Question about liftmaster Chamberlain Garage Door Opener Transmitter 300MC
How do I remove the mounted garage door button to check the wires
  • 28 Answers
Remove the square white pad from the wall staion and you will find a screw. remove screw and lift up on entire wall station, it will come off the wall, wires are in the back
Posted on Sep 28, 2010
How do I fix the close feature on my garage door opener?
Your electric eye sensors are not aligned, or not working or you have a loose wire or broken wire to them or a shorted wire on the sensors.
Apr 28, 2015 | Building Materials
I have an access master opener. My wall mounted control stopped working. It is a 3 button, 2 wire control. I ordered a new one, replaced it and still doesn't work. I checked the wiring for a break or...
On the rear of the motor unit the two wires from the wall control should go to terminals 1 and 2. Make sure they do. You should be able to momentarily short across those two terminals and the door should operate. Remove the wire from one of the terminals before you try this. If the door operates then replace the wire and try again. If it doesn't work now the two wires are shorted. Replace the wires.
Oct 18, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door will not open close with remote
Press and hold for 3 seconds the button on the wall control with the lock icon.
Aug 29, 2009 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster 971LM opens but won't close correctly
Check the wiring going to the sensors to make sure it is not broken or disconnected. You have a problem with the sensors themselves or the logic board. Unfortunately the only way to be sure is to replace.
Jul 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sear garage door wall mount contol light keeps blinking
Hold the button with the lock icon in for 3 seconds. This should toggle the unit off vacation mode and your remotes will work.
May 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage Door opener will not opern
2 flashes indicate safety eye issue. Check you wiring and make sure it is wired correctly and check to make sure the eyes are properly aligned.
Jan 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door opens on it own and light blinks
  • Stuck remote control button. Check all remotes. check LED on receiver.
  • Staples around Multi-Function Control Panel bell wire could be cutting into that wire. Remove wires from opener and test. Replace staples causing intermittent short.
  • Multi-Function Control Panel could have sticking door control push bar. Remove wires from control panel and test. Replace control panel if defective.
Dec 28, 2008 | Sears Craftsman LiftMaster Chamberlain...
Door will only close when held down
That normally happens when the sensors aren't aligned. Both sensors have led lights on them the yellow/orange one will stay on all the time the green one will go out if it cant see the other sensor. Possibly theres a wire that's broken or the other sensor is really out of alignment. Check every inch of wiring from the sensor to the opener, remove wire nuts if present and check the connections. The wires that are used are small, solid and can break easily. Also see if there's a staple that's too tight, move the wire abit where it's stapled and look for damage.
Jun 23, 2008 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster Wall Control Button not working after replacing gear
Check wiring back to unit to make sure it's not shorted or broken. You can also reset the garage door opener by unplugging it for a few minutes and plugging it back in.
Apr 25, 2008 | Sears Craftsman LiftMaster Chamberlain...
liftmaster Chamberlain Garage Door Opener Transmitter 300MC Logo
217 people viewed this question
Top liftmaster Electrical Supplies Experts
Mike
Gil Shultz
ray gallant
Are you a liftmaster Electrical Supply Expert? Answer questions, earn points and help others
