Question about Magic Chef Refrigerators
MCBR1010W light on, no cooling in freezer or refrigerator. Diagnostics?
  • 2,272 Answers
First check the temperature control knob in both the freezer as well as refrigerator section.Is the temperature control knob properly adjusted towards cooling or not.Get it confirmed first. The temperature control is located on the top left hand corner of the refrigerator compartment.Adjust the temperature control knob to "MAX".-------"MIN" the warmest to "MAX" the coldest.--------Your refrigerator has one control for regulating the temperature in the freezer compartment. The temperature control is located on the center of the freezer compartment's interior back panel.Adjust this also to the max.Let it remain in max for 2 hours.Then check. ------------------- Temperature inside the refrigerator is too warm:----------Temperature control is set too warm. Turn the control to a cooler setting and allow several hours for the temperature to stabilize. Door is kept open too long or is opened too frequently. Warm air enters the refrigerator every time the door is opened. Open the door less often. The door is not closed completely. The door gasket does not seal properly. A large amount of warm or hot food might have been stored recently. Wait until the refrigerator has had a chance to reach its selected temperature. The refrigerator has recently been disconnected for a period of time. 4 hours are required for the refrigerator to cool down completely. ------------------- If still the same problem then this is related to blocked drain line in the unit so the defrost is not working and this is causing the problem,or other possibility is faulty control board.
You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation
Posted on Sep 16, 2010
Kenmore bottom freezer refrigerator 795.79004.905. Refrigerator not cooling.
Not an easy refrigerator to diagnose but here is a link to a Service Manual=> HERE Go to pages 21 through 23 and try to do the diagnostics. The problem could be several things including a defrost failure. Otherwise you will need to get a technician out to help you resolve this. I will try to help you should you need ask.
Appliance 911
Oct 06, 2015 | Kenmore Refrigerators
My refrigerator quit working. I replaced the thermostat. now my freezer works but my refrigerator doesn't both fans come on
Ok . First diagnostics. Here a link defining how to do that task directly. Refrigerator Control Board 12784415 Diagnostics . This site has excellent supporting videos and data.
Then the manual Free Online WHIRLPOOL REFRIGERATOR Repair Manual ..
At the moment you pinpoint the suggested codes to examine. Happy hunting. Fare. Well.
Jul 27, 2014 | Whirlpool Refrigerators
Mcbr1010w not cooling
Do you see any ice buildup on the back wall of the freezer or behind it?
Nov 05, 2012 | Refrigerators
Refrigerator not cold but freezer freezing
The first thing you want to do is open the freezer and see if the fan inside there is running. The reason is the freezer cools the refrigerator side by circulating air from the freezer. If the fan is running then your problem is one or more parts of the defrost system is malfunctioned and in return your problem arises. There are three parts to the system, the defrost timer or in some cases control board, defrost thermostat also known as a bi-metal, and the defrost heater. The defrost system is set up to operate as so. The defrost timer or control board will turn the machine off, in some cases every 8 hours, some 12. During this time period the defrost heaters, located behind the freezer wall and rest underneath the evaporator, yet wires to them run up the side of it, are energized and emit heat that raises upward to melt the ice that has formed on the evaporator coils. The bi-metal or defrost thermostat is at the top of the evaporator. When the heat from the heater starts to reach the bi-metal, it breaks the circuit turning the heater off. The whole purpose of this is because the freezer cool the refridgerator side by drawing air across the coils and blowing to the other side via the evap fan motor. In my opinion, if you change one part of the defrost system change them all because usually when one part fails another will follow, so save yourself the time and the food loss, the cost difference is minute.
Jun 16, 2012 | Magic Chef Refrigerators
My magic chef model MCBR1010W refrigerator went room temperature but the light coes on. When I unplugged it overnight and plugged it in the next morning it started to work. I want to try cleaning the coils...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 09, 2011 | Magic Chef Refrigerators
Magic chef ref. m# MCBR1010W Runs contenuly of course the warranty just ran out. Please help if you can on SS.
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Mar 29, 2011 | Magic Chef Refrigerators
I awoke this morning to find our Magic Chef model MCBR1010W (only about 2 1/2 yrs. old) has just stopped running completely - fridge & freezer warm, everything melted, not even making a sound. we just...
heatman101
Mar 27, 2011 | Refrigerators
Defrost timer might not be working
The timer is located behind the fridge , down by the compressor .
Aug 23, 2009 | Magic Chef CTB1821AR Top Freezer...
Magic chief frig mcbr1010w defrost timer help squence of operatio
The solution to all of the above problems. Disconnect the blue wire from the timer and connect a wire from the white neutral to #1 pin on the timer. As shown the timer operates thru the defrost bimetal
Jul 31, 2009 | Magic Chef CTB1821AR Top Freezer...
Refrigerators Logo
99 people viewed this question
Top Magic Chef Refrigerators Experts
evans_lloyd
Level 1 Expert
John Tripp
John Tripp
Lawrence Oravetz
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
