Question about Liebherr KBES3650 Stainless Steel Refrigerator
Liebherr KBES 3650 - too warm in main fridge compartment. Hi the main fridge compartment of this larder fridge warmer the it should be (milk does not taste as cold as it should). The temp indicator says 4 degrees. The fan does not seem to operate as frequently as it used to and there is thick ice on the back of fridge behind the bio-fresh compartments. Any ideas?
  • Liebherr Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 17, 2010
Our fridge Liebherr KBES 4260, Class SN-T is located in a utility room that is not as warm as the kitchen, but neither is it bitterly cold. During the very cold spell in December and in January it failed...
most modern f/f work in the temperature range +10C to 35C,so if you store it in a room below or above these temps you will incounter problems.before you buy you should check the temp range as in some countries they supply them to operate outside these parameters.i use a greenhouse heater in an outhouse to keep mine warmer than +5C,seems to work okay.
Jan 26, 2011 | Refrigerators
I put milk inside the fridge and before expiration date it smells very bad and is not OK ,please give me soloution .it happened more than 20 times,thanks
If your milk is not keeping then the frdge is too warm....
Turn the control on the fridge a little bit colder each day, till you just start to freeze things...
Then make it just a bit warmer and you will be at he best temperature to keep food the longest...
heatman101
Nov 18, 2010 | Refrigerators
Liebherr frige/freezer switching on/off by itself
its the main board relays on the board on the back panel or just inside the lower area on the left wall near the compressor compartment
Jul 30, 2010 | Refrigerators
Cappuccinatore Milk Temperature on Saeco Royal Pro Machine
Hi
First open it up and run it without any milk attached until just mostly steam is coming thru. Turn off - then drop the tube into a jug of milk which is locted below the outlet. If its steaming, the milk will be heated up ok - it may need flow adjusting - lift the thin 'plug' near the tube up and down to adjust flow. You can add to the froth by lifting the tube out of the milk for a moment then back in again a few times.
To clean the unit just run clean water tru as tho it was milk until it comes out totally clear (about 1/4 cup). For hygiene sake make sure the tube is wiped clean on the outside with a clean paper each and every time when finished.
You can flush your main coffee lines out by making out its doing a large preground coffee - but don't put any preground in.
Select preground - select large coffee and go. Pays also to remove the brew unit and wash in warm water once a week - saves coffee goo building up and causing it to stick.
Feb 21, 2009 | Saeco Royal Professional Espresso Machine
Liebherr larder fridge not working in normal mode
thermostat is faulty - supercool just bypasses the stat
Sep 23, 2008 | Liebherr Refrigerators
Liebherr KBES3650 Stainless Steel Refrigerator Logo
633 people viewed this question
Top Liebherr Refrigerators Experts
Charles T Nevin
Charles T Nevin
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Liebherr Refrigerator Expert? Answer questions, earn points and help others
