Question about Vacuums
On the KARCHAER 370, there is a split in Part No. 9.036-694 .0 Can I purchase a new part for the wand?
The clip or gasket which locks the crevice or other tool into the wand is broken & lost, can't find it listed as a spare part for dc01 absolute
The clip will not be listed as a repair part because it's not sold separately. You'll have to purchase a new wand to get the new clip.
Nov 09, 2013 | Dyson Vacuums
I have a Samsung 4320 vacuum cleaner which has started making a loud blowing noise as if the hose is split. I can't find a split in the hose and it isn't blocked. Also it isn't picking up very well. ...
Most vacuums have an air duct on the hose to adjust the amount of suction. If this becomes opened, you will hear the sound you've described and the suction will lessen. Check the wand and the hose and see if you notice a sliding piece that can be moved to enlarge or decrease an opening in the wand or hose. Use this to close the opening and your machine should work as it's supposed to.
Hope this helps and good luck!
Mar 07, 2011 | Samsung Easy 1300 Lightweight Compact...
My Dyson DC07 vacuum works on the floors, but when I pull out the extension wand the coiled hose attached to the wand collapses and no suction goes through the hose?
Hi there, it sounds like you have a blockage in the hose. I have made a video to show you how to get the hose off and linked it to this answer. It is possible to split the hose in places trying to get the blockage out so try not to be rough. If you do damage the hose you will need to buy a new DC07 hose it is a waste of time trying to repair. If this was a helpful answer please take a moment to rate it or leave a testimonial.
Feb 20, 2011 | Dyson DCO7 Animal Bagless Upright Cyclonic...
The wand that connects to the power head at the powerhead connection broke(sheared off) fine crack
Unfortunatley the Wand for your Miele is sold as an entirely assembly only. Miele does not sell pieces of this wand separately. In order to fix your wand you'll need to purchase a new wand assembly complete.
The wand on your Miele is the Miele SET210 Wand. Here's a link if you need to purchase one;
http://www.govacuum.com/miele-172.html
I would probably guess that your wand broke off right at the bottom where it connects into the power nozzle. Unfortunately this is the weakest part of the wand as you can probably see. The wand narrows into a thinner plastic here, and I've seen a few wands crack off right on the bottom part.
Please feel free to request a repair clarification if you have any questions about how to repair your vacuum.
If you found this helpful, please be sure to rate it by clicking the thumbs up icon. I really appreciate that.
Chris J.
Mar 21, 2010 | Miele s558 Silver Moon Vacuum
My Dyson dc 18 slim extender wand has NO suction. There is a plastic white cylinder object blocking.
If the floor head has suction and the wand does not, or vice-versa, the white cylinder you are referring to diverts the suction between the floor head and wand. If the flimsy plastic switch used to turn the cylinder is broken, you may need a new under carriage or just set the cylinder to wand or floor manually and use it as a one dimension cleaner. Depending on your ability, perhaps the switch can be purchases and replaced by a DIYer, but the job looks moderately difficult.
Jan 31, 2010 | Dyson DC18 Allergy Bagless Upright Vacuum
My dyson 17 wand does not work. When it is on and you stand it upright it turns off
Hi its Darran at Dyson.
If the suction is good from the base but not from the wand, this would indicate that there is a blockage in the wand handle or hose. To test this, stand the machine upright and release the wand handle. Switch the machine on and test the suction from the top of the wand with your hand. If its poor, remove the wand handle from the hose and try the suction at the top of the hose. If its good here, then there is a blockage in the wand handle.
If the sction from the top of the hose is poor, you can remove the hose to check this for any splits or blockages. If it needs to be replaced, you can buy a replacement online at www.dyson.com.
Alternatively, should you any further help or advice with your Dyson, please contact our Helpline on 1866MYDYSON.
Kind regards
Darran
Dyson Customer Service
Jan 25, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
The handle will not stay connected. You can push But when you pull back, it separates right above the off /on switch
There may be damage to where the wand connects to the back of the vacuum cleaner - you should see two grooves on the wand and two on the spine of the vac where the wand slides into - if you have any damage to either side, the wand won't click into place and stay attached to the machine. Call the Dyson helpline for troubleshooting and so that they can refer you to an authorized Dyson repair dealer if needed. If the damage is to the wand alone, you will be able to just purchase a new wand through them.
Jul 14, 2009 | Dyson DC18 all floors Bagless Upright...
Split main hose
You can attempt a repair, but you'll be luck if it remains satisfactory for very long.  The only real solution is a new hose.
Apr 20, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Using the wand works fine, but using sweeper - no suction
Forgive me if I'm thinking of the wrong model, but I think the DC07 has a short length of clear plastic tubing between the floor head and the fixed vacuum pipe-work. This tube can split and let air in which, of course, reduces suction at the head. You need to inspect it very carefully, as the split is often where it's really difficult to see!
If this is the problem, a repair with tape is possible but rarely completely satisfactory. A new bit of tube is the best solution.
Apr 05, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Vacuums Logo
746 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
