Question about Turboair TUR-TSF49SD Super Deluxe Freezer reach in two section 49 cu
Turbo air refrigerator TSR 49D model will not maintain temp. Setting 5 temperature goes down to 28 degrees - setting 4 does not get cold enough. I need a temp around 41 degrees.
jgwhomeequip
  • 1902 Answers
SOURCE: turbo air sandwich table too cold
Replace the thermostat which is located on the back of the unit underneath the bins in the very back. If the thermostat goes bad it will let everything just run and run and run. If this has been helpful please rate
Posted on Feb 12, 2009
  • 531 Answers
SOURCE: Ge model PSC25MSTASS digital refrigerator setting
check for frost in the freezer back wall
Posted on Apr 01, 2009
freetek
  • 5568 Answers
SOURCE: refrigerator will not maintain proper temperature
Check in the back of the fridge section; there is normally a control that is provided for 'balancing' the cold air between the two sections. That coolled air is distributed by a concealed fan that may not be running; you should be able to ear or feel the air movement when the unit is in a cooling cycle.
Posted on Apr 19, 2009
  • 61 Answers
SOURCE: Refrigerator does not maintain 37 degrees
i have seen this problem before its the control board in the back the board is about 150 dollars and it goes every DING DING 5 years lol horrible design of the one that comes on the fridge every ge side by side has this problem  its very easy to replace but have to "ground" yourself before you touch the new control board meaning rub you hands on plumbing pipes, not pvc or copper
good luck if you got questoins let me know
Posted on Jun 08, 2009
SOURCE: Fridge Freezer will not maintain fridge temp, but freezer fine
My miele fridge freezer has just come up with a fault code F4 where the temp is... what does this mean and how can we fix it???
Posted on Jan 18, 2010
Why does the split unit blow hot air in air conditioner mode, when switched on with the remote control.
because you have the temperature set at 28 degrees celcuis . Change the temperature to 18 degrees and it will cool 28 is hotter
It is a reverse cycle air conditioner it will warm the room if you set temperature to 28 degrees . Set it lower and it will blow out cold air.
Have exact same air conditioner as I recognise the remote control.
point it at the air conditioner when altering the temperature setting.
Check under the slide compartment also on the remote for more advanced settings.
Jul 02, 2015 | Cfm Daikin R410a Split System Air...
I have a 2yr. old Maytag Frig.,freezer on top.I cannot get a stable freezing temp. I can set, with the setting control, readings of 4 or 7 with no effect on the actual temp. I bought a freezer thermometer...
If the refrigerator is not cold enough then please check the following and also click on the blue coloured links for more info.
How To Check the Temperature1x1.gif In most refrigerator freezers, the refrigerator gets its cold from the freezer. The evaporator fan circulates air over the coils in the freezer and cold air circulates into the refrigerator through vents. If the vents are blocked or closed, then the fridge will not get cold enough but the freezer will. If neither is cold enough, then the number of possibilities increases.
Lowering the freezer temperature will increase the cooling cycle activity. Setting the refrigerator temperature may have little affect on the cooling cycles because it simply changes the vent opening size. Decreasing the fridge temperature opens the vents more and increases air circulation from the freezer.
The temperature can be adjusted using the controls found inside the refrigerator or freezer. The ideal freezer temperature is about 0 to 5 degrees (F) and about 38 degrees (F) for the fridge.
Measure the temperature by placing a cup of water with a cooking thermometer into the refrigerator for about 2 hours or more. To test the freezer, substitute alcohol or cooking oil.
Goodluck,
Please don't forget to rate the solution.
Mar 27, 2008 | Refrigerators
Fridge not cold enough
The higher the number the colder the temp is supposed to be.
In order to prevent the formation of bacteria and other such organisms to affect food the way it does, the ideal temperature range of refrigerators has been mentioned here. Before we look at these settings, it is important to know the format in which temperatures are represented within a refrigerator. Commonly, you will notice a dial representing the figures 1-5 or 1-9 in the refrigerator, and a dial representing the letters A-E in the freezer. The ideal setting is usually in the middle of such figures.
If the dial is in such a format in your refrigerator, try a setting at 3 if the range is 1-5, and at 4 if the range is 1-9. For the freezer, a setting at C is suitable.
The ideal temperature in the refrigerator ranges between 34 degrees F - 38 degrees F or 1 degrees C - 3 degrees C. So that foods such as vegetables and fruits remain fresh and crisp, the temperature may be set around 38 degrees F or 3 degrees C.
The ideal temperature in the freezer ranges around 0 degrees F (-18 degrees C) or lower.
Read more at Buzzle: http://www.buzzle.com/articles/refrigerator-temperature-settings.html
Mar 05, 2014 | Belling Refrigerators
PSC23NSTESS FREEZING VEGTABLES
Side by Side ModelsIf foods, such as fruits and vegetables, in the refrigerator are freezing, it can be caused by several things. First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenheit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • If food in the bottom of the refrigerator is freezing, this could be caused by a refrigerator not having enough food to absorb the cold air.
  • If food in the door is freezing, move the door bins up or down so they are one notch away from freezer vents (Side by Side models only).
  • The fresh food control should be at the normal setting of 5.
Freezer on Top Models
First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenehit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • Since the cold air coming into the fresh food section originates in the freezer above, the rear of the top shelf will be the coldest spot in the fresh food area. Avoid placing delicate items that freeze easily on the back half of this shelf.
  • If food is freezing in the produce (fruits and vegetables) or meat pan, it may be that the temperature controls are not set high enough. Since cold air naturally falls, the pans can get too cold if the refrigerator is not running long enough to maintain good air circulation. Adjust both controls up one notch.
