Question about Rancilio Silvia Espresso Machine
When running the machine for a shot of espresso I get water leaking into it. It's a Rancilio Silvia, this occurs with every shot. All I've done is clean the machine.
  • 26 Answers
Time for a new group head gasket and probably all the recommended preventative maintenance.
Mike mike@espressomachineexperts.com
Posted on Sep 22, 2010
Rancilio Silvia is leaking from behind the front panel when brewing stops
There is a discharge tube for the brew solenoid there, if leaking constantly there is a problem, if only small amount of water after brewing a coffee not a big problem.
Feb 01, 2015 | Rancilio Silvia Espresso Machine
No Hot Water
Sounds like your Rancilio needs a service, this problem could be caused by the boiler not working correctly, possibly a leak from the boiler or a valve malfunction causing a drop in pressure.
Mar 17, 2008 | Rancilio Silvia Espresso Machine
What is wrong with my silvia? No coffee or water, but steam ok. Loud burring noise
Hi There,
Your coffee group is blocked, with lime or coffee oils.
Try descaling 1st Pulycaf coffee machine descaler . You will find descaler and cleaner in this rancilio silvia kit. Rancilio Silvia gasket kit . Descaling should be done every 3 months or so.
If the descaler does not work - you may have to remove the solenoid valve and descale that - not an easy fix. Takes 20 min.
May 29, 2014 | Rancilio Silvia Espresso Machine
I have a Rancilio Silvia around 5 years old. After around a year, it stopped reliably producing dry steam. I have very hard water, but despite regular vinegar cleaning, cannot seem to get it to steam
I work on industrial machines have done so for 15yrs
if your machine is anything like the prof rigs in terms of engineered design then what you are noticing is the pressure release valve working-letting any unused and pressure + water drain from the group head to a small plastic black box below the stainless housing panels/drip tray after extraction is complete.
What i describe should only happen after the shot stopped.
you should hear it and see it the water for about 2seconds after you stop the extraction manually/automatically
Dec 30, 2013 | Rancilio Silvia Espresso Machine
I've looked up and read many of the pump problem responses and none of them seem to match my issue. Yesterday my Rancilio Silvia worked just fine. I first want to say that I clean my grouphead often...
Typically when this issue has occurred it is the pump. The pump may still run but there is no suction. This is normal once it fails. There really isn't much else in the machine for this to happen. It's rather simple inside.
Jun 04, 2011 | Rancilio Silvia Espresso Machine
Hi, I purchased Rancilio Silvia v3. I have overflow of water in water tank. What happens and how can I fix? Thank you.
There is a max fill line mark on the side of the water tank. Fill the water to there or less. Do not fill the water any higher than this line or water will spill out the side where the water inlet hoses run. Also make sure that the tank is not cracked and leaking water.
Apr 26, 2011 | Rancilio Silvia Espresso Machine
On my rancilio silvia, 3 way valve not whooshing anymore. Water temperature seems low- around 180* at highest.
There are two thermostats, one for water, one for steam. Replace the one for water. You can get the themostat here
Rancilio Silvia Parts
Dec 06, 2010 | Rancilio Silvia Espresso Machine
Rancilio Silvia - Water coming from behind into the drip tray when pouring a shot.
Correct
When you are finished and turn the pump off, the 3 way valve opens and relieves the pressure in the brew head so you don't get an explosion of coffee when you remove the portafilter.
Oct 26, 2010 | Rancilio Silvia Espresso Machine
Rancilio Silvia Espresso water flows too quickly about 7 seconds
  1. check the coffe filter>> it could be teard up and leaking(check it carefuly it is hard to see sometimes)
  2. check the pressure you get from group. 7 - 9 bar pressure you should get to handle. if it is biger than check by pas valve and adjust the pressure, also check up boiler security valve(security valve for water for coffee)
Feb 09, 2009 | Rancilio Silvia Espresso Machine
Rancilio Silvia Espresso Machine Logo
392 people viewed this question
Top Rancilio Coffee Makers & Espresso Machines Experts
vilhj
Level 1 Expert
andy just round the...
Level 1 Expert
Are you a Rancilio Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
