Question about Canon Office Equipment & Supplies
I have a canon IRC4080 with ImagePassH1 I would like to change the IP of the server but cant RUN SETUP of the printer it would ask me a password. I have alredady tried the SERVICE MODE- CLEAR PASSWORD but after shut it down an try to access the printer ask me the password again.
  • 62 Answers
Fiery.1 is the default password.
Posted on Sep 17, 2010
I have changed from Broadband to Wireless and now my Canon IRc4080 won't print. I have turned everything off, turned it all back on, checked the plugs, changed the cable between the printer and my switch...
I would print out the user data list and see if these settings are what you had before. If these are correct, I would use the CMD function of DOS and ping the address of the copier. If connected correctly you should get a reply. You may have to go the the Canon support site and download the setup installer for driver software. http://www.usa.canon.com/cusa/support/office/color_imagerunner_copiers/Color_imageRUNNER_C4080_C4580_C5180_C5180i_C5185_C5185_PRO_C5185i/color_imagerunner_c4080#DriversAndSoftware
Pick the OS you're using and look for the setup installer ( usually a large file, has other copiers along with yours). Run it, follow instructions, and will it try to find the IP address of the copier. If it does, it should come up with the address of the data list. Hope this gets you in the right direction.
Jan 26, 2011 | Canon imageRUNNER iR C4080 Color Copier
I need to get a wpa passphrase how do i get 1
Difficulty: Moderately Easy
Instructions
Things You'll Need: · Wireless print server
· USB printer
· Ethernet cable
· Computer
1. Step 1
Obtain a wireless print server that is compatible with both your wireless network and your printer. While the printer’s documentation may not explicitly say that it is compatible with a print sever, many are compatible, and this can be verified by checking the website of the print server’s manufacturer. If you have a multifunction printer, only the print function will work with most wireless print servers, though a few have recently added support for scanning and the printer’s other functions.
Step 2 Read all of the documentation that came with the wireless print server. The manual will detail the specifics of the installation routine.
Step 3 Connect the printer to the wireless print server via the USB cable. Connect the print server’s Ac adapter and turn the unit on.
Step 4 Connect an Ethernet cable between the wireless print server and your computer. This will be used for the initial setup only.
Step 5 Insert the CD supplied with the print server into your CD-Rom drive. Start the software if it does not start automatically. The application will walk you through the installation process, which includes setting the unit’s IP address, setting an access password, configuring it to connect to the wireless network, installing the drivers that allow the print server to use the printer and installing the print drivers on your computers.
Step 6 Choose how your print server will be addressed. Most units are set up to use dynamic addressing by default, which means that your wireless router will assign an IP address to it. This allows the server to be easily installed on the network, but it also means that the IP address of the printer may change over time. The other option is to assign a static IP address to your print server. This option is more reliable, because the print server will always use the same IP address, making it easier for the computers to find the printer and easier to access the print server’s online configuration application. If your router has the IP address of 192.168.0.1, for instance, set the print server to something like 192.168.0.2 or 192.168.0.3, as long as another device does not use that address.
Step 7
Set a password to be used to access the unit’s online configuration application.
Step 8 Configure the print server to access your wireless network. Give it the same SSID network name as your router and set it to use the same wireless channel. If encryption is used on the router, enable encryption on the print server, and enter the encryption key or password.
Step 9 Follow the instructions given by the print server’s software for installing printer drivers on the unit.
Step 10
Disconnect the Ethernet cable and allow the unit to connect via the wireless network.
Step 11 Install the printing drivers on each computer that will use the printer.
Step 12 Access the print server’s online configuration application to verify all settings by entering the IP address of the unit into a web browser, using the “http://192.168.0.2” format. Enter the administrator name and password.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
May 08, 2010 | HP Photosmart C6180 All-In-One InkJet...
Can't connect to WPSM54G after configuring it
hi sir,
1. first reset the printserver
2. make sure that the printer drivers are installed on the comp.
3. use a w/l comp on which we can go online
4. connect the w/l comp to the print server using ethernet cable and also connect the printer to the print server
5. put the print server cd into the comp and run setup.
6. make sure printer server is near to router and there is no firewall on the comp.
7. the setup will give the ipaddress to print server if not plz assign static ip on the printserver.
