Question about Sony Playstation 3 (PS3) Console
Internet connection my internet has a strong connection on the Settings and connection status list but poor connection on the network and games
  • 1 more comment
  • SeaDogg69 May 24, 2008
    I'm constantly getting kicked off the server in the middle of games and the lag in the game is bad. I can be shooting someone and it will take an entire mag to kill him. (and I know the difference when I'm hitting someone and when I'm not). Is this a connection problem a broadband speed problem or a bad router problem
  • salazarpete Aug 31, 2008
    ip adress is fond but will not connect to internet
  • scotta01 May 11, 2010
    What is your broadband speeds?
  • 49 Answers
You could be dropping connectivity sometimes you may need to reformat
Posted on May 20, 2008
I Opened a hulu plus account yesterday with the 1 WK trial free how am I able to bring it up on my bluray player ? It says it cannot connect to the internet check network settings & internet connection...
Are you using a wired or wireless network? What you state above says that you are using a wired network, so check your CAT 5 cable is plugged into your blueray player properly.
Mar 05, 2015 | Computers & Internet
Tip
How to set up WiFi on XBOX
To connect the appropriate wireless network adapter to the console. On the Xbox, a Wi-Fi adapter that connects to the Ethernet port (sometimes also called a wireless network bridge) must be used. Alternatively, the Xbox 360 is also designed to work with certain Wi-Fi game adapters that connect to a USB port.
Turn on the console and navigate to the wireless settings screen. On the Xbox, the menu path is "Settings -> Network Settings -> Advanced -> Wireless -> Settings" On the Xbox 360, the menu path is "System -> Network Settings -> Edit Settings."
Set the SSID (network name) on the Xbox to match that of the wireless router. If your wireless router has enabled SSID broadcast, the SSID name should appear pre-selected on the Xbox display. Otherwise, select the "Specify Unlisted Network" option and enter the SSID there.
Specify "Infrastructure" as the Network Mode. (Infrastructure is the mode used by wireless routers.)
Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead. Note that the standard Microsoft Xbox 360 Wireless Network Adapter supports WPA while the standard Microsoft Xbox Wireless Adapter (MN-740) only supports WEP.
Save your settings and verify the network is functional.
On the Xbox, the Wireless Status screen displays whether a connection has successfully been made with the wireless router, and the Connect Status screen displays whether a connection has successfully been made through the Internet to Xbox Live.
On the Xbox 360, use the "Test Xbox Live Connection" option instead. Tips: Even when your wireless connection between the Xbox and the router is working perfectly, you may still experience difficulty connecting to Xbox Live. These issues can be caused by the quality of your Internet connection or the firewall and Network Address Translation (NAT) settings of your wireless router. Additional troubleshooting may be required in these areas to achieve reliable Xbox Live connections.
on Feb 07, 2010 | Video Game Consoles & Games
Unable to connect to the Internet Confirm the Internet settings of the wii console. Error code 50299.
Go to internet options on your Wii settings, select internet, and then connection settings. Once that is done you will be able to see the wifi connection. Click the wifi connection and delete it. Try to reconnect the Wii to your wifi router and you should have success connecting to the internet. If it doesn't connect repeat the steps listed above.
Dec 31, 2014 | Nintendo Wii Console
Error code:101-0502 for wii u any one know what it is ?
Error Code: 101-0502
Situation:
  • A communication error occurred when using the friend list service.
  • What to do:
    • Check our network status information.
    • Review our Network Status page and ensure there are no service notifications related to the Wii U friend list service.
    • Ensure your Wii U is connected online and try again.
    • Test your Wii U console's Internet connection by performing a connection test. If the connection test fails, use the error code provided to troubleshoot your Wii U console's Internet connection. [How to]
    • Enter an alternate DNS into your Wii U connection settings.
    • If there was an issue with the DNS you are using, entering alternate DNS may resolve your issue. [How to]
Oct 12, 2013 | Video Game Consoles & Games
I cannot get the TV to connect to the internet any more. One day it was working and the next it was not. I have rebooted the entire system to factory settings, taken out the power cord, rebooted the...
Error 1106 is an indication that the Domain Name System (DNS) was unable to resolve. Follow the steps to check the Internet connection: 1. Check the Network Connection. 1. Using the supplied remote, press the Home or Menu button. 2. Select Network Setup . 3. Select View Network Status . 4. Select Check Connection . If any of the connection settings fail, verify that the TV is properly connected to an active Internet connection. Follow these steps, if the error continues to appear: 2. Unplug the TV and wait 60 seconds. 3. Power on and off all of the networking equipment, including the modem and router. 4. Allow the Networking equipment to reset after powering them of and on. Test that the connection is active by using a computer. 5. If the issue continues, wait and try viewing the content later.
Sep 18, 2011 | Televison & Video
Im having trouble connecting to internet with aspire one acer wireless net connection status: limited or no connectivity, but shows 54.00 mbps and a strong signal strength, how can i fix this
Is this happening when connecting to your home network or at public wifi sites? Check the network connection icon in the lower right hand part of your screen (called the system tray), right click on that, and it should have a popup that says "connect to a network" click on that, and a list of available networks should be listed. Many public wifi sites are security protected, so make sure you have the appropriate user name and password for the site you're using. If the site is listed, left click on that to highlight it, then click connect at the bottom of the window. That should establish a connection with a local network. If problems persist, download and install a new copy of the network driver software (available from the manufacturer). Good luck!
Dec 22, 2010 | Acer Aspire One PC Notebook
How to hookup wireless internet
SBG900 vs. Playstation 3
You need to create a gaming gateway in the router and assign that gaming IPAddress in the playstation manually in the network setup. All the info you need is in the Connection and Status List. This should be checked while logged onto the internet.
Dec 01, 2009 | Arris SURFboard SBG900 (49402201900) Modem
Dns error 80710102
try mving your ps3 around into verous places around the room and try to find an internet connecion. you can go to settings, network settings, then settings and connection status list and it will show you how much internet you have.
Jan 05, 2009 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
95 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
