Question about Microwave Ovens
Hello. my stove dont work - Microwave Ovens
  • Microwave Ovens Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Posted on Sep 17, 2010
Hello. I just received a new Glass Touch ASM (WB27T10875) for my GE stove. My previous one cracked and needed to be replaced. Problem: While installing/ connecting the ASM to the stove, once I connect the...
Funniest thing. I was having the very same problem on Monday. Every time I laid the glass touch panel down on the stove, it stopped working but worked when I held it up. After failing to install the panel so it would work for 30 minutes, I walked away from it and ate dinner. Coming back later, I decided my problem was the connections on the back side were coming into contact with the metal so I placed a tightening knob in the center of each of the outside holes making sure the underside of the knob went exactly into the middle of the hole. I then lowered the left side of the panel down to where the threads started and very carefully partially tightened the left knob so none of the panel back touched the stove. I then lowered the right side until the knob touched the knob and tightened that side finger tight. I keep testing the buttons to make sure they were still working. When the out side knobs were finger tight, I finger tightened the 2 inside knobs. Success. My oven is now working.
Aug 03, 2013 | GE GLASS TOUCH ASM WH - WB27T10873
My whilrpool stove goes in fse1 error mode and beeps constantly. even after i push cancel, it seems to reset then goes back to beeping after a few minutes without even being touched. I unplugged, reset and...
Hello jerseydev594,
You might want to visit the Product Owner Center on WhirlPool's website, which is: http://www.whirlpool.com/owner_center
My guess is that your WhirlPool stove might be malfunctioning so you might need a replacement unit if possible, Again, http://www.whirlpool.com/owner_center can help you.
Sincerely, oliver18754
Jul 08, 2011 | Microwave Ovens
HOW TO USE PRESTIGE INDUCTION COOK-TOP MODEL :pic 1.0
Dear Sir,
i have Prestige PIC 1.0 induction stove.The issue with the stove is whenever i switch ON the stove the 2 Watt Resistor in the PCB(R50 After Diode IN 4007) getting blown off.Even after replacing the resistor also I have the same issue.Can anyone help me on this that where i have to check, whats wrong in the stove.? thank you
regards,
Prakash
Bangalore
Feb 17, 2011 | Microwave Ovens
WHY DOES MY GE STOVE KEEPS FLASHING F2?
Hello mrctate. The F2 fault code indicates that there is high resistance or interference in the oven temperature sensor. The fix is to replace the oven temperature sensor. You can look at this part by going to Searspartsdirect.com and entering your model number. Once you do so you will see excellent diagrams of each of the parts of your GE stove. Joe
Thanks for choosing Fixya!
Nov 18, 2010 | Microwave Ovens
Over Stove Microwave, all works except doesn't heat
Hello. The problem you are having with your microwave is due to either a shorted rectifier or a shorted magnetron.
Regards, Joe
Dec 23, 2009 | Microwave Ovens
66993 pizza oven microwave oven combo pizza oven not heating error code f1 microwave part works
Hello, please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
Jul 20, 2009 | Kenmore 63662 / 63664 / 63669 Microwave...
Stove won't stay lit!!
So, you cleaned the burner per the manual (or the one you looked at when visiting the appliance store,) and it still flames out right after coming on? Sometimes things catch in the works and there are a few methods to clear them out (e.g. at the controls) depending on the model. Beyond that,in order to disconnect the stove and check the inlet filters, you might want to call the appliance or gas co for a technician. No use having leaks, searching forever for the main shutoff valve, etc.
Mar 24, 2008 | GE XL1800 1100 Watts Microwave Oven
Fan stopped working in JVM1533BD microwave
I assume you're talking about the hood fan which ventilates the cook top and blows air through the grille across the top. If so, it's okay to use the microwave with that not working, but if you boil something on the stove, an external fan is definitely needed to keep mositure from going up into the microwave controls. If the cooling fan INSIDE the microwave (behind the keypad) is not working, then you do NOT want to run it unit it is fixed. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your full model number (without the suffix) here: http://tinyurl.com/gv383
Apr 06, 2007 | GE JVM1542 Microwave Oven
Microwave Ovens Logo
13 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
