Question about Pride Wrangler Pmv 4 Wheel Scooter
My Pride Wrangler PMV will not move. Battery is fully charged, lights and horn work. My repair person said the controller was sending out an error code on the throttle so he ordered and no change in read out. New controller is now recommended at $1,500 for part alone. Any other solutions? Why so much money? Do they fail frequently?
  • 692 Answers
Bailey I think you said that the throttle pot was replaced and you are still getting the problem? Did your guy also check the speed pot? They can cause the same problem as a bad throttle pot. The controller is the brains and yes they are expensive but I question $1500. No they fail very seldom and usually its another part. How old is the scooter? There is a one year warranty on the controller. The dealer cost for the controller is about 1/3 of what you were quoted. Maybe a little wrangling could reduce your cost. But I would want all things checked first. Hope this helps you
Posted on Sep 17, 2010
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 346 Answers
Hello.this is the 3rd time i have wrote you an answer,hopefully this time it will be sent.im disabled myself,so i know what its like to be without ur scooter.if you download:troubleshooting_2007 SHOPRIDER.pdf and go by their set way of doing things.its an Adobe Acrobat Document.& im sure you will be happy with this,& should have ur wheels back soon.please rate me as in thumbs up 1 to 4 as to how you feel i helped,Colin.
How can I trouble & fix my scooter
hi sounds like youre circuit has shut down if your have had it in free wheel it will shut down all the lights will work take the key out put it in drive and put the key back if it has a similar circuit as a pride XL it should work...........one more thing if u leave the key turned on for 20 minutes the circuit will shut down all the lights will work take key out wait for a few minutes & put the key back in ..if this does nothing get youre batteries checked with a ..battery load tester .....good luck
Sep 05, 2015 | Pride Hurricane 4 Wheel Personal Mobility...
Pride wrangler pmv-600 goes in reverse on forward lever
Check the polarity of the motor harness at the controller.
Sep 28, 2014 | Pride Mobility Products PMV600 Wrangler -...
Why won't my pride legend start?
The legend has a Curtis controller. The flash codes you provided points the problem to a faulty throttle pot. If a new throttle does not fix the issue, then your problem is the controller itself.
Sep 03, 2014 | Pride New Mobility Legend 4 Wheel Scooter
Pride Wrangler PMV has ringing sound when in drive mod? Help
It sounds like the wheel bearings need lubrication or they might not have a fitting to be able to lubricate. If there is no way to lubricate the bearings, they will have to be replaced with new wheel bearings.
Jun 09, 2014 | Pride Wrangler Pmv 4 Wheel Scooter
Pride wrangler rings sound when in drive mod?
Need some more information, what sound ... How many beeps, symptoms when fault occurs. Even small bits of information can shed some light on the problem.
The battery on my wrangler will not charge
Measure the voltage on the charger terminals. It has to be 29 volts when not connected to the scooter. If the charger in an onboard type the fuse for it in in back of the scooter. Download the service manual from Pride's website. It has detailed instructions.
Feb 16, 2014 | Pride Wrangler Pmv 4 Wheel Scooter
Pride hurricane. Will not move fwd or rev. No beeps when turn on switch
So the status light does not flash ? just a steady green ?,,,
so when moving the throttle lever or wig wag what ever you wish to call it , is there a click from the rear brake located on the side of the motor ???
Regards
Rob
www.gewizrepairs.co.uk
Feb 02, 2014 | Hurricane Pride PMV Mobility Scooter -...
Pride colt . fully charged batteries but no power to lights indicators or drive
hi, okay have you checked the fuses located on the tiller stem normally located under a black plastic cover ?
Your batteries may be fully charged but the voltage is not enough to power up the controller, sigh of a dodgy charger ? , bad batteries ? ? check the battery voltage , should be at least 24volts
The horn will work as it bypasses the controller logic.
Regards
Jan 20, 2013 | Pride Health & Beauty
My Pride Hurricane PMV will not go forward or backwards when I engage the trottle all I get is a click but it will not move. The battery meter shows fully charged.
Make sure that the manual brake release/freewheel lever is in the DRIVE position. The click indicates the brakes are being released but the motors are not kicking in. I hope this helps- good luck!
Nov 03, 2010 | Pride Mobility Products Hurricane PMV...
Hogh - low speed switch is incorrectly wired , but i dont know how it should be wired - Pride Hurricane scooter
Hi, I take it been taken then, do you get a error codes ?
see below
DIAGNOSTIC FLASH CODES
The diagnostic flash codes for your scooter are designed to help you perform basic troubleshooting quickly and
easily. A diagnostic flash code will flash from the status LED in the event one of the conditions listed below
develops.
NOTE: Your scooter will not run unless the flash code condition is resolved and the scooter has been
turned off, then turned back on.
Any electromechanical device occasionally requires some troubleshooting. However, most of the problems that
may arise can usually be solved with a bit of thought and common sense. Many of these problems occur because
the batteries are not fully charged or because the batteries are worn down and can no longer hold a charge.
FLASH CODE CONDITION SOLUTION
! (1) Battery charge is low. Charge batteries as soon as possible.
! ! (2)
Batteries are too low to operate the
scooter.
Charge batteries.
! ! ! (3)
The scooter’s battery voltage is too
high to operate the scooter, or the
charger is still connected to charger
port.
Unplug charger and/or turn key off, then
back on again.
! ! ! ! (4) Current limit time out.
Turn the scooter off for a few minutes,
then turn your scooter back on.
! ! ! ! ! (5)
The manual freewheel lever is in the
(forward) freewheel position.
Remove the key from the key switch,
then push the manual freewheel lever to
the (rear) drive position, and restart your
scooter.
! ! ! ! ! ! (6)
Throttle control lever not at center
position at start up.
Return the throttle control lever to center
position, turn scooter off, then back on.
! ! ! ! ! ! ! (7) Speed pot error.
Contact your authorised Pride Dealer for
assistance.
! ! ! ! ! ! ! ! (8) Motor volts error.
assistance.
! ! ! ! ! ! ! ! ! (9) Other internal errors.
Regards
GeWiz.
Oct 20, 2009 | Pride Hurricane 4 Wheel Personal Mobility...
Pride Wrangler Pmv 4 Wheel Scooter Logo
188 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
