Question about Ariston Technologies LL64WNA Built-in Dishwasher
Dishwasher trips out electric - Ariston Technologies LL64WNA Built-in Dishwasher
  • Ariston Tech... Master
  • 43,501 Answers
Either you have a bad motor or there is a short from a wire that rubbed through or the heating element is shorting out..
First guess would be the motor...
Check the motor with an ohm meter...if that is good then go from there...
heatman101
Posted on Sep 16, 2010
Dishwasher is 'tripping' electricity to the house fuseboard as soon as water heating begins in any cycle - cannot locate thermostat to test ?
This can be due to the fact that the heaters draw up more current than required and so trips the circuit. it will be important to remove and check the heaters, check if the contactors are faulty that feed supply to the heaters. Also if the trip is a ELCB- then with some leak in the circuit , motor, heaters, the circuit will trip. Hence check the electrical, check the ground on your dishwasher. Use an external ground and check
Apr 15, 2011 | Dishwashers
When we switch the dishwasher on it trips the electricity. It's worked fine for 2 years but now won't work at all and just trips the electricity.
Your dishwasher has a serious electrical safety fault which is causing the protective breaker to trip (although it may have a simple and cheap cause). With all due respect, your question clearly demonstrates that you lack the knowledge and skills to carry out a diagnosis and a safe repair (especially vital for anything which uses water and electricity). Before doing anything else, fully disconnect your machine from the main electricity supply by either unplugging it or for a machine connected to a flex outlet by turning off the wall switch and then removing the fuse.
Sorry, but in this instance you only have two choices: get a qualified dishwasher repair engineer in or replace the machine. Anything else could be lethal.
Oct 08, 2010 | Beko Dishwashers
AEG OKO FAVORIT 6050 trips earth leakge
This is typical of a water leak onto electrical connection OR the electrical element has shorted internaly . Check this with a Ohm meter and itshould show the problem
Dec 20, 2009 | AEG 24 in. Favorit 60830 Free-standing...
Causing electric trip to go off as soon as the dishwasher is switched on
Heating element at bottom of dishwasher cause of "throwing" trip, told this by manager of local electric store where machine was purchased.
Oct 11, 2009 | Creda Dishwashers
Hotpoint Aquarius FDW60 tripping electrics
I had the same problem. found out that the RCD was faulty & needed replaced. now o.k.
Sep 14, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Neff dishwasher trips the electricity
It could be faulty wireing in the dishwasher connection or you could have a leak in the washer causing the wires to get wet. I would have an electrician have a look at it.
Dec 19, 2008 | Neff 24 in. S5456 Built-in Dishwasher
Hotpoint fdw60 trips consumer unit when switch the plug switch
Hi i have hotpoint FDW60 when i swich the plug and the dishwasher starts then you hear the dishwasher filling up it trips my electric in the house.
Jul 19, 2008 | Hotpoint 24 in. FDW60 Free-standing...
HOTPOINT FDW60P DISHWASHER
There is usually a float switch inside the DW body. Usually a polystyrene lump. This may be stuck in the up position, or a pool of water may still exist within the case.
When you say trips the electric - is this your wall MCB or ELCB ? If it is that then there is a major electrical fault on this machine that needs investigation.
Jun 11, 2008 | Zanussi 24 in. DE6744 Free-Standing...
Trip switch
is the dishwasher on its own circut breaker if so whats the size
Mar 17, 2008 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Ariston Technologies LL64WNA Built-in Dishwasher Logo
167 people viewed this question
Top Ariston Technologies Dishwashers Experts
Electro Med Services...
Renee Knafel-Bullock
Are you an Ariston Technologies Dishwasher Expert? Answer questions, earn points and help others
