Question about Craftsman Saws
I have an old Sears Craftsman 7" Electric Handsaw model #315.27782. The blade I use for fine sawing has begun to wobble. I've taken it off, put it back on and tightened it several times. Same wobble. I'm thinking new blade. My dad - who gave me the saw - says it's not the blade. Suggestions to stop the wobble?
    Problem Solver:
  • 7 Answers
I am not real sure about how this saw is put together, I am looking for a breakdown, but in most saws when they get a wobble its the bearing on the spindle shaft. If you still need an answer come to my page phoenixrepair.org and let me know. I will try to find out if that parts are available.
Posted on Oct 19, 2010
  • 395 Answers
It could be that the bearings that support the shaft that holds the blade are worn, allowing the shaft to move slightly and make the blade wobble. As the machine is an older model, I would try replacing the bearings.
Posted on Sep 17, 2010
How to change electric cord on Sears Band saw
You should check the manual of your band saw. Or just call the manufacturer directly.
Apr 17, 2013 | Olson Bandsaw Blade 57 56-7/8 Inch 1/4 X...
My Craftsman 7&1/4 inch 12 amp Circular Saw(Model 315.108330) slips while cutting. The motor keeps spinning but the saw stops rotating. Can I Fix it?
Most circular 7-1/4 saws have a bolt and a compression washer that acts as a brake shoe that holds the blade secure but under dire circumstances will allow the blade to slip some rather than hold the motor shaft and allow burn out. The compression washer under your bolt has become worn and doesn't grip the blade securely. You can find a split washer that will fit under the blade and give you some more friction, or go to sears and order another compression washer for your saw.In the Sears Parts List found at: http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Saw-Parts/Model-32018780/0247/0744410/50035950/00001?blt=06&prst=&shdMod=
see part no. 44
Feb 23, 2011 | Craftsman Evolv 12 Amp 7-in Circular Saw -...
Cannot tighten blade on old craftsman circular saw.bolt turns blade shaft and motor without tighting blade
Is the washer/spacer in the blade too thick and you are perhaps tightening up on that instead of the blade. Also check the threads on the bolt, see if the bolt turns all the way in without the blade in position. It may be jamming up before gripping the blade.
Jan 24, 2011 | Sears Craftsman 7-1/4 in. Circular Saw...
Have an older Sears Craftsman 10" Table Saw, model
you should be able to order one from sears. another place to look is ebay. the round plastic thing is to mark with pencil the cut of the blade. put in your sliding miter Gage set at 90 deg. put a piece of wood on it, push forward and cut the wood then slide back and mark the wood position on the plastic. that's the point where your blade cuts
Dec 30, 2010 | Craftsman Saws
Need substitute switch part for sears saw
Sorry , but go buy a new saw. Your not going to find an aftermarket
dealer that carries this switch.
Trying to rig some other switch is not worth the trouble over buying a new one. If the switch is not available, then the saw is old.
New
Craftsman Evolv 12 Amp 7-in Circular Saw 35.00 dollars.
Feb 15, 2010 | Sears Craftsman 7-1/4 in. Circular Saw...
14'' Sears craftsman bandsaw blade slips off, not much power
It sounds to me like the blade has stretched which the do in changing temperatures.
Try replacing the blade before you give up altogether. i was having the same problem with a Ryobi Blade would come off whenever i tried to cut a pice of 3 ply. I eventually replaced the blade and all ny troubles evaporated.
Aug 29, 2009 | Saws
Where can I get manual for model 358.355061 craftsman chainsaw ?
please tell us about the make(manufacturing company) of that machine,
Aug 07, 2009 | Garden
Saws Logo
416 people viewed this question
Top Craftsman Saws Experts
Mike
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
