Question about Philips Magnavox 51MP392H Rear Projection Television
The red colour goes out of the contour several minutes after turning the unit on. It shifts to the right 5 inches. Any technical advice? I do electronics, but no experience at all in rear projection. Thanks!
  • Philips Master
  • 5,138 Answers
First you need to try resoldering pinns on the convergence ICs, they are Big Black ICs will have Part number on them example
STK392-110, if that doesnt fix it then replace both of the ICs Mats Electronics has them 1-800-628-1118
Posted on Sep 16, 2010
Transmission shifting problem
has a safety brake feature... you must press brake to move gear selector out of park.. if power booster for brake system is weak... will not come out of park....
Jul 26, 2014 | 1993 Buick LeSabre
Tip
What to do if your ricoh afficio 1022/1027/220/270 show sc542
First of all do not panic as the copier is in auto jammed mode.
Switch off the copier.Here the list you should do as the sc542 revealed your termistor in fuser unit is out of order.
1. Open the lateral door and take out the fuser unit
2. Below the fuser unit , you will see the 2 unit termistor with red plastic contact.
3 Replaced it both with the new one then reinsert the fuser unit in the copier back.
4.Closed the lateral door.
5.Switch on the copier,you should go into sp mode by push yellow[c] button follow by button 1,0,7 then push cancel button[red colour] for several seconds until the screen revealed you are in sp mode.
6. Switch off the copier for 1-2 minutes then switch on.
7. Wa la......it's working back as new
8.By doing this you will save several hundreds dollars by calling the techician isn't it.
Yours sincerely
on Apr 16, 2010 | Office Equipment & Supplies
Fujitsu airon ASTA24LCC 2 flashes green and red then 5 red flashes any idea what it means
Had similar problem (ie. 2 green & red flashed followed by 5 red flashes - Fan blowing but not cooling ... I also noted that the outside unit fan wasn't going). Tried restarting several time after waiting only a minute or two after turning the mains power off but with no change. So turned the unit off at the mains power and then fired it up about 2hrs later and it was all working fine.
Jan 24, 2013 | Fujitsu 24C1 Air Conditioner
After 10 minutes the colour wheel get out of synch and then a few minutes after that there is a crazy squeek and the lamp red indicator turns red light and the unit shuts off. I have opened up the unit...
Hi
Clean the Color wheel sensor thoroughly. a lens cleaning solution might help. be careful.
If problem persists.
Intall a 1" fan throwing air into the vent near height riser stud. into the color wheel chamber. this works.
Jun 13, 2011 | Optoma HD70 DLP Projector
Red Light is on and when you turn it on it goes off to the red light again
This is related to your power supply which is inside possible one of the 2 fuses inside the power supply has gone bad you can replace those if your ok with opening your unit and little soldering otherwise searcdh ebay for ps3 power supply its a silver box looking dervice about 5 x5 inches. easy to put in takes about 30 minutes start to finsih.
May 02, 2010 | Sony Playstation 3 (PS3) Console
Oyen burns everything you put in it
I would say that the thermostat is faulty, and that it needs replacing.
Trust this helps you.
Dec 05, 2009 | Stoves 720EF Electric Double Oven
Contour 1996
Jumper cables have two colored cables. The red one goes from your vehicle positive battery terminal (+) to the other cars positive terminal (+)
The black goes from your negative terminal(-) to the other cars negative terminal (-)
Your car should start within 5 to 10 minutes if you have good connections.
Get your charging system checked to see if your battery is bad, or your car charging system is not working.
Aug 26, 2009 | 1996 Ford Contour
52 rear Projection RCA-Convergence auot cycle not working?
It's late but try unplugging TV from a/c outlet for 5 minutes,if no fix call factory authorized service center. Good Luck, God Bless.
Nov 12, 2007 | RCA P52926 52" Rear Projection Television
Sony KV 25 F3U
TWO Blinks---B+ over current protection (OCP) , unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
Sep 16, 2006 | Sony KV-32S26 32" TV
Philips Magnavox 51MP392H Rear Projection Television Logo
14 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
