Question about Kenmore HE2 Plus Front Load Washer
Something rattles in the washer during the spin cycle. Sounds like a coin or something stuck somewhere but we can't locate it.
  • 58 Answers
First thing I would chek is the drain pump. Something may be stuck inside there.
Posted on Sep 16, 2010
Can I safely use my washer if I hear something metal scraping during spin cycle?
You can, but I wouldn't. The outer skin of the drum is made of plastic. If it is a coin, it could dislodge, get caught again in mid spin and punch a hole straight through the plastic.
Get a flashlight and look between the seal and the outer drum when you open the door.
Jan 24, 2016 | Frigidaire Washing Machines
Whirlpool spin cycle rattling
Well, it just might be. :-) More than likely you have something in your machine basket that is loose. Probably a coin or something from clothes previously dried or washed in the machine. This is quite common, especially for folks who carry coins or loose objects in their pockets. Remove whatever is loose in the basket and you will have solved your problem.
Jan 03, 2015 | Whirlpool Washing Machines
Rattling noise in spin, spin problems becoming more pronounced. control panel lights flash but 0 error codes. unplug 2 reset, probl repeats
If this noise is happening while it's trying to drain water then you have something floating around in the lump. Coins are very common. If the noise is happening during a spin cycle and more pronounced during the final high spin cycle, you have bearing or spin tub issues. Time to go shopping.
Nov 07, 2013 | Frigidaire ATF6000ES Front Load Washer
Bosche axxis washer spin cycle ticking noise
Assuming everything else is working normally, I would still suspect there is an object that is getting stuck between the rotating drum and the outer housing. Maybe not coins, but something longer, like a pocket comb or the wire inserts used in some garments. It is easy to take the top off of the unit, and this might help to isolate the noise better. Early spin is usually a bit unbalanced, so it is possible it could also be something really simple like a hose clamp that has sagged enough to be contacting something else, and it only shows up when the machine is bouncing a bit.
Mar 16, 2013 | Bosch Washing Machines
Whirlpool - MOD WTW 6600SW1 SER - CT 4270227 Type 580 For the past several weeks, the washer became progressively louder during the spin cycle and it sounded as if there was something rattling such as...
Sounds like you have change in the pump the coin may be stopping the propeller of the pump not allowing it to pump out the water. you may be able to take the pump off and clean the pump if the propeller is too bad you may need to replace the pump the pump part number is W10049390
Jul 15, 2011 | Whirlpool Washing Machines
Oasis HE elite washer Sounds like coins rattling occasionally during spin cycle.
there are coins or small items in the pump. We used a wet dry vacumn to clean it out thru the drain hose.
Oct 24, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Ge fornt load washer mod #wcvh6260fww the inner drum chatters violently in hi rpm spin-- not to be confused by the entire unit shaking-- the inner drum only
I'm having a similar problem. Mine sounds like there is something behind the drum, like maybe a coin or loose nut? It screeches horribly.
Jul 30, 2009 | GE WSXH208A Front Load Washer
Loud Clicking rattle during spin
you may have something stuck in the pump
pull hoses off pump and see if there is anything stuck in it
Jun 13, 2009 | Admiral AW22 Top Load Washer
Something tumbling around during spin cycle
Yes, a coin can get down into your tub and make a horrible sound during the spin cycle. It has happened to me before. So have your washer checked out.
Jan 19, 2009 | Maytag Neptune MAH5500B Front Load Washer
Something stuck in drum, spinning cycle loud hammering/clacking sound
hi there,
sounds like you may have something caught between the tumbler and the cabinet. since the drum has holes in it, can you have a look if you can see anything that's come of clothing, like a bra wire. it's usually something bigger.
Sep 29, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
232 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
