Question about Astoria JADA AK SUPER Espresso Machine
Need o- ring for astoria jada - Astoria JADA AK SUPER Espresso Machine
3 Suggested Answers
espressonist
  • 1711 Answers
SOURCE: Hi, I have the astoria jada ak super automatic. I
The drain **** is either blocked or bend or is making a big bend which is blocking water in it a this making dificult for the drain water to flow. Their is also a smal chance the main drain pipe to be blocked so you can try to put the drain hose inside a bucket to check if the water can run through you drain hose
Posted on Feb 13, 2010
z34aga
  • 137 Answers
SOURCE: What are the recommended settings for grinding
it depends what coffees you are using, Arabicas can go in higher temperatures and give you very good performance but in same temperature robustas or mixture of both will give you weaker result.
as guide you should use steam from 1 - to 1.3 kg cm2 pressure of pump 7 - 9 kg cm2
the grinder: 1 turn on grinder 2screw inn the plate until you start to hear metal sound. 3 go back for 4 positions 4 grind small amount coffee for testing 5 A ) if it goes to fast and cream is too white than go more fine 5B ) if it goes to slow = drop by drop than you go to larger grinding 6 repeat this with small amounts until you don't find ideal position.
i hope you will be patient in grinding process and you will go step by step.
Posted on Feb 08, 2011
My 2010 camaro ss from jada toys incorporated's steering doesnt work i need your help
It could be that the servos on your car could be shot. How old is the car?
Apr 03, 2013 | Toys
Replacement blades for Jada Toys Heat Air Command Radio-Controlled Helicopter
Just send $5 to Jada Toys Inc.
ATTN: Parts Department
938 Hatcher Ave
City of Industry, CA 91748
specify what blades you need.
Jan 16, 2013 | Toys
What are the recommended settings for grinding espresso on the astoria jada ak? as well as recommended temp and compression?
Feb 08, 2011 | Astoria JADA AK SUPER Espresso Machine
Feb 06, 2010 | Astoria JADA AK SUPER Espresso Machine
Fault code
On the Jada AK I would first do several wash cycles with the cleaning tablets http://www.kaldi.com/cafe_supplies.htm. These machines need to be kept really clean.
www.kaldi.com
Mar 31, 2009 | Astoria JADA AK SUPER Espresso Machine
I need a new pressure guage for an Astoria A2 - coffee machine
here is the site where you can get your presure gauge and other parts for your machine.http://www.espressoparts.com/results.cgis?catalog=&select=NAME&keywords=astoria+pressure+gauge&image.x=15&image.y=14
Jan 19, 2009 | Astoria Argenta AEP-2 Coffee Maker,...
Astoria JADA AK SUPER Espresso Machine Logo
Top Astoria Coffee Makers & Espresso Machines Experts
Charles T Nevin
Charles T Nevin
J.D. Browning
J.D. Browning
NOEL
NOEL
Are you an Astoria Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
