Question about Miller Electric Manufacturing Electric Syncrowave 250 DX TIG 907194032 Welder
I have a Miller 30 amp spool gun that I am conecting to a millermatic 251 mig welder that has the sooplgun conector when I conected the gun I have no power to the spool gun what do I do to make the spool gun work.
5 Suggested Answers
CarlGehrke
  • 169 Answers
SOURCE: hook up
I think I can help you do this, let's start with the general and you can ask questions if we don't cover everything you need.
The HF251D connects to the welding machine using 3 cables, you connect the Electrode terminal on the welding machine (the Lincoln) to the Electrode In terminal inside the HF251. Connect the Work terminal on the Lincoln to the Work In/Out inside the HF251, also connect the work (ground) clamp of your torch to this terminal. Be careful to select the correct size cables for the maximum current you intend to weld with.
The 3rd cable is the gray 14 pin round control cable that comes out the back of the HF251, it needs to be plugged into your Lincolns RMT14 socket. You'll also need to make sure that the Lincoln is set for remote control, this is usually a switch on the front panel. I'm pretty sure that the remote control cables have a standard pin layout, but we can check this by comparing the specs in both owners manuals.
After that you connect the torch and gas bottle to the HF251, start the Lincoln, and TIG weld until you're happy.
I've got a manual for the HF251 and can get a shop manual for it if we need it. What I'm not sure about is your Lincoln - what model is it exactly?
regards,
Carl
Posted on Dec 12, 2008
luxur4
  • 92 Answers
SOURCE: need wiring schematic for miller 140 wire feed welder
No problem,email, write or phone for this information, Miller personel are very obliging as are most Welding manufacturers.
Posted on Jan 23, 2009
  • 14 Answers
SOURCE: I want to find a operator/owners manuel with a
get a hold of miller theyll be more than happy to help you,and turn you on to a owners manual.hope this helps jojogunn.
Posted on Mar 15, 2009
witmoz
  • 390 Answers
SOURCE: I have a miller 251 millermatic welder that has no
check the wireing from the gun to the servo,it may have got damaged.then test the servo
Posted on Sep 02, 2010
Anyone know what spool gun I would use on a miller syncrowave 300(s) welding machine. I think it might need an adapter but not sure.
  • You can contact direct, but here are some links.
  • Miller Spool Guns for Aluminum and MIG Welding - MillerWelds https://www.millerwelds.com/accessories/guns-torches/spool-guns Spool Guns. Spoolmate™ 100 ... Reliable direct connect Spoolmate™ 150 spool gun provides 20 ft of cable reach and accessibility. ... Miller respects your privacy ...
  • AD/4.6 Syncrowave 210 Series - English - Miller https://www.millerwelds.com/~/media/miller electric/imported mam... · PDF file Syncrowave ® 210 Series TIG/Stick/MIG ... Miller Electric Mfg. Co. ... Spoolmate™ 100 Spool Gun #300 371 Includes 12-ft. (3.7 m) ...
  • Miller Spoolmatic 30A Spoolgun 130831 - Cyberweld.com store.cyberweld.com > ... > Miller Spoolguns & Spoolgun Adapters
    • 5/5
    • 11 RATINGS
    • $1,013
    Miller Spoolmatic® 30A Spoolgun is the professional's choice for ... connect to a Miller 300 pro we would ... spool gun plugged into our Miller ...
  • Manuals & Parts - MillerWelds https://www.millerwelds.com/support/manuals-and-parts ... operations/setup information, and maintenance to troubleshooting and parts lists, Miller's manuals provide detailed answers to your product questions. ...
  • Re: Miller syncrowave 180sd & MM 185 w Spool Gun weldingweb.com > ... > Shop, Trade, Sell Forum
    • 3 POSTS
    • FIRST POST: 2013-04-19
    2013-04-25 · Re: Miller syncrowave 180sd & MM 185 w Spool Gun ... The Syncrowave has about 300 hrs. run time and 350 Arc Starts ... Miller syncrowave 180sd & MM 185 w Spool Gun
  • Spool Gun Hookup Chart - MillerWelds https://www.millerwelds.com/.../spool-gun-hookup-chart Find spool gun hookup information for Miller welders. Determine which spool gun works with each ... Spool Gun Hookup Information. ... Millermatic® 300 without Meters:
  • Spool Gun Hookup Chart MillerWelds
    Jun 10, 2016 | Miller Welding Tools
    I HAVE A XLT142 WHERE CAN I FIND A MIG GUN FOR IT
    Hi:
    You can fin a miller M10 or a tweco replacement gun at any welding supply store like: Praxair, there are more than 1000 stores all over the country check your internet for the nearest one to you.
    Apr 20, 2011 | Miller MilWeld MLL907263 /AutoArc XLT142...
    What mig welder would you I buy to restore a old car.
    I always tell my customers that the best machine for a body shop is a millermatic 212 if you have 220V available if not, go to a Millermatic 211 this is one is a dual voltage unit 110V/220V. if you can afford it buy a spool gun SG100 for all aluminum parts, the machine will cost you 999.00 and the spool gun 215.00. Best investment ever for your shop.
    Oct 28, 2010 | Clarke Power Products Clarke 130EN Mig 110...
    I have a miller 251 millermatic welder that has no response to the gas being tiggered when i press the gun trigger
    Sep 01, 2010 | Miller Welding Tools
    Millermatic 140 w/ auto set powers on but will not feed wire or arc
    If its a new unit its probably nothing. Miller makes good stuff. Open the side so you can see the spool. With the machine on, press the trigger for a second. Did the little wheel spin (trying to feed the wire) if it did then your problem could be kinked wire, **** on tip, or spring on small spool is loose and wire is slipping. Let me know.
    Nov 20, 2009 | Miller matic 140 Mig Welding Package W/As...
    I have a millermatic 130 that will not feed wire
    There can be a few different reasons for it, but here are the top ones.
    1. Remove the nozzle from the trigger end and remove tip and defuser. If you can. Some models the defuser is part of the gun.
    2. make sure the lead is as straight as you can get it.
    3. Check to make sure the tension is tight enough for the wire.
    4. Make sure the spool tension is not to tight.
    5. If all the above steps have been followed to no success, look into buying a new liner for the lead. When removing the liner check it for any major kinks or bends. Sometimes you may not have any but you can find a real flimsy spot by inspecting the liner and this can often cause a mis feed.
    5. If
    Sep 14, 2009 | Miller MilWeld MLL907263 /AutoArc XLT142...
    Spool gun not working
    Was it working before?? If so check switch on gun/relay in welder and connections. If not it is not connected properly/bad relay/ gun switch/ or bad spool gun.
    Mar 16, 2009 | Welding Tools
    Need wiring schematic for miller 140 wire feed welder
    Dec 27, 2008 | Miller matic 140 Mig Welding Package W/As...
    Miller Electric Manufacturing  Electric Syncrowave  250 DX TIG 907194032 Welder Logo
    280 people viewed this question
    Top Miller Welding Tools Experts
    Robert Lee
    Level 1 Expert
    Kory Ronning
    Jose Velazquez
    Jose Velazquez
    Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
