e310 desk top will not power on
If the POWER Button on the TOWER is blinking AMBER (Yellow) then the most likely failure point is the POWER SUPPLY in the Tower.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817226001
Dec 21, 2009 | Dell Dimension E310 PC Desktop
Mouse V450 shipped with new Dell Desk top does not work reliably
It should be good up to 30 feet, whatever the setup. You might try plugging the send/receiver into a front port to see if that helps.
I usually open Device Manager, open each USB device and set the power to stay on, (not "turn off this device to save power"). That way, sleep mode won't cause you to lose contact with the mouse. Or just disable sleep mode.
May 18, 2017 | Logitech V450 Laser Cordless Notebook...
Dell dimension 3000 desk top, does not turn on ?
It's one of two problems: bad power supply, or bad motherboard. If you are electro-mech inclined, remove the power supply. Take it to your local computer repair shop, and ask for one just like that one.
Reinstall, power up should (most of the time) fix this problem. If still no power, you need a new mb. Return to the shop, ask them to replace mb. This repair should be right around $250.0 - tops. Any more than that - replace computer.
Hope this helps. Either way, if you wouldn't mind taking the time to rate my response, it would be much appreciated!
Thanx and good luck.
gurutim
Mar 22, 2009 | Dell Dimension 3000® Pentium® 4...
Dell POWER SUPPLY Power Supply Logo
103 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
