Question about Acer Aspire One 532h2298 Netbook
I'm trying to connect my acer aspire one 532h netbook to my tv via a vga to composite/s-video rca cable. I described the problem to the technician and they said that the problem was not the cable or my computer, but that I had to adjust my settings. But, they want to charge over $100.00 for the support, because this is not covered under my warranty. The problem is this, the picture comes up on the tv screen, but it's gray and split into 3 and also pretty much unreadable. Could you tell me what i need to do without draining my bank account dry?!
  • 11,896 Answers
On your main windows screen, right click your mouse, go to properties, then go to settings.
You will see two boxes. Box 1 and box 2. Take and drag box #2 to the left side of box #1. Then click apply, then click ok. Now you should be able to see your screen on your tv.
Posted on Sep 16, 2010
How to connect acer aspire 5315 to LG led tv
Acer Aspire 5315 doesn't come with an HDMI port. So, you have the following options:
1. Use a VGA Cable to connect the PC to TV if the TV has PC-Input facility
2. Use an S-Video cable to the TV's S-Video-in port if the TV has it
3. Use and S-Video to HDMI converter if the TV has HDMI port
(http://www.amazon.com/Composite-S-video-Audio-HDMI-Converter/dp/B003NS0UUQ)
for audio, you can use 3.5mm to RCA (Red/White) connector to connect to TV's audio-in port.
Apr 15, 2013 | Acer Aspire 3680 Laptop
How to connect my acer D255E to the TV
According to the limited resources that I could find your only video output is a VGA port. Most newer televisions, predominantly LCD televisions will allow a direct connection via VGA. If your TV does not support VGA, can try using:
VGA to HMDI for HDTV's - Amazon search http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=vga+to+hdmi&x=0&y=0
With these I typically recommend a full force converter over a cable, but often times cables will work. Remember that with a VGA to HDMI cable only, this will only pass video and not audio. You will need separate cables for audio.
If you have a non-HDTV try this: http://www.amazon.com/VGA-Adapter-S-Video-Cable-Video/dp/B000Y7T5UU/ref=sr_1_1?ie=UTF8&qid=1315249911&sr=8-1
Use either S-video or RCA connectors to your TV.
Sep 05, 2011 | Acer Aspire One D255E13438 Netbook
How do I connect the Acer netbook to the TV?
The only option is using the VGA port on the Aspire One to hook it up to the TV.
Your TV must have a VGA in port for your to be able to hook your computer to your TV. All you need is a regular VGA cord.
Mar 26, 2011 | Acer Aspire One Netbook 8.9" Notebook
My tv is a sanyo ds31590. I need to connect to an acer aspire 5253-bz692 in order to watch netflix. What cable do I need?
You'll need a VGA to Composite or Component Cable. Asuming you have RCA Composite/Component Connections on your TV.
I'll Look something like this:
funnyx_1.jpg VGA to Composite
or
VGA to Component
Make sure you TV has @least one of these 3 colored group inputs in front or in back of it. 1. Composite (Mono): Yellow, White or Red
2. Composite (Stereo): Yellow, White, Red 3. Component: Red, Green, Blue
If you don't have any of those then you'll need This Along with a Splitter.
Hope this helps, if it does then please remember to leave Feedback/Testimonial.
Mar 22, 2011 | Acer Computers & Internet
How do I connect my acer aspire 5050 to TV?
Since the Acer Aspire One D250 only has VGA output for its video, you will need a VGA cable to connect between the D250 and a TV that accepts VGA input as a video source. The sound is separate. A mini-stereo jack on an audio cable with two RCA phono plugs on the other end would be used to connect the D250 audio output (usually used for headphones) to the left and right audio inputs on the TV. You may need to use the TV setup screens to select the proper video and audio sources. With the TV on and proper video source selected, you now should be able to press Fn and F5 to get a menu in the middle of the D250's screen that allows you to select the video destination by holding down Fn key and pressing the F5 key repeatedly. The single large screen icon (3rd one from the left) is the one to select video output to VGA port only which would send it to your TV. The sound on the D250 does not need to be selected but you may wish to adjust its level and/or properties to be more suitable for TV.
Jan 19, 2011 | Acer Aspire One D250 Netbook
How do I hook my tv up to my acer netbook? I dont have a tv port but do have a port for a second moniter and have the cord to hook it up but it will not work...
If the TV doesn't have a VGA input, you have two options. If the TV has component video inputs (3 RCA jacks color-coded red, green and blue, not just a single video jack coded yellow), you can use a simple adapter cable. Here is an example.
If your TV only has a single yellow video input jack (called composite video) you can't use the simple cable. But you can get a VGA to video converter. This device takes the VGA signals and converts them to the form the TV can use.
Hope this helps. Thanks for using Fixya!
Mar 30, 2010 | Acer Aspire One PC Notebook
Cannot get video to tv with vga to s-video adapter
try to use the vga output enable function key. it should be one of the "F-keys" (F5, F6...) hold the "Fn" key (generally in blue for the acer aspire 5520 series) and press a key that has a drawing resembling two monitors, but not the one that has a brightness drawing inside on of them, as it will turn off your main screen backlights. in the acer aspire 5520, it is the F5 key. look for a picture of this model's keyboard and you should see a similar key on your netbook as it is a manufacturer standard.
Feb 06, 2010 | Acer Aspire One Netbook 8.9" Notebook
Acer Arspire 1642 WLMI does the vga output support tv out?
i dont think it has..you can then buy a VGA to RCA for the regulatr TV(should work for both the TVs)
an example is here
http://www.cablesnmor.com/vga-rca-cable.html
please info if u want more help,will be glad..regards
Nov 27, 2008 | Acer Aspire 1642WLMi Notebook
Connecting my acer aspire 5100/5102 to my tv via cable
There are a number of possible ways to getbthe display up onto your television. Im not certain which colours to use with which but once its all plugged in you will need to hold down the FN (funtion) key and press one of the F1-F12 buttons. to work out which one you just need to look for a button that looks like a screen or two screens and that should make the display external. good luck
Feb 07, 2008 | Acer Aspire 5102WLMi Notebook
Acer Aspire One 532h2298 Netbook Logo
121 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
