Question about Sirius Stiletto 2 Portable Satellite Radio Receiver
The unit picks up the signal fine when it's docked at home, yet when I go to record, the recording shows up in the library but the file is empty when you open it.
  • Kevin Coley Sep 16, 2010
    Has recorded in the past. Works through external speakers
    Yes, it confirmed my thoughts.
    President:
  • 2,777 Answers
So when you listen and record at the same time, does it play in your headphones or through speakers attached? Did it used to record successfully or has it never worked correctly? These things are usually pretty straightforward, if it used to work correctly but now doesn't it may have some internal failure going on, if it never has worked, it almost certainly has a hardware issue.
Let me know and I can help.
Thanks
Tim
Posted on Sep 16, 2010
  • Tim Grayson
    Tim Grayson Sep 16, 2010
    And you are sure you are recording correctly? Well I guess there is no "wrong" way to do it really, as long as it indicates it's recording. It sounds like the internal memory on this unit has failed. Is there any chance it's still under warranty? You unfortunately are going to need to either have it repaired or replaced... If you read around this is more common then you'd think :(. These stiletto 2 units are notorious for failing.
    I am so sorry about that....
    You should try calling Sirius about the repair, I believe they are the ones that handle it 1-888-539-7474
Panasonic DMR-ES25 Trouble setting up to record TV shows
The DMR-ES25 does not have an ATSC tuner; it has an NTSC tuner. See page 54 (Specifications) of the manual at the bottom of the left column (television system). You need to add digital to analog (ATSC to NTSC) OTA converter box between the antenna and the DVD recorder. Next, you will set the converter box to the channel you wish to record and set the DVD recorder to record on a composite input (Line in) or channel 3/4 depending on how you set up the converter box.
The only remaining analog broadcasts are a few low-power stations. Unless you live close to one of these transmitters, your DMR-ES25 will not be able to tune in any channels. Make sure that you find a converter box with composite and/or RF out if you wish to use the DVD recorder. There are some currently available ATSC tuners that have built-in DVR capabilities. These might also work for you. However, many of the cheap units fail quickly.
I hope this helps.
Mar 06, 2017 | Televison & Video
JVC Hard Disk Camcorder (Everio) GZ-MG155U, after break in file management, came out of it showing no recorded material (I had 6 hours of material recorded on it at the time) and though the on-screen...
Try to connect first the Camera to your computer and check if there's any file inside it and see if you will be able to find that recording if not you can try to download a datarecovery software on the internet or just take this Camera to a data recovery center near you and let them do the recovery of the recording....
Hope that helps........
Jul 02, 2008 | JVC Cameras
No Signal from Tv
Yes I beleave it is cabable of recording your tv, one moment.
Apr 20, 2008 | Samsung DVD-VR357
For my jvc sr-dvm600 the record times for DVD for all record modes seem to be set to just minutes instead of hours. How do I adjust those. The DVD recorder quits after just two minutes.
Your HD is full, I had the same problem, even if you think its empty or it shows empty the "library" record function is recording it to the library. to delete you have to be in dvd mode, not hd mode, press edit, hi-light and delete one at a time. to stop this in the future, just shut off library mode in the setup menu. I had deleted my hd in hd mode and them found out that everything was backed up in my recycly bin from day 1 and had to manually delete in dvd mode even though its not on the dvd, weird. figured it out tonight and I was going to send in for repair tomorrow. hope this helps
Dave
Nov 17, 2010 | JVC SR-DVM600
My Stilletto 10 doesn't reliably record programmed talk shows. I leave it on and plugged into my car kit (yes, it is powered by a plug that stays on when the car is off) and when I come back it is...
Is it set for auto shut down? It took me months to properly record with this thing, frustrating at best. Now it's almost flawless. Go in to menu then settings then dock. In that menu you will see "Auto Shutdown". If this is on, your receiver will shut off after 4 hours only when plugged into the car dock. When on a home dock it will stay on. Turn this off and it will stay on until you shut down. Auto shutdown is the default setting. If for some reason you receiver is reset, you will need to check this setting again, because it will turn auto shutdown on again. Hope this helps.
Jul 17, 2009 | Sirius STILETTO 100 MP3 Player
Dvr docking station
I had the problem that the record feature was not available in or out of the docking station and therefore i could not record. Archos connector on bottom of unit senses a change in the resistance of the device it's docked with and knows if it's the DVR station or not.
Turned out to be a hardware fault - i had to RMA both the Archos and the docking station (while in warranty) and Archos fixed it/them.
That may not help you much.
PS: I think i zapped my DVR station with static one day and that might have been the original cause.
Dec 31, 2008 | Archos 604 WiFi Digital Media Player
Panasonic DVD Recorder - Digital tuner stopped working
Is your recorder hooked up to the new convert box for digital antenna reception?
I am currently researching the convert boxes for my dvd recorder. I found that some dvd recorders already have digital converter boxes already installed. This might be the case for you.
Mar 08, 2008 | Panasonic DMR-EX85EB-S DVD Recorder/HDD...
Records snow/static - intermittently
Intermittent problems like this really suck.
I have a simular problem on my Toshiba DVD recorder. Once in a while it just doesn't record anything at all.
Unfortunately, there really is no solution. It sounds like a glitch in the unit to me. Wether or not it's present in all the units of that model or just yours, only Panasonic knows for sure.
Feb 14, 2008 | Panasonic DMR-ES40VS DVD Recorder/VCR
Line in
You need a device that does not come supplied with the player.
Making LINE-IN recordings
Line-in recordings are used to record music tracks in digital format directly from an external player.
1. Connect an external player (like a portable CD player or a stereo system) to your player via the docking
cradle. (this is an optional accessory which is not supplied with your player)
2. Insert one end of the audio cable to the line-out connection on the cradle and the other end to the device
you want to record from.
3. Go to the main menu of your player and select Recordings > Start LINE-IN recording.
4. A message Connect line-in will be displayed.
5. Press 2 to start line-in recording, at the same time, start the playback on the device you want to record from.
6. Press 1 to stop recording.
7. Your line-in recording will be saved on your player as a PCM file (.wav extension). You can find this file
under Recordings > Recordings library > Line-in recordings.
-Tha Mp3 Doctor
Aug 17, 2007 | Philips GoGear HDD6330 MP3 Player
Sirius Stiletto 2 Portable Satellite Radio Receiver Logo
100 people viewed this question
Top Sirius Audio Players & Recorders Experts
John
John
Steve
Scott Thompson
Are you a Sirius Audio Player and Recorder Expert? Answer questions, earn points and help others
