Question about Hotpoint HSS25GFP Side by Side Refrigerator
The freezer side frost up over a short period of time.
  • Hotpoint Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 17, 2010
Hotpoint Future fridge freezer - freezer working well but top of the back of the fridge has a large build up of ice ??? And doesn't appear to be keeping the food cold enough
here are lots of things that can cause cooling problems. One of the most common causes of poor cooling in a frost free refrigerator is a defrost system failure. In such a case one or the other compartment may appear to be keeping proper temperature but that too may change in a short period of time. The fridge compartment's temperature rise is usually (but not always) the first to be noticed. Frost" and "Ice"
There is a difference between "frost" (a white, snow-like substance) and "ice" (usually clear and solid). When referring to what is seen during an inspection, please keep this distinction in mind as the possible causes for each are often very different. The Defrost System
Inspecting the (usually rear) wall of the freezer compartment for a frost build up is necessary. (In the case of many GE top freezer models, check the freezer's bottom panel.) If there is a frost coating on it, it is often a sign of excessive frosting beneath it. Sometimes however the evaporator cover panel will actually need to be removed (see the illustration below) before an excessive frost build will visible.
The refrigeration system's evaporator (cooling) coil is usually in the freezer compartment. This evaporator will periodically frost over and have to be defrosted by means of a heating system. When the defrost heating system fails, the frost can accumulate to such a degree that airflow throughout the appliance is hampered. There may be just enough air circulation to cool the freezer section but that will eventually stop too.
Sep 28, 2016 | Hotpoint Refrigerators
Back of freezer has frost and freezer wont cool to proper temp. icemaker etc also not working
Did you leave the freezer door open for a period of time while the refrigerator was running? Unplug and defrost the freezer manually with a hair dryer until all frost is removed inside and in back of the freezer. Reapply power and see if it will then cool/freeze properly. Let me know the results
APPLIANCE 911
Jan 10, 2016 | Samsung RH29H9000SR RH29H9000SR 36"...
Freezer is frosting and refrigerator is warm.
As far as your freezer frosting up, sounds like a door seal problem, run your fingers along the seam of the door seal, there should be no splits/holes in the seal.
As far as the refrigerator either there is a secondary fan motor, or there is a obstruction blocking the air movement, if the freezer has a bad seal, its suspect ice is still building up.
Jul 08, 2013 | KitchenAid KSRV22FV Side by Side...
Whirlpool etowsrxmq03-- back wall of freezer is
Good day,
Yes that is normal. It is going thru one of it's automatic defrost cycles to melt off excess frost building on the cooling coil mounted behind the rear panel in the freezer section.
The red glow is the heater doing it's job. It does this for a short period of time, and causes the rear panel to become somewhat warm, but only for a short period.
It only occurs about once a day randomly, and lasts only 21 minutes, so the odds of seeing it are rare.
Jun 05, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
My freeser has frost on back wall
Frost on the back wall is an indication that the automatic defrost cycle has failed.
This will lead to improper cooling in a short period of time. If you want to make the repair yourself part number WR51X10053 is the heater (the most likely part that has failed).
You will need to unload the freezer, take all the shelves out and remove the rear panel from inside the freezer. You will see the element located at the bottom of the radiator looking coils.
Apr 18, 2010 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
We have a 20.3 cubic feet Kenmore upright frost free freezer we purchased in May 2003. We noticed the meat was beginning to thaw one afternoon. We hit the quick freeze button and that seemed to fix the...
This sounds like a bad thermostadt, since the quick freeze button does work. But it should be much colder than 32 degrees. It may also be the motor, since it runs for brief periods of time after plugging it back in.
I'd say best bet here is to call a repairman. (sorry...)
May 10, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Icemaker making too much ice & Freezer frosting up.
Hi gpss,
It sounds like you are getting large amounts of warm moist air into the freezer. This can be caused by the door being left cracked open or the door seal not sealing properly. Check your door gaskets on both sides of the refrigerator. One other possible is the ice chute. If it is not closing all the way it will cause the same problem. You will get alot of frost forming in the freezer then it will melt when the refrigerator defrosts. Let me know if this helps, and if you have anymore questions.
Mike
Sep 30, 2008 | GE GSH25JSTSS Stainless Steel Side by Side...
Layer of frost on the bottom surface of ice maker
during periods of high humidity and or high use, it is not unusual to notice frost on surfaces in the freezer. the ICM is susceptible due to it being metal and having warm(compared to freezer temp) water in it. make sure the doors ar closed tight and nothing is stuck in the gasket area.
J
Jun 13, 2008 | GE Profile PSI23NCR Side by Side...
FRIDGE NOT WORKING
Most side by side and other models of refrigerator freezer combinations are of one basic design. The freezer section does the cooling for both compartments. The refrigerator section gets it cold air from the freezer compartment. Therefore check for frost on the back wall of the freezer compartment. If frost is present there you have a defrost problem and it is cutting off the air that cools the refrigerator section.
I think this problem may already be resolved in some manor because of the date of post. Posts should expire after an unreasonable time period.
Mar 19, 2008 | Smeg FA561X Side by Side Refrigerator
Hotpoint HSS25GFP Side by Side Refrigerator Logo
50 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
