Question about Estate Washing Machines
Washer stopped with water still in it. it doesn't make any noise
  • Estate Master
  • 43,501 Answers
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Sep 16, 2010
My Whirlpool Ultimate Care II Washer doesn't stop filling with water
If this only happens when the machine is turned on,the tube from the tub to the water level switch is pinched or broken. If the clear plastic tube is not pinched or broken,the water level switch in the control console is bad. If the machine lets water through when it is in the OFF position,the water valve where the hoses connect are bad.
Dec 27, 2012 | Whirlpool Ultimate Care II LSQ9564J Top...
Maytag Neptune TL washer doesn't stop adding water
it sounds like your drain hose is to low it needs to be 3 feet high if its to low this will cause the water to syphon out and keep refilling
Nov 22, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Doesn't spin fast enough to remove water from tub. makes a steady noise that doesn't get louder or softer just stays steady
HI,
Check back of washe with a flashlight for a bent or clogged drain hose. Do not move washer to check it. When you move it , it will straighten out and you will never know if it was bent
Also while it is pumping , pick up end of drain hose at drain and observe the volume of water being pumped.
If no water then the Pump may need replaced
Thank you for using fixya
Leo Ponder
Please rate me if this helped
Aug 12, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
When my LG is washing sometimes the FE codes comes up, what does this mean? How can I fix this issue?
This means that the washer is overflowing. This is a built in fault that turns on the drain pump so that the water doesn't get so high that it gets into the floor. If water is continually flowing into the washer you will get this problem. If this is the case the water valve is most likely the problem. To confirm unplug the washer and if the water doesn't stop flowing into the washer the water valve is the problem.
If water isn't continually running into the washer then the problem can be the water level control.
Jun 23, 2011 | LG WM-2277HW Front Load Washer
Hi i have a whirlpool WFS1072AW Front loader 7.5 kg we load the washer as normal press start and then this horible noise comes from the back no water goes in just the noise like gears grinding
Hello Steve.
First off is this a new washer?
If so front load washes ship with retaining plugs / pins in the back. They do this to stablize the drum in shipping so it doesn't get damaged. Check the back and see if this is the case. There should be 4 or so to remove. Also don't throw these out, if you ever need to move you will need them to make sure the washer doesn't get damaged.
Hope this helps.
Good luck
May 02, 2011 | Washing Machines
LG front load washing machine WM2233H Error code is FE
I found this information on the internet. I hope that it helps.
" Getting fe code on lg washer.
"This means that the washer is overflowing. This is a built in fault that turns on the drain pump so that the water doesn't get so high that it gets into the floor. If water is continually flowing into the washer you will get this problem. If this is the case the water valve is most likely the problem. To confirm unplug the washer and if the water doesn't stop flowing into the washer the water valve is the problem.
Thank you,
Shawn"
I hope that this helps you out
Apr 21, 2011 | LG WM2233H Front Load Stacked Washer /...
Screeching noise after water starts going in
Hi just read your posting.Now put the machine to a spin cycle and push start,Does the noise happen in this cycle? If the noise doesn't happen then try a cold water fill but turn the hot tap off first.If the noise still doesn't happen then try a hot water fill but turn the cold water off first. This noise sounds like one of your water valves is faulty.Please reply with additional information on the questions and I am sure we can rectify this fault.
Jul 07, 2010 | Fisher and Paykel GWL11 Top Load Washer
Kenmore Ultra Wash water supply started making loud noise while water is entering washer. If you turn on sink faucet at the same time the noise will stop.
It sounds like the solenoid valves which let in the water are not fully opening and causing chatter -- probably corroded . Turning the washer-water supply faucets down (to the left) will probably stop it, but the solenoid valves need to be checked.
The reason opening the sink faucet stops the noise is that it reduces the water pressure to the washer -- this is the same effect as turning the washer faucets down.
May 05, 2009 | Kenmore Dishwashers
Washing Machines Logo
287 people viewed this question
Top Estate Washing Machines Experts
Dan Webster
Dan Webster
dweatherby
Are you an Estate Washing Machine Expert? Answer questions, earn points and help others
