Question about Toshiba 14AF42 14" TV
I got a used Toshiba 14AF42. No remote. I have a universal remote but I cannot switch to from TV to Video inputs. The remote does everything else but that. How can I switch inputs without the Toshiba Remote?
satscoop
  • 59 Answers
SOURCE: InputChannel without remote
Yes and no depends on the TV if you have a menu button press it and go to autoprogram and let it find all the channels then press channel down until you get to channel 1 then press it again and it should start cycling through aux inputs.sometimes TVs dont have a menu button and this is not possible.try simply pressing channel down until you get to channel 1 then maybe it will cycle through your inputs.Please rate me if this helps.
Posted on Nov 16, 2007
SOURCE: Input Selection without a Remote
try with the channel 00.Good luck
Posted on May 25, 2008
likha
  • 790 Answers
SOURCE: i need to switch my tv to input without a remote
Hi
please use the menu button in your front panel then search the video, Air, or Cable selection!
Thanks!
Posted on Apr 10, 2009
  • 65 Answers
SOURCE: Programing universal remote for Toshiba TV
code numbers are,018,021,023,071,085,090, or go to www.replacementremotes.com Ted10
Posted on Apr 14, 2009
lilmikew99
  • 122 Answers
SOURCE: I can't switch to aux/video without my remote.
not really sure about this but if you put a disk in then run auto scan for your channels,long shot but worth a try.
Posted on May 11, 2009
I have a toshiba 32a14 TV and an Auvio universal remote. I can get the remote to turn the TV on and off but I can't get it to change the input to the TV
Tv universal remote have it limted to it used and operations,only operate the basic only like power on/off and channels up/down also volume up/down that about it.The tv input video 1 or 2 for IN tv to used are tv personal funcstions only for the tv original remote control only have it functions for.Try the website Remotes.com to buy the tv original remote.
Aug 24, 2011 | Toshiba 32A14 TV
Toshiba 27a45
yes a universal remote will work but you may need to try several to find one that will, not all work to select your inputs. first try changeing the channel below channel 2, thats were most tv inputs are located (accessed)..
Jul 20, 2009 | Toshiba 27A45 27" TV
Switch Toshiba projection tv to receive input from video-1?
jbrowne_usa
If your DISH remote is programmed to your Toshiba TV, you can press the TV button at the top left of the remote and then release. This will put the remote in TV mode. Press and release the TV/Video button just below the clear TV button. This will cycle through the inputs on your TV. Continue to press and release until you have Video-1 displayed on your TV screen. I hope this helps.
Ray Calo
DISH Network
Jun 14, 2009 | DISH Network DVR-625 DTV Receiver /...
Universal remote works for basics but won't change input
Rich,
good day , what button can you see infront of your TV screen?
Not familiar with this model but if you'll manage to locate a button marked as "TV/AV" or "AV" press this button until it the display switch to A/V mode (audio/video). Or if this is a really old model, from Tuner mode or channel model. set the channel station to 1 then press the " - channel " button and see if it will change from tuner mode to A/V mode
cheers,
mark
Jan 31, 2009 | Toshiba 32A33 32" TV
I can't get the channel select to go to av input or video input
A universal remote in most cases can not switch this TV into the AV mode...you can but a orignal replacment remote for your TV At www.remotes.com and then you can use all the functions again!
That will fix ya!
Please rate my response!
Thank You!
Jan 17, 2009 | RCA 32V430T 32" TV
Switching to play video games--how do I do it?
You are going to have to order a origanal remote that came with the TV to do this because the universal remote does not have the game mode feature! Go to www.remotes.com to order yours!
Please rate my answer and help keep this site FREE!
Thank You!
Jan 02, 2009 | RCA Universal Remote Control
Toshiba mo#20af44 hooking up 360 xbox
As far as I'm aware, the only way to switch inputs on the TV is by using the Toshiba remote--there aren't buttons on the TV itself to do it. Which means unfortunately, if nothing on your universal remote will do so and you don't have the Toshiba remote (either to use or to reprogram your universal remote with), you may be out of luck.
Oct 11, 2008 | Toshiba 20AF44 20" TV
Toshiba 24AF44
You need the original remote controller to be able to switch input modes.Universal ones usually don't work. If you don't have the original remote and can't find it ever or if it is too expensive you can buy an rf modulator ( very cheap) and connect your dvd player, game console etc) to the modulator then connect the modulator to your antenna with a coax cable. This worked for me. It placed the connection to channel 4 and other cable channels are still working,
You can buy the RF Modulator from: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=180299245670
Mar 16, 2008 | Toshiba 24AF45 24" TV
Toshiba that uses CT-90040 remote
Is the cable remote a programmable universal? If so, just a matter of finding the codes to reprogram functions.
Concerning the "tuning video", are you saying that you can't get to different input sources?
Oct 15, 2007 | Toshiba 36AF42 36" TV
Toshiba 14AF42 14" TV Logo
174 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
