Question about Bosch Dishwashers
Bosch Diswasher shu 4000 power light works intermittently
    Sergeant:
    Champion:
  • 304 Answers
make sure that the door of the unit was firmly close..& check for any problem @ the pump, & the levelling switch.
Post back again, & please add any other info that will help..
`jack
Posted on May 18, 2008
  • 3,037 Answers
Alright I understand the exact product but I don't understand the question all so well. Power light? Works intermittently? Can you please explain this a little better. As specific as we can, by helping me understand, I can better assist you to fix this problem. thanks
Posted on May 17, 2008
  • Benjamin Patri
    Benjamin Patri May 17, 2008
    There may be a loose connection some where if the dishwasher doesn't always have power but please explain your situation a little more and I could point you to a better cause of what is happening.
  • Benjamin Patri
    Benjamin Patri May 22, 2008
    Please update me on this situation
    Brigadier General:
  • 3,614 Answers
Please add more information about the problem..
thank you
  • micromaster
    micromaster May 17, 2008
    -any error codes, & any other signs of system malfunction..
  • Bosch Master
  • 19,396 Answers
Check the contacts at the back of the lights, it may be a contact problem, or a problem with the control board
  • Ginko
    Ginko May 17, 2008
    You also get flashing light and cycle do not proceed to rinse if no water is coming to the dishwasher, check that water supply is opened and that water is dispensed to the dishwasher, ensure also that door is closing properly.
  • Ginko
    Ginko May 17, 2008
    Here is the
    user manualfor reference
I have a SHU5305us/u12 and my front door lettering got erase. anyone have a picture or a manual that tells me what each button means.
Cycle Interruption
As a safety feature the dishwasher will automatically turn itself off whenever the door is opened. However, if the door is opened quickly while in a wash or rinse cycle some water may splash out of the dishwasher. For this reason it is recommended that the machine always be switched off before opening the door.
To Interrupt a Cycle
1. Press the on/off button to stop operation.
2. Wait at least 10 seconds (or until the water noises stop) before opening the door.
To Resume a Cycle
1. SHU/SHI models, close the door and press the on/off button.
2. SHV models, push the on/off button and close the door.
Changing a Cycle
For Bosch dishwasher models SHI 6800 and 4320, SHU 5300, 5310 and 6800 press the program button of the desired cycle TWICE. For all other Bosch dishwasher models, press the program button of the desired cycle ONCE. The chosen cycle button (or the light above it) becomes illuminated, showing that it has been selected.
* SHU 3030 and SHU 3130 models do not have program lights.
Cancelling a Cycle
Each control panel shows which buttons to simultaneously push to cancel a cycle. Refer to your dishwasher to find the cancel drain buttons on your particular model.
1. Press the indicated buttons at the same time and hold for approximately 3 seconds.
2. When the drain pump noises stop and the LED display or clean light indicate that the end of the cycle has been reached, the dish
washer is reset.
3. Press the on/off button to turn the dishwasher off.
4. The dishwasher is now ready to run a selected cycle. Add more detergent if necessary.
Dado
Oct 05, 2015 | Bosch Dishwashers
Bosch SHU3300 won't run
check your control module.
Thanks
Sergio
Mar 03, 2008 | Bosch 24 in. SHU5305UC Built-in Dishwasher
No control panel lights on Bosch SGV43A03GB/17 diswasher
i have nearly the same problem ! but my one have no water left in it !but pump still running if i put bucket of water in it will drain it away but no lights on panel and anyone know what that is please ?
May 14, 2012 | Bosch 24 in. SGV43A03 Built-In Dishwasher
My Bosch dishwasher stays running in the wash cycle, will not shut down or dry and sanitize the dishes.Checking the fault codes both the power scrub and the reg wash lights flash. Model SHU33A02UC
A solution to this problem would be to sell me your dishwasher. The law firm for which I work is looking to acquire an old unrepaired Bosch SHU 33 dishwasher for some ongoing litigation. If you (or anyone else with this model Bosch) could send me some details regarding your dishwasher, you may be able simply to buy a whole new dishwasher. My email is JFraser -at- jshlawmi.com.
Thanks!
Aug 10, 2010 | Bosch 24 in. SHX33A02 / SHX33A06...
Bosch SHU 8805 upper arm is getting no water.
replace the upper water arm conduit and wash arm hub as they leak under years of pressure and the o-rings leak water and then it can't hold pressure and supply the upper arm with full pressure water,also replace the center arm conduit if it has one as this will wear out too
Mar 23, 2010 | Bosch 23 in. SHU 8805 Built-in Dishwasher
Bosch 4000 tablesaw won't start. Brushes replaced
I found that the remaining problem was a intermittent at the switch, which disassembly and cleaning resolved.
Tilting the motor / blade assembly down allows access from below, to the 3 screws fastening the controller circuit board cover on the brush end of the motor. From there, one can easily test exposed wires for power supply, see that brushes are contacting and clean accumulated sawdust.
Jan 06, 2010 | Bosch Electric Table Saws
Burning plastic smell, big flash & now its dead - Bosch SHU8805UC
remove the water and, the burnt plastic that probanly melted on the dish drying heater coil
close and, lock the door turn the dishwasher back on and, reset the circuit breaker to see if the motor will run or, is damaged
Jul 01, 2009 | Bosch 23 in. SHU 8805 Built-in Dishwasher
Bosch dishwasher still some soap left on dishes
Most of the causes of the problem that you are describing are related to the way the dishes are loaded in the unit. To test this, run it empty and see if the dish soap dissipates.
Mar 17, 2017 | Bosch SHU3305 Dishwasher
Dishwashers Logo
130 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