Nov 01, 2012 | GE CustomStyle PSC23NSTSS Stainless Steel...
Beverage Air MT17 cools sporadically. I turn the temp control setting to 5 and it will go down to 28 degrees F and the next day it will be at 55 F. I have to turn the control knob to off position then turn...
Low refrigerant would make it inefficient but if it chills to 28° it can't be that bad. I think you have a control issue. The compressor runs when you reset to off & on, then chills until it satisfies the thermostat, then shuts off. But then is not starting again when the temperature rises. You'll need to follow the control wiring to see what contacts are open and not passing power to the compressor. Control wiring is typically 24v ac or 115v ac. There's also the possibility that the compressor is tripping out on overload at 28°. You effect a reset when you turn it off, then on.
Mar 26, 2017 | Beverage-Air MT17 Refrigerator Commercial
Am going away and would like to know what level to turn the radiators down to, on the westtherm radiator valves it goes from * to 1 - 5.. Would the * setting be okay?
I assume you want to save on heating costs and at the same time keep the pipes from freezing in your absence. 50 degrees is the normal temperature you want to maintain in this case. However, I am unable to tell you exactly which setting would maintain that temperature. So try closing the door to one room that you infrequently use, put a thermometer in that room and turn the radiator down to the first setting. After several hours, check the room temp. If it's 50 degrees, you've got it right. If it's below 50, turn it up a notch and check it again in an hour. Remember, night time air temperatures are generally colder than daytime temps.
Feb 08, 2011 | Heating & Cooling
Bought a brand new LG bottom freezer fridge a couple of months ago. I like the refridgerator part to be cold, so we keep the fridge temp on 6 (1-7 are temp choices. 7 being the coldest). We had the freezer...
If designed as most combination units, one of the two controls influences the temperature directly, the other only determines how much of the generated cold air is allowed to enter the other compartment. The typical arrangement is that setting the freezer temperature determines how often often the compressor runs; the other diverts a portion of the cold air into the refrigerator side.
Using the common thermometer for cold temperatures (~$5 US), adjust the freezer temperature for 0 to -5 degrees F (the often recommended temp.), then the other control for the desired refrigerator temperature, suggested as 35-45 F. This is the most common practice.
If you cannot balance them the way you want, reverse the procedure, setting for refrigerator temp., then freezer.
Dec 13, 2010 | LG LBN22515 Bottom Freezer Refrigerator
Freezer not cold enough; fridge OK
Hello cokoliso,
Welcome to Fixya
You said, your Trio won't make ice. Freezer stays at about 25 degrees regardless of control setting. Fridge maintains 40 degrees at mid setting. Shouldn't the freezer be close to zero? Is there a way to check the temperature sensor in the freezer?
To check the temperature you can buy a refrigerator thermometer at the hardware store.
Ask if it can be used in the freezer too!
The fridge sounds slightly to cold and the freezer not enough.
Fist look in your freezer and check if the articles there are full to the max and covering the air vents usually found in the rear of the freezer.If so clear an opening for the freezer to breath.
Refrigerators and freezers usually share the cold air and I've seen this be the problem on many occasions.
If freezer was not I blocking the vents or even full to the max.
Then pull the plug out or if you can not reach the plug, trip the breaker off for 5 minutes and see if this resets the system.BUT do not plug the fridge back in before at least 3 minutes.
Let me know how it goes and send me any questions.
Thank You, Huuum
Please remember to leave a rating .
Oct 03, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Our amana fridge model # BH2055W, with a botom freezer will not maintain the temperature.A repairman put in more fluid, but that did not solve the problem. It will not get cold enough and does not...
CHECK THE FREEZER TEMP FOR ZERO DEGREES. PUT A THERMOMETER IN THE FREEZER THAT WILL MEASURE DOWN TO ZERO DEGREES. LET IT SET OVER NIGHT BEFORE CHECKING. IF THE TEMP IN THE FREEZER IS ZERO OR LOWER, THE SEALED SYSTEM IS O.K. IT IS AN AIR FLOW PROBLEM. ON SOME MODELS, THE AIR TO THE FRESH FOOD COMPARTMENT IS CONTROLLED BY AN ELECTRIC, MOTORIZED AIR DAMPER. IT COULD BE DEFECTIVE, STAYING CLOSED WHEN THE CONTROL CALLS FOR MORE COLD AIR. IF YOUR REFRIGERATOR HAS A DIGITAL CONTROL, THERE IS A SENSOR IN EACH COMPARTMENT TO TELL THE ELECTRONIC CONTROL WHAT THE TEMP IS. THE SENSOR (THERMISTOR) COULD BE BREAKING DOWN, GIVING A FALSE READING. THIS WOULD ACCOUNT FOR THE TEMP VARIATIONS.
IF THE FREEZER IS ALSO WARM, THERE COULD BE A RESTRICTION IN THE SEALED SYSTEM. THERE COULD ALSO BE A PROBLEM WITH THE RELAY ON THE COMPRESSOR, NOT ALLOWING THE COMPRESSOR TO START UP WHEN IT IS NEEDED.
BE SURE THE CONDENSER FAN MOTOR IS RUNNING WITH THE COMPRESSOR AND THE CONDENSER COILS ARE NOT PLUGGED WITH DUST, DIRT OR FOREIGN OBJECTS.
Apr 08, 2008 | Refrigerators
Turboair TUR-TSF49SD Super Deluxe Freezer reach in two section 49 cu Logo
103 people viewed this question
Top Turboair Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Turboair Refrigerator Expert? Answer questions, earn points and help others
