Question about Samsung LNT4642H 46 in. LCD Television
Tv clicks off and on no picture or sound - Samsung LNT4642H 46 in. LCD Television
Connecting laptop to tv...sound but no picture
u have to go back and click start look for control panel than click on display on your left hand side click on connect to a projector and select to duplicate the image on your tv
May 08, 2014 | Dell Latitude E5400 Notebook
No picture just sound
GO SETTING TAB AND FIND OPTION SET DEFAULT MANUFACTURING SETTING AND TRY
May 18, 2012 | Sony KV-35S42 35" TV
Red light flashes on power switch, but no picture or sound on tv
tv will not power on. red light on switch blinks. power relay clicks, but no picture or sound.
Jul 28, 2009 | Toshiba DVD Recorder AND Series2 TiVo...
Will not come on it only a clicking sound from part no. 0mron 0584H3
I had the same problem with my tv, same make and model. I first continuously turn on and off my tv manually until I could get some kind of picture. This procedure took maybe five minutes. I was able to get a fine picture and sound, as if it was brand new! Other things to keep in mind, try to eliminate dust build up as much as possible.. Hope this helps out...
May 21, 2009 | Philips Magnavox 27MS343S 27" TV
Power light for tv turns on but no picture and no sound comes on tv i have a 50 inch phillips plasma
Check your cables and TV input settings.  Can you get to the on screen menu?  Does anything appear on the screen when the tv is on?
Dec 06, 2008 | Televison & Video
No picture and clicking sound only
This may be a power supply problem or a shorted horizontal output transistor shorted. The clicking sound is the power supply trying to start but can't because of the overload. Stargazer
Feb 17, 2007 | Curtis CM32020S 32" TV
No picture or sound
If you had a burning smell, well the board is toast. These sets are made to replace the entire board at one time. Before installing the replacement module, the picture tube should be checked. A defective picture tube ( such as a G1 short) may cause a failure in the power supply section.
Sep 07, 2006 | Zenith C32V36 32" TV
Samsung LNT4642H 46 in. LCD Television Logo
23 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