8. follow the wizard
9. it will ask u the w/l settings to enter. plz type the exact same n/w name and security password.and apply the settings.
10.after that it will connect u to the print server and u will be able to print if you will not u will find an error to open port.
11.you need to open standard tcp/ip ports for the printserver ipaddress that u have assigned.
12. if u dont knw, u can ask the comp vendor.
13. plz also confifm that the printer is compatible with ur print server.
thanx and regards
sukhiii
Apr 16, 2009 | Linksys WPSM54G Print Server
I have a netgear wgps606 wireless print server. I
Manual Configuration of WGPS606 Print Server
Note: Before configuring the printer server please check if you printer is compatible. You may open this link to you web browser: http://kbserver.netgear.com/kb_web_files/N101216.asp.
1. Please make sure that the printer works when connected directly to the computer.
2. Confirm the wireless settings of your router. You should have the SSID, wireless security and IP address of the router.
For NETGEAR routers please follow these instructions to check the wireless settings:
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. The default username is "admin" and the default password is "password".
Note: If it does not take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you cannot remember the password, you need to reset the router and run the Setup CD to reconfigure it.
d. Click on Wireless Settings under Setup tab and you may get the wireless settings on that page.
e. On the left side under Advance setup, click on the LAN IP setup and locate the LAN TCP/IP Setup. Underneath that is the IP address of the router.
Note: If your IP address is 192.168.1.1, then you may use 192.168.1.200 for your print server.
3. Please connect a computer to the print server. At this time, the router is not connected. The printer should be connected to USB1. The power, LAN port and LPT1 should be lit.
4. Assign static IP address to the computer.
a. Click on Start and right click on Control Panel.
b. When the Control Panel window opens, double click Network Connections.
c. Right click on Local Area Connection, then click Properties. When the Local Area Connection Properties window appears, click Internet Protocol (TCP/IP) then hit Properties button.
d. Change the option from Obtain an IP address automatically to Use the Following IP Address and enter the following:
IP: 192.168.0.50
Subnet Mask: 255.255.255.0
Note: Leave the default gateway and DNS addresses blank.
f. Click on OK and then Close. Exit out of all the Windows.
5. Ping the print server.
a. Click on Start and then Run. Type cmd and hit OK.
b. On the DOS prompt, type ping 192.168.0.102. This should give four responses.
c. If it gives request timed out or destination net unreachable, please turn off both print server and computer. Wait for few minutes, then turn it on again. You can also try holding the reset of the device. Then repeat steb 5.b.
6. If you are able to get replies, you may now open Internet Explorer and type 192.168.0.102 on the address field.
7. After hitting go or enter on the address field, it will ask for a login. (Please type in admin for Username and password for Password).
8. Click on Wireless Settings under Setup tab and we need to set the same SSID as your router.
9. Please also select the appropriate Wireless Security and type the network key or wireless password from the router. Then click on Apply to save the settings.
10. When you get back to the page, click Print Server settings.
11. Check Change to and set the following:
IP address: 192.168.1.200 (It should be on the same range as the router. e.g. 192.168.1.2 for the computer and 192.168.1.1 for the router). This will be the print server's IP address.
IP mask: 255.255.255.0
12. Click Apply to save the settings. We will get a Page cannot be displayed.
13. Set the IP address of the computer back to dynamic.
For Windows 2000 and XP:
a. Please click on Start, select Settings and then Control Panel.
b. Double click on the Network Connections icon.
c. Right click on Local Area Connection and click on Properties.
d. Scroll down to Internet Protocol (TCP/IP) and click on Properties.
e. Select the option Obtain an IP address automatically and Obtain DNS server automatically.
f. Then click on OK.
For Windows 98 and ME:
a. Please click on Start, then Settings, and then Control Panel.
b. Double-click Network then select TCP/IP for the Ethernet adapter. Then click on Properties.
c. Go to IP address tab and select Obtain an IP address automatically.
d. Click on the Gateway tab and delete the numbers under the Installed Gateway.
e. Click the DNS Configuration tab, and then select Disable.
f. Click on OK. Windows will then prompt for a restart.
