Question about Maytag Neptune MDG5500AW Gas Dryer
Loud squeak and not staying hot - Maytag Neptune MDG5500AW Gas Dryer
  • Maytag Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Posted on Sep 21, 2010
What do i do for loud squeak when i turn flymo tl400
Loud squeak when turning on is usually low power steering fluid or a water pump going out. If the power steering fluid is fine keep an eye on your temp gauge and make sure it is staying consistent when hot.
Feb 24, 2015 | Cars & Trucks
My dryer is making a very loud squeaking sound when I turn it on. Also inside is very hot within minutes.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Dec 27, 2010 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Whirlpool LEW0050PQ electric dryer makes a noise.
heatman101
sdfhywt4
May 22, 2010 | Whirlpool LEW0050P Electric Dryer
Intense squeaking noise
When microwave is running, turntable squeaking when rotating. Can problem be fixed? Microwave is about twelve years old.
Mar 07, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
My 1992 sl1 saturn was stolen and recovered when I got it back I got it back with a loud squeking noise coming from the serpentine belt area. Sounds like loud crickets and when I accelerate the squeak gets...
It sounds like an idler pully needs replaced. The bearings are going bad. It is not hard to do this, but more than likely that is what it is. You should also replace the belt.
Jun 23, 2009 | Saturn SL1 Cars & Trucks
Squeaks really loud while agitating. Drains great, and works well other wise. Could the belt be going bad?
Could either be the drivebelt slipping or, if an older machine could be the main bearing getting dry.
May 20, 2009 | Washing Machines
Hot Point electric dryer squeaking when in use.
It could be one of the pulleys on the bottom of the drum. Take the top and front panels off of the dryer. Get some WD-40. Now the hard part, there is no easy way, but put your right arm in underneath the drum (the right side of the drum)and spray the pulley the best you can. This is the hardest, but the easiest way to fix this problem, without having to take the entire dryer and drum apart. I had the similar problem. I didn't completely fix the problem, but the squeak has been significantly quieted.
Feb 14, 2009 | Hotpoint NWSR483EBWW Electric Dryer
Dryer body very hot, loud squeking, soot from ball in back
I would replace the high limit control and the thermostat to be on the safe side. There is a real danger of burning the house down.
Nov 25, 2008 | Kenmore 62602 Electric Dryer
Squeak from the back end.
but hoping I could get a little help.I get a very loud squeak from what seems to be the back end of the bike under power. I don't notice it in first gear but 2nd and up I hear the squeak that is very loud. It is not a constant squeak but a jumpy one that seems to match the engine vibrations (as in it seems to squeak every time a cylinder fires) but only under power.I just put on new rubber on the back end last night and I left every guard off and it didn't change assuming that I have guards rubbing and squeaking but apparently not the case.Now what I find to be very interesting is that it is not always there. Case in point: Almost a month ago, I got caught in a pretty good rain storm. It didn't squeak again until I washed it. After I washed the bike, it never really went away until I ride for a while. Oh yeah, almost forgot to mention that the squeaking never really stays for a whole ride, just the start of it (10-20 minutes?)Is this a symptom of the wheel bearings going or do I have a problem with my belt drive? The bike is a 2003 XB9R and I know that there have been problems with the belt on some (not being strong enough) but from what I can tell, the belt looks imaculate for being 5 years old.Any ideas before I start throwing money at it until it gets figured out?,1. the belt will not squeak, so it's not that. 2. this is hard to figure out online.3. is it while riding constant or during normal/hard acceleration?,,,
Nov 10, 2008 | 2005 Buell Firebolt XB9R
Maytag Neptune MDG5500AW Gas Dryer Logo
46 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
