Question about Insignia 19 in. Widescreen Flat-Panel LCD HDTV
How do i get my insignia (model NS-32L550A11) to play sound while connected through the vga?
  • 11 Answers
SOURCE: insignia ns-lcd32
You can download the manuals from the Insignia website at:
http://www.insignia-products.com/c-14-lcd-televisions.aspx
Jerry
Posted on Dec 08, 2008
  • 2318 Answers
SOURCE: No picture, no sound, does light the insignia sign. Why?
In about 90% of the time the power supply is defective if the TV fails to power ON.
I repair these power supplies, if you need further assistance write to jah2mil@homtail.com
Posted on Jun 29, 2009
ginko
  • 19396 Answers
SOURCE: Insignia NS-32LCD has sound but no picture -
If an LCD TV has sound but no picture do the following:
Use the source button to ensure that source is not set to the wrong input.
Try unplugging power cord for ten minutes, to ensure it is not a setting problem.
Check all the video cables at the back of TV.
Check Light /Color settings.
If problem persist and does not depend on external receiver or settings, then it is likely an internal fault.
If it has sound but no picture then one of the following parts is faulty, and must be tested and replaced:
Theinverter is the high voltage board that provides variable power to thebacklight lamp. This is the most common. When inverter is faulty youcan get no picture, or a very dim picture that can only be seen bypointing a torch light with a 45 degree angle on the LCD surface fromvery near distance.
The inverter must be tested by reading voltages with a multimeter.
The LCD ribbon cable/LCD display and connectors.
Thisis quite uncommon, but happens. If the TV had been hit or moved the LCDcable may have slipped out, or the LCD connector may be damaged.
The LCD controller board.
Thisis the board that controls the video signal, it is difficult to test,as there is need to read determined values on IC pins. To test thisboard you need to purchase a service manual and follow thetroubleshooting diagrams on service manual.
Input/Output Signal boards.
This are the boards where youconnect the video and audio cables, if a signal board is defective,then you may get no picture on particular inputs located on faultyboard.
If under warranty contact the manufacturer ringing the number on the user manual.
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
Posted on Jul 18, 2009
  • 161 Answers
SOURCE: Insignia lcd tv model ns-ltdvd26 has sound but no picture
the pic attached is an electrolytic capacitor, they come in different sizes and are usually blue, black and sometimes yellow. depending on manufacture.
most of the problems I have heard of tvs having problems with the electrolytic capacitors going bad. if you open the tv and see one of those swollen or leaking you need to replace them.
Posted on Feb 13, 2010
SOURCE: trouble connecting Insignia HDTV 19" to my macbook pro
One of the first things you may notice about your new big-screen HDTV is that it has more connections for video than your old TV ever dreamed about. It probably has two or three HDMI connections, maybe a DVI connector, a VGA connector, and at least one component video connection. And those are just the connections most commonly used for high definition.
It’s shame to let all those connections go to waste. Your Mac just happens to be sitting nearby; why not hook it up to your new HDTV? It's actually a pretty easy task. A few lucky souls won't even need an adapter; for the rest of us, at least one adapter will be necessary.
Pick the Right HDTV PortFor best quality, your HDTV's HDMI or DVI ports are the preferred connection method. Both are capable of the same digital quality. The only practical differences are the style of the connector and the fact that HDMI supports video and audio in a single connection.If it has one, another option is to use your HDTV’s VGA port. The VGA connection isn't as good as the HDMI or DVI method, but as long as your TV supports full resolution via the VGA port, you'll be hard pressed to notice the difference.Mac Pro, MacBook Pro, Mac MiniMac Pros, MacBook Pros, and Mac Minis have standard DVI connectors. Mac Minis and MacBook Pros have a single DVI port; Mac Pros have at least two DVI ports.If your HDTV has a free DVI port, then all you need is a standard DVD cable; no adapter is necessary. But in all likelihood, you'll need to connect your Mac to your HDTV using either an HDMI or VGA connection; both options require an adapter. If you choose VGA, you can use the adapter that came with your Mac.If you choose HDMI, you'll need a simple adapter, which is available from multiple sources. The adapter may be a cable with a DVI connector on one end and an HDMI connector on the other, or it may be a small adapter that has both types of connectors, but no cable. Either type will work fine.iMac, MacBookiMacs and MacBooks