Question about Cameras
I'm troubleshooting the Kodak Ektasound 130 film camera. Motor does not run. I have taken the cover off to check the belt, it is OK. ckecked batteries and contacts, they are OK as well. What to do?
  • NJBob43 May 18, 2008
    For those that tell me to check the batteries read my post again. And, no, the camera has not been dropped.
    johnychel, mentions the "sliding region", what exatly is that?
    Sergeant:
    Champion:
  • 304 Answers
may i add;
make sure that the camera battery was fully charged, it is possible it stop workin cause of the unit ws dropped,.
did the camera still got a power..?
`jack
Posted on May 18, 2008
    President:
  • 1,257 Answers
I tried my level best to search for the repairing guide to help you resolve the issue ,but didn't succeed but i got the solution for you ,you can use the link below to purchase repair guide for your Kodak Ektasound 130 film camera..
Link : http://www.craigcamera.com/lit_kodakrepair.htm
Posted on May 17, 2008
  • 796 Answers
Check the sliding region..
there may be some dirt blocking it to open...
    Brigadier General:
  • Cameras Master
  • 3,614 Answers
Have you try to charge again the battery..?
  • micromaster
    micromaster May 17, 2008
    any incidents happen to the camera before you have the problem.. did you dropped it or any..
Threading and showing the film
Usaly means that drive rubber bands have gone bad, Very hard parts to find anymore.
Nov 15, 2014 | Kodak Vintage 8mm Eastman Movie Projector...
Manual for kodak ektasound moviedeck projector 275
Check with www.micro-tools.com for parts and manuals!! They have an amazing inventory of classic Kodak parts for slide & movie projectors! Good Luck !! Jim
Jun 05, 2012 | Kodak Vintage Ektasound Moveideck 265...
Kodak P850: Pressing the shutter button turns camera off
This problem is frequently due to corroded battery terminals inside the camera. Remove the batteries and wipe the terminals with a soft cloth (heavy corrosion may require a fine wire brush, steel wool, or sandpaper). Remove any residue left in the camera by the cleaning. Clean the terminals on the batteries in the same manner, and then replace them in the camera. This cures most problems, but if it doesn't work for you, check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
It uses a simple Q&A format to diagnose problems and propose solutions.
Aug 03, 2009 | Kodak EasyShare P850 Digital Camera
Kodak v1073 lens cover won't open when camera is turned on
Remove the batteries and clean the battery contacts inside the camera with a soft cloth (a heavy buildup on the contacts may require cleaning with a fine wire brush, steel wool, or sandpaper). Remove any residue that the cleaning leaves in the camera, and then reinstall the batteries. This clears most power-on problems, but if yours persists, check the Kodak troubleshooting guide at:
Jul 26, 2009 | Kodak EasyShare V1073 Digital Camera
Fuji 35mm Camera (Model DL-400)
Dawn
remove the battery and check that it is good. replace battery and open back door, close the door and it should run the motor / transport. if so, load film up to the drive sprocket being sure film will catch on the sprocket.
or move the latch holding back cover, and open the door fully. check the pressure plate on the door, gently pull the plate up a little to increase pressure on the film. bring the holding lever out toward the latch and close the door to lock the lever back to position.
Jun 11, 2008 | Fuji Discovery 185 Zoom 35mm Point and...
Frozen?!
it locked up
although it may not sound safe, the only way to resolve or at least check camera condition further is to do a powercycle
remove the battery and card, wait for 10 seconds and but back the battery only - turn on the camera, check performance through internal and if ok, try it with the card
if not, go to www.kodak.com/go/itg for troubleshooting or repair
Feb 13, 2008 | Kodak EasyShare V610 Digital Camera
Problems with camera display on kodak APS (something or other......)
I am having exactly the same problem (I have a T550). On the last film I shot, the only way to advance the film was to pull the battery out and re-insert it every time. When I printed that film, all the frames are blank! Kodak's FAQ about "clearing the logic" suggests a solution for that problem. 1. Turn camera off 2. Pull battery out 3. Turn camera on 4. Click the shutter approximately 6 times 5. Turn camer off 6. Repeat step 4 7. Reinstall battery I just tried that but the problem persists. I am now going to leave the battery out for several hours; maybe this will help. Otherwise, well it is time to bite the bullet and buy a digital !
Jun 21, 2007 | Kodak Advantix T550 Auto Focus APS Point...
Cameras Logo
142 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
