Question about Sanyo PLC-XT16 Multimedia Projector
When you power up the projector without inputs connected you get a blue screen with 8 white dots (pixels?) appearing in a horizonal line. they stay on the sreen and fill it up when you add an input the screen goes to all "static" you can not see anything any ideas?
  • mccourthouse Sep 17, 2010
    is there any way to just replace the image processer?
    just want to know if i can only replace the image card?
    President:
  • 1,139 Answers
If it is the image processor that is at fault then this will be a surface mounted IC (Intergrated Circuit) on the main circuit board. These are only able to be fitted using professional surface mount machines and you would not be able to do this yourself unless of course you had the machine. Generally I would say that you would not be able to obtain the IC anyway and if you did I would imagine the repair would be hugely expensive and uneconomical to repair. As a last resort take it to an electrical dealer near to you and see if they would look at it for free or for a small charge. They could then confirm what is wrong with it and you would be able to find out for sure if it was worth repairing. Normally projectors tend to be hugely expensive when they require repairing, including maintenance like bulbs and colour filters. Sorry to be the bearer of bad news.
Posted on Sep 17, 2010
  • 2,272 Answers
A lens on a projector is vitally important for the quality of your image.If the lens is got cracked or dirty then the image will be blurry or with statics etc etc. Clean the lens and check.You can use camera lens cleaner liquid to clean the lens and wipe it with dry cotton cloth.Also check internal light lamp.If all checked ok then its problem with internal board. Try to set the projector again to its factory settings.Then check. To get the procedure for how to set.Please click this link directly.And check page number 36,37 for settings. http://www.projectorcentral.com/pdf/projector_manual_2195.pdf ----------- Keep updated.Thanks.
  • raj somaiya
    raj somaiya Sep 17, 2010
    Yes the card can be replaced.But it has to be ordered from sanyo service center.The local online shops are not dealing with cards.
    The parts available for your brand projectors.click this link:--
    http://www.partstore.com/SearchModel/San...
    Thanks for keeping updated with your query.
  • Sanyo Master
  • 11,800 Answers
Those whit screens are parasites (pixels incorrectly commanded) Since they appear white that means the parasites appear in all 3 LCD screen at once, meaning that they are generated by the image processor. The processor is faulty and since it's soldered on the mainboard it must be replaced.
The only place from which you can obtain a mainboard for your model is an authorised repair shop - or a shop attached to a dealer.
Get a quote before sending it to one of them, it 's very possible that the bill will be higher than what the projector is worth.
Posted on Sep 16, 2010
  • Azrael SRL Sep 17, 2010
    There is no separate image board on this projector- only a mainboard with all the electronics and a power source board.
How do i get rid of white dots?
This is a dlp projector and has a bad DMD chip. Most models are very similar. Here is a video of a similar repair.
Feb 07, 2014 | Mitsubishi XD250U-ST DLP Projector
Appearing white pixel dots from infocus in2100 Projector
1,white spots appeared on screen,means the DMD chip is broken,you need a new DMD chip.I supply the DMD chip and the price is USD200
any questions, feel free to contact me
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
have a nice day!
Jerry,Lampdeng Limited
Sep 30, 2013 | InFocus Office Equipment & Supplies
I have nec np200 and there's a lot of dots appeared on the screen. what seems to be a problem
I have 2 NP-200 projectors installed in a school which show white dots on a black background and black dots on a white background. This is caused by the DMD chip losing pixels. Only solution is to replace the chip, I'm researching now if that i an economical solution.
Oct 25, 2012 | NEC NP200 Projector
White dots appears in my screen. I replace the lamp and the problem is the same. (Sharp xr32x)
I would be willing to bet the DMD chip is failing the cheapest used one i seen was on e-bay the chip # will be something like 1076-6319W the only part of the # that matters is the last from what i have seen they tell me the 6318W and 6319W is suppose to be the same chip the used on i seen on e-bay was $124.00 probably better off seeking a new projector if you can not replace yourself as you will have over half of the cost involved hope this helps Robert
Aug 29, 2012 | Sharp "XR-32X-L DLP Projector"
White dots on the screen
Need more info. But initial suspicion is there is a problem with your projector.
Are they stationary and always in the same position? You may have bad pixels.
Are the dots there with no signal going to the projector?
What is connected the the projector? Detail the video path - try all the sources. The dots still there and in the same position on all sources?
It is probably your projector.
If some of your sources are fine - the problem might be from a connected source.
Hope this helps.
Aug 26, 2012 | Acer X1160 DLP Data Projector, 2,000 ANSI,...
Small white dots all over the screen. Looks like dust
If the dots cant be blown off the lens, or appear rectangular in shape when looked at close up, then you have pixel failure. If so, then the DMD chip probably needs replacing.
Jul 29, 2011 | ViewSonic PJD6211 Projector
I have a Optoma HD 67 projector and suddenly it has a lot of white spots on the screen, even if you remove the input cable the white spots stay there
as greg instruction, it is very detail,
usually, white dots problem is reason of the DMD. perhaps the manufcaturer can't directly and singly sell a parts for end user, they always let you send broken machine to their repair store, then ask for high repair cost.
actually, optoma HD67 projector with 1280*720 pixels, so i think you should buy a 1272-6038B DMD chips, if you need further help, please freely contact me again,
Jul 28, 2011 | Optoma Office Equipment & Supplies
White dots appear on screen
As before, pixel problems are appearing
Jun 13, 2011 | ViewSonic PJD6221 3D DLP Projector
Dots appearing on the display screen
if these are pixel shaped dots then the DMD chip is most likely faulty
Apr 11, 2011 | BenQ MP622 DLP Projector XGA 2000:1...
VT45 Projector: Blue pixels throughout screen
If the problem is what I describe as a blue haze over the entire image projected, I was told this is a defect in the cable - we have a Dell Video Projector 2300 - and it takes only a dell VGA cable.
So, the problem is in the cable - solution is replace cable.
Feb 28, 2007 | NEC VT45LPK Projector Lamp for VT45
Sanyo PLC-XT16 Multimedia Projector Logo
152 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
Electro Med Services...
k24674
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