have a mini DVI connector for hooking up external monitors or TVs. You'll need at least one adapter, maybe even two. At a minimum, you'll need a mini DVI-to-DVI adapter. You may also need a DVI-to-HDMI or DVI-to-VGA adapter, depending on which port on the HDTV you choose for the connection.Make the ConnectionOnce you determine which, if any, adapters you need, and have the necessary cable to reach from your Mac to the HDTV, turn off both the HDTV and the Mac. Connect the cable between the Mac and the HDTV.Turn the HDTV back on first. It doesn't need to be set to the connection the Mac is on, but it must be powered up first, so that when it boots, your Mac can recognize the TV and the resolution it needs. Once the HDTV is powered up, turn on the Mac.Your Mac should recognize the format and resolution of the TV, and automatically select the native resolution of the TV for running the video. In a few seconds, you should see the Mac desktop on the HDTV.Over or UnderscanYou may notice that the Mac's desktop appears to be slightly larger than the HDTV's screen (its edges are cut off); this is called overscan. Or, you may notice that the desktop doesn't occupy all of the HDTV's screen real estate (there are dark areas around the edges); this is called underscan.You can usually correct either issue by making adjustments on the HDTV. Check the HDTV's manual for information on making scan-related adjustments. They may be called overscan, underscan, dot-by-dot, or pixel-by-pixel. If your HDTV has a dot-by-dot or pixel-by-pixel capability, give this a try; it should eliminate any over or underscan issues. Some HDTVs only offer these special scan controls on specific inputs, so be sure to connect to the corresponding input on your HDTV.Time to Watch a MovieOnce you have your Mac and HDTV working together, it's time to kick back and watch a video from your Mac. Be sure to check out the QuickTime HD trailers for a sense of what HD and your Mac is capable of. Enjoy!
Posted on Feb 22, 2010
I would like to connect my lenovo thinkpad t61 to an insignia t.v. both the t.v. & laptop have vga ports. what else would i need to connect the two & what is the process? thanks for your he
The laptop will provide a VGA output and your TV should be able to switch to "Computer" or "VGA" input so all you need is a 15pin VGA lead. Just ensure you get the correct gender.
Mar 08, 2014 | IBM Lenovo ThinkPad® T61 PC Notebook
Setup insignia NS-LCD19. I get a "signal not
Your computer video output resolution is not compatible with the TV. Try adjusting your video card output settings to 800x600 at 60 hz to begin. Once the desktop displays on your TV, you may continue to adjust the settings to meet your needs.
Oct 12, 2011 | Insignia NS-LCD19 19 in. LCD TV
It says no signal in vga mode
This means that there's no VGA source connected (i.e . a computer, a hard disk player, etc), if you want to use this input, you have to get a VGA cable (male to male DE-15 connectors at both ends) to connect both devices.
Mar 13, 2011 | Insignia NS-LCD22-09 LCD HDTV
I have a Insignia NS H 2002 with my own speakers. Will this unit play music CD's by itself without being hooked to anything else.
Yes, this model will play audio CDs as well as DVDs. You can download the manual here if you need a copy, which explains all the functions.
Feb 10, 2011 | Insignia NS-H2002 Theater System
I have an insignia 24 tv and i cant get the audio
You will also need to connect audio from the audio output on your computer to the TV. I would recommend consulting the owner's manual for your TV as is should include detailed instructions for connecting your computer. Search for your TV model number at InsigniaProducts.com.
Jan 05, 2010 | Insignia NS-24 TV TV
Insignia 22'' LED HDTV screen resolution problem with VGA
This is more of an alternative than a solution... but I solved my problem by getting a dvi to hdmi adapter and connecting to my mac desktop via hdmi. Once I then turned off the overscan in the menu I got a perfect 1080p image. Hope this helps. :-)
Dec 20, 2009 | Insignia Televison & Video
My insignia mp3 was formatted i need the drivers
my video's on mp3 model no.ns-dv2g r not playing would u plz tell me the solution for this .
Oct 06, 2009 | Insignia NS-DV2G MP3 Player
Insignia 42" LCD resolution > 1280x1024 w/ computer source
Salutations RandomDrone,
From reading your owners manual it appears the max resolution of the television would be 1280X1024 when using the VGA connection.
If you would like to review the manual it should be available at:
http://www.insignia-products.com/skins/skin_1/Topics/Documents/07-290%20NS-LCD42HD_WEB.pdf
Sorry, I didn't have better news.
Jon
Go Ahead. Use Us.
Jun 01, 2008 | Televison & Video
Open Questions:
Insignia 19 in. Widescreen Flat-Panel LCD HDTV Logo
124 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