14. To set up a TCP/IP port to the computer, please follow these steps:
b. Double click on Printers and Faxes.
c. Right click the printer icon and go to Properties.
d. Click Port Tab and click Add Port.
e. Select Standard TCP/IP port. Hit OK or Next.
f. In the field for Printer Name or IP Address: enter the IP address of the Print Server and click on Next.
g. Select Custom and then click Settings.
h. Under Protocol select LPR, and for Queue Name, type L1 if printer is connected to the print server USB port 1 and L2 if the printer is connected to the 2nd port.
i. Click on OK, then Next, and Finish.
j. Lastly, please right click on your printer icon and select Use Printer Online. If this is not an option, disregard it.
15. Check if you can print through the print server.
16. If it is not printing, then please try to connect the print server to the router and check if you can print. If it can, then there might be a need to re-do the steps for wireless configuration of the printer server.
Mar 29, 2009 | NetGear WIRELESS PRINT SERVER 54MBPS...
Netgear Print server
IP: 192.168.0.50
Dec 18, 2008 | NetGear WGPS606 (WGPS606NAR) Print Server
Scanning to email; Canon LC730i
You need to network the printer via its ethernet port and you need an email server in that network to route the fax.
I got it to work at home using hmail (a free windows mail server).
Fax
http://www.twesalesusa.com/downloads/FAXDrv_G.pdf
http://www.twesalesusa.com/downloads/Network_Guide.pdf
I cant find the sending guide which I have in print, you will need that as the most important piece, but basically if you know basic email account setup, you should be able to go through data registration button on main panel and under system settings-> network settings I believe enter SMTP IP address of your internal email server. Another avenue for this would be to ask your ISP if they relay email for static IP subscribers. Qwest does and you might be able to point the fax directly to the relay but I haven't tested this (in lieu of the in home hmail server).
Oct 24, 2008 | Canon 730i Laser Printer
Canon Color Imagerunner c3220
Go to the Printer Tab, select Printer Status/Settings, select Functions, go to page 2, select Run Setup, select Yes, and then you're in like Flynn.
Sep 03, 2008 | Canon imageRUNNER C3220 Printer
Netgear Wireless Print Server WGPS606 won't install correctly
I finally got my WGPS606 installed - unfortunately, it's just on one computer so far, but that computer is on the network and is not wired. Here are a few tips:
1. hold the reset button (little pinhole) until you see some action going on with the lights (I forget exactly what happened, but after a while there was a change) - this served to "reset" my WGPS606's IP Address, which I had changed during setup.
2. connect your computer to the server with an ethernet cable and type in http://192.168.0.102 (the default IP Address of the server)
3. login with the default username and password:
username: admin
password: password
4. once logged in, you will see all of the WGPS606's information. At that point, you should be able to change the IP Address of the server to what you want it to be, but I think you can proceed to run the setup on the installation CD (or the installation program from the WGPS606's Netgear website) and it should be recognized on the wireless network.
In my case, I want to mention that when the initial setup failed for me, I used the MAC address on the back of the server. After steps 1-4, my server was finally on the wireless network by the installation program, however, the MAC address was 1 digit off from what was on the server. The MAC address on the back of the server was the PHYSICAL MAC address, whereas the WIRELESS MAC address was one digit higher (last set of numbers. For instance, on the back of the server, the MAC address ended in ":01" and I found out that this was the physical MAC address. The wireless MAC address was exactly the same, except the last 2 digits were ":02."
Another thing to note was that after the server was recognized, it told me to reserve a specific IP Address other than what I had previously set - I didn't realize that it chose it for you. Anyway, just keep that in mind. After this, everything worked like a charm - well, I have yet to set up the other computers to connect to the server, but at least I have one!
Hope this helps!
Jan 11, 2008 | NetGear WGPS606 (WGPS606NAR) Print Server
Cant change or remove the password.
with some system you will have to use ctlr H before the password system
this removes the space so the password is correct
Aug 03, 2007 | Emulex NETQue Print Server
Emulex NetQue Pro2 Print Server how do I connect to it
Your DHCP server will keep track of which MAC Addresses have been given what IP addresses. From there, find the IP address of your Print Server. Ping the IP address to confirm IP connectivity between your computer and the print server. You should then be able to upgrade the firmware.
Oct 04, 2006 | Emulex NetQue Pro2 (NP02) Print Server
1,451 people viewed this question
old marine
old marine
