Question about Kenmore 24032\24036 Top Load Washer
Spin cyle wont spin unless i start it by hand. then it will spin until rinse then i have to start it again with by hand.
  • 347 Answers
Assuming that this washer is agitating properly and your only concern is spin you have a bad clutch that has been contaminated with water or grease or is just plain worn out.In either case the clutch is slipping to much to start spinning on its own. Not a real bad repair but something most homeowners would not repair themselves.
Posted on Sep 16, 2010
Oko 72630. Why is it stuck on rinse cycle?
Could be several reasons:
- Selected the "Night cycle" program (means standing with the drum full of water, reason: too much noise in the spin cycle)
- Set to the "Rinse hold" (means standing with the drum full of water, reason: wrinkles on the clothes)
According to your description I think that this is not a failure otherwise error E20 will be appears on display.
Once the washing programme has come to an end, END illuminates on the programme progress display.
If RINSE HOLD was selected, the display beside the START/ PAUSE button flashes.
1. After a rinse hold, the water must first be pumped out:
- Either press the START/PAUSE button (the water is pumped out and the washing is spun according to the completed programme;
After the START/PAUSE button is pressed again, the spin speed can still also be changed during spinning), or
- Turn the programme selector to PUMP OUT and press the START/PAUSE button (the water is pumped out without spinning),or
- Turn the programme selector to SPIN or SHORT SPIN and press theSTART/PAUSE button (the water is pumped out and the washing is spun or gently spun).
At the end of this programme step, the END indicator will illuminate.
2. Open the door.
As soon as the DOOR indicator lights up green, the door can be opened.
Dado
Aug 15, 2015 | AEG Washing Machines
The rinse cyle is not working,it is spinning but the water is not coming out and it is not reaching the off cycle. Do I have to pay for this service? Am I entitled to the "Limited Time: Get 7-day Free...
Look for hoses reversed. Common issue, not apparent until someone manually turns off hot water, which is connected to cold port. Cold port is used for rinse.
Aug 01, 2010 | Whirlpool Washing Machines
Fisher Paykel washer spin issue
lift the front of the machine and set on blocks about 3"
reach under to back to the blak flexable pipe and squeeze several times to loosen hair soap gunk eccetera.
start mahine on rinse cyle
it should start to drain on its own
Jul 18, 2010 | Fisher Paykel EcoSmart GWL15
Spin cyle does not come ,but water drain
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 24, 2010 | Maytag PYE2300AY Electric Dryer
Washer stops agitating durning the rinse cyle, but timer keeps going. Also won't wont spin the water out on the rinse cycle. Wash and spin work just fine. This problem is the same on all three cycles.
I suggest you replace the control box. I need Mgfr & model # to find the part number for you. The replacement steps are more mechanical than electrical. Oh! make sure you UNPLUG unit before starting repair.
Feb 11, 2010 | Washing Machines
Washer won't rinse & drain
The lid wasn't locking in all the way- when we put something heavy on top of the latch it started working.
Sep 15, 2009 | Whirlpool Washing Machines
Machine will not agitate for wash or rinse cylces
that could be your problem or your drain pump maybe full... try spin and drain see if it will drain
Sep 08, 2008 | GE Energy Star WCVH6260F Front Load Washer
Maytag washing machine
humm, is it advancing to spin on its own or are you manualy moving it?
model serial is on the top of machine stand on tip toes and look over the top
could just be the lid switch
May 16, 2008 | Washing Machines
Wont spin out
are the clothes out of balance? sometimes it can take quite a few trys to rebalance the load. if that is the case, it probably could use new drum springs.
Mar 05, 2008 | GE WSRE5260D Top Load Washer
Washing machine stops mid cylcle
try pushing the door closed again, i have a problem with my machine that when i put a load on it starts then stops the light starts flashing then i firmly push the door (at the handle side) and it starts to work again, it might help!
May 10, 2007 | Whirlpool AWM6120 Front Load Washer
Kenmore 24032\24036 Top Load Washer Logo
53 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
