Question about Altec Lansing Multimedia Computer Speakers
I just moved my computer to another room and now can't get the speakers to work. The one speaker hooks into a subwoofer which hooks into the wall..what do you think I am doing wrong? The left speaker then hooks into the back of the right speaker. Seem simple to me, but no sound. Any suggestions?
  • 122 Answers
Double check the connection to the computer you my have pluged them into the wrong jack.
Posted on Sep 16, 2010
Power light is on but no sound from the speakers
Have u hooked them up correctly ? I did that once n the left n right were wrong way around
Oct 29, 2012 | Altec Lansing VS4121 Speaker
How to install a home theater
Follow these steps:
•Plan out your setup. Before you start unpacking speakers and moving furniture, it's a good idea to have a placement scheme in mind.
•2
Consider the location of the outlets in your home theatre room. If possible, choose a room powered by a single circuit breaker to reduce the risk of damage due to the overload your home theatre system might cause. Supplement the number of outlets with power strips.
•3
Place your TV. The television should be placed where it can be viewed straight on. The center of the screen should be aligned with the eyes of a seated person.
•4
Place your speakers before you start hooking things up. If there are hearing-imparied people in your household, place the speakers so that someone could sit directly next to at least one speaker.
•5
Position your central channel speaker above or below your TV. If you put it on top of your TV, make sure the front edge of the speaker is aligned evenly with the front of your TV screen.
•6
Place your front left and right speakers at equal distances on either side of your TV. The height of your left and right speakers should match the height of your central channel speaker.
•7
Put your surround speakers at equal distances to the left and right of where you would normally sit and view your TV. Do not point your surround speakers directly at your viewing position. Try pointing them toward the back of the room or toward the ceiling.
•8
Place your subwoofer to the side of the room, about halfway between your viewing position and your TV. You can adjust the bass reaction of your subwoofer by moving it closer to a wall to increase the bass, or by moving it away from a wall to decrease it.
•9
Connect your speakers and theater system by running flat speaker cables down the length of your baseboard or lower portion of your wall. Consult your owner's manual for exact instructions.
Mar 13, 2011 | Philips 55PFL7505DF7 55 in LCD TV
I have just moved my speakers around in my room and they were working perfectly before. Now only one speaker is playing and when i swap the inputs the other speaker will work fine but they other one wont....
check the mass terminated cable connecting the controller to the base speaker. This connection becomes flacky generally requiring a good contact cleaner solution being needed to be applied to restore the connections.
Go to radio shack and ask for a plastics safe contact cleaner then after disconnecting the mass terminated cable spray it liberly. Then reinsert while still wet then work in and out a few times. You can do this for all the cables connecting to the pc as well. This should restore your dead channel....hop it works :-)
Feb 23, 2011 | Logitech Z-2300 Computer Speakers
I have this set of speakers hooked to a Dell 3000 running under Windows XP Pro. I recently had to change offices and when I hooked up the speakers, the subwoofer wouldn't work. I've tried reinstalling the...
Please check the cable using a multimeter. Check if the cable is broken.
Just by shifting the system, I fear if you could have an issue like this. Also check the Subwoofer box if its working or not. Good Luck.
Jun 04, 2010 | MidiLand MLi SW190 Computer Speakers
Subwoofer turns on and is hooked up, but no sound.
The signal don't seems to be present to the sub input.
Try change the wire betwen the audio system and the subwoofer.
Spider Guy
Mar 15, 2010 | Onkyo 630-Watt 7.1 Channel Home Theater...
Subwoofer blows internal fuse when receiver is turned on
Has it ever worked?
Try this - connect one pair of its speaker wires at a time and test it. Watch the polarity.
• Make sure all cube speaker arrays are connected to the proper terminals according to their
position in your room.
• Check to be sure all wires are connected to your surround receiver with the proper polarity
(+ to + and – to – wires). Incorrect wiring can result in a total loss of module output.
• Correct any wiring problems before you plug in your receiver and turn it on.
Dec 12, 2008 | Bose Acoustimass 16 Speaker
New (old) house with stuff installed when we got it
IF YOU HAVE THE SAME AMOUNT OF CABLES AS SPEAKERS HOOK THESE UP TO YOUR AMP THEN SUB TO SUB OUT PUT ON YOUR AMP WITH A SUB CABLE OR PHONO THAT REACHES FROM AMP TO SUB.SET AMP TO ALL CHANNEL STEREO OR MODE THAT SENDS STEREO TO ALL SPEAKERS,ALSO SET SPEAKER SIZE IN SETUP OF AMP TO SMALL AND SUB OUT PUT TO SUB ONLY.YOU SHOULD GET MUSIC AROUND THE HOUSE.IF SOUND IN SAY BEDROOM IS NOT AS LOUD AS BATHROOM USE THE TEST TONE TO LEVEL OUT EACH SPEAKER.
HOPE THIS HELPS.
CABLE GUY.
Jun 26, 2008 | Audio Players & Recorders
Unwanted sound from subwoofer.
switch your subwoofer off from the socket for at least 30 minutes and check if the noise is still there,if its still there open it and play a movie then press it lower if the sound stops then you will have to put some toilet papers at the back of it ,thats what I did to mine.
Feb 19, 2008 | Logitech S200 Computer Speakers
Loud humming coming from subwoofer
This can be caused due to an increase in local interference. The hum is decreased when you plug in the satellites because the interference is spread over a longer area. You may notice that speakers tend to hum around things like cell phones and power outlets. To see if this is the case, move the speakers to another part of the room if you can, slide the desk around, plug the computer in at another room, something like this. If the hum gets louder or quieter, it is interference at your new place. This can be solved by finding a new area to set up your computer stuff at. Since it's mostly the subwoofer, try elevating it off the ground, there may be a power main running under the floor.
Sep 04, 2007 | Audio Players & Recorders
How to add more speakers?
In the end I biwired the speakers and that's worked fine.
Aug 12, 2007 | Denon D-M71DVS System
160 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
