Question about Nesa Vision NSD-790T Car DVD Player
Eject bottom is not working the cd is stuck onside the DVD player....how can I remove The CD
Take the unit apart and push the disk out by hand is a possible solution and check why it got stuck!!
Posted on Sep 16, 2010
The cd wont eject from cd player in my seat ibiza 1.4 diesel 2010
Open my computer and right click DVD icon and also option show eject and press it.
Open command prompt and type command, like your DVD rom drive name "E" then go to E drive under and type eject Command.
If not solved then i share a link please visit and read it. and follow instruction.
http://www.wikihow.com/Remove-a-Stuck-CD-from-a-Car-CD-Player
Thanks,
Apple Technical Support
Jun 09, 2014 | Computers & Internet
How to get a dvd tray unstuck
There are two ways to open the CD/DVD drive door if the button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD/DVD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD/DVD disc.
If you still having problem opening with the Eject button, then the CD/DVD drive is faulty and needs replacing.
May 19, 2013 | Televison & Video
5disc multiple choice cds stuck in slots how do i
Have a look for a small hole in the front of the CD player - this is the emergency eject button. Find a paper clip, unwind it and then press the paper clip through the hole - the CD should then eject the first CD and you will then be able to eject the others.
Apr 28, 2010 | Blaupunkt IDC-A09 5-Disc CD Changer
Cd is stuck inside how to eject
if there is a tiny hole on front place a paper clip in there it will eject it does on other systems
Apr 16, 2010 | Pioneer CDJ-1000 CD Player
DVD stuck in DVD player
In the rear of the player is a small hole to eject the CD. Straighten a paer clip and push it in the hole to eject the CD.
Dec 22, 2009 | 2006 GMC Yukon Denali
My xbox 360 tray wont stay close how do i fix it
Do you mean the CD tray won't stay closed? If so check the simple things first. The button that you push to open and close the tray is actually a lever that pushes a much smaller button below it. Make sure that your eject button is not stuck down for some reason. Check your cd tray and the bay to make sure nothing got inside that is preventing the cd tray from closing all the way. I believe if something gets in the way the tray will automatically re-open. You can also take some compressed air and blow out the cd tray to remove any debris that may be blocking the tray from closing.
If none of the above simple steps work I believe it boils down to 2 things. 1. An object inside the case or tray that is preventing it from closing all the way or... 2. The eject button is stuck down.
If your comfortable with it you can take apart your xbox case and remove your CD/DVD player and ensure the button works properly. You can do a search on this site or youtube for instructions on how to take the case apart if needed. Once the case is apart the CD/DVD player is easily removed. You will then notice that the switch you press on the outside of the Xbox to open and close the CD/DVD tray is actually a lever that presses a much smaller switch directly on the front of the CD/DVD unit. You can then test your eject switch directly by pressing the button directly with a ball point pen or a pin. If the bay does not open and close properly at this point it may be necessary to replace the CD/DVD player and I do not know if it can be replaced or not. Hope this helps.
Nov 15, 2009 | Microsoft Xbox 360 Console
Cd stuck inside laptop
There is a small hole, usually near the eject button. Unbend a paper clip and carefully push the paper clip into the hole, try to keep it straight. drive should pop right out.
Feb 20, 2009 | Gateway MT3705 Notebook
I have an ACER 3003WLCi notaebook and there is a CD stuck the CD/DVD drive, how do I remeve the CD/DVD Drvie to remove the stuck CD.
Should be a small hole near button to open drive. Carefully take a paperclip and press slightly in hole. Should eject tray and and you can take disc out.
Be sure that power off and battery/power adapter removed.
Hope this helps!
Mar 24, 2008 | Televison & Video
Nesa Vision NSD-790T Car DVD Player Logo
606 people viewed this question
Top Nesa Vision Car Audio & Video Experts
xxxxxx xxx
Are you a Nesa Vision Car Audio and Video Expert? Answer questions, earn points and help others
