Question about Medion md40298 Notebook
Notebookrecovery how do you start the recovery process stored on the seperate partition on tjhe hard drive my notebook has this but norecovery cd
  • 123 Answers
Cjt002,
if u powered on ur computer,u can see something u press to go into ur bios set up right?,then at the side of that,something indicates wahat you'll gonna rpess to start recovery set up..somthing like <F11>..
Posted on May 17, 2008
Please tell how to reset my computer to factory defaults
If you Toshiba is a fairly recent laptop and there is a Restore partition on your hard drive.
To restore your Toshiba to "Out of the Box" condition then please click on this link and follow my instructions :-
http://www.fixya.com/support/r8248520-restore_toshiba_out_box_condition
Mar 11, 2011 | Toshiba Satellite L455DS5976 Notebook
Tip
How to perform an eMachine Factory Restore
Back up all of your photos, documents, folders, files, favorites (bookmarks) and anything else you would like to keep and reinstall after the system recovery. Use a CD, DVD, flash drive, MP3 or external hard drive to store your data temporarily.
Click on the "System Recovery" icon (usually found within the start menu) and begin the process by following the on-screen prompts.
Click on "restore" and note the warnings about losing all of your data. Wait for the computer to complete the process of erasing the hard drive and creating a new partition.
Insert the emachines recovery disk in the CD tray when prompted. This will start the process. There are usually one or two disks involved and the computer will let you know which ones to insert when and will even eject the tray automatically in most cases. You may have to restart at least three times, do not be alarmed by this and keep the disk in until you are prompted otherwise. do-emachines-system-recovery--1.5-120x120.jpg
Example of Windows Installation Install Windows on the new partition and follow the prompts on your screen. Be sure to choose the largest partition, the one with the most kb available. There are usually two to choose from, as you have deleted the other ones in the steps prior.
Reinstall all of your backed up data and any software programs you are currently using, including the printer and Internet, if needed. Be sure all of your drivers and hardware is working properly, as they have been reinstalled as well during the recovery process.
on Mar 04, 2010 | Computers & Internet
I just restarted my HP and now it says there is no hard drive and I dont have a recovery disk
try disconnecting the drive and reseating it first.
If you enter the bios (f10 on startup) does the computer even detect the drive? If not - try reseating it - don't forget to power off first
Failing that try the hp recovery partition
Press the power button to start the HP. Press and hold the F11 key to launch the HP Recovery Manager from the recovery partition.
Backup any files you want to save. Follow the HP Recovery Manager instructions to save any important files before continuing with the recovery process.
Continue the recovery process. After backing up files to an external device or CD/DVDs, select the option to perform a system recovery.
Obtain and install updates for the HP. After your system reboots, use HP update manager as well as Windows update to restore all critical updates to your HP computer.
5
Make a set of recovery disks. Use HP Recovery Manager and select "Advanced Options" to create a set of recovery disks that can be used in the event that your HP cannot access the hard drive.
Feb 25, 2011 | HP G60-235DX Notebook
I want to restore my hp compaq dx2200 microtower to factory setting but i lost the cd what can i do to restore it for free
Check to see if there is a recovery partition on your hard drive. Usually this will be hidden unless you know where to look for it. Here are the steps:
  1. Go to Start Panel
  2. Right-Click my computer
  3. Click manage
  4. This will open a seperate window with the title computer management on top of it
  5. In the left pane you want to look under storage and select DIsk Management
  6. This will give you a snapshot of your hard drive, if your hard drive is split into more than one partition and that partition is at the least 5-8 Gb, chances are you have a recovery partition. Run this check then let me know what you find
If you do have one, then let me know and I will walk you thru the process of booting from this partition
Aug 01, 2010 | HP Compaq Business Desktop dx2200 - P4 524...
I need help restoring my pc to factory settings
do-emachines-system-recovery--1.5-120x120.jpg Example of Windows Installation Install Windows on the new partition and follow the prompts on your screen. Be sure to choose the largest partition, the one with the most kb available. There are usually two to choose from, as you have deleted the other ones in the steps prior.
Mar 04, 2010 | E-Machines eMachines Desktop PC
My aspire notebook want to reformat but theres no cd or dvd drive on it
It should be a recovery partition on your hard disk. Try this :
Turn on your laptop. On boot, press <F2> to enter BIOS. To enable disk-to-disk recovery (hard disk recovery), activate the BIOS utility, then select Main from the categories listed at the top of the screen. Find D2D Recovery at the bottom of the screen and use the <F5> and <F6> keys to set this value to Enabled. Save and reboot. While the Acer logo is shown, press <Alt> + <F10> at the same time to enter the recovery process. Refer to the onscreen instructions to perform system recovery.
You could miss this process, if it is so try again.
If there is no recovery partition on the hard drive you need a CD revovery kit for your model. Contact Acer support team and ask for it. If you are lucky you will get one for free or you will pay a very affordable price (10-20$). If not, try to find a friend that has the same version of Windows as yours and you can use it with your activation key (you find it on a label on the bottom of the laptop).Also, you have to purchase an external (USB) optical drive (CDROM/DVDROM)
Oct 09, 2009 | Acer Aspire One PC Notebook
Second hard drive
generally, its not a second driver your seeing , it is a seperate partition on your ONE drive set aside for holdingyour recovery files incase you need to reinstall all your software back to factory settings of when it was new. The only way to access this drive is through the recovery process, otherwise its protected so not to get messed up.
Hope this answers your question. Please post again if I misunderstood your request..
regards
Apr 19, 2009 | Acer TravelMate 2480 PC Notebook
Vista instaled without cd, regain vista after defragmentation?
There is a seperate partition on your hard drive called recovery. You would boot to the recovery partition and install vista that way after reformate.
Jan 15, 2009 | HP Pavilion dv9000z Notebook
Reformating the hard drive
high level format should appear as an option from recovery cd..
Apr 19, 2008 | Toshiba Satellite A45-S150 Notebook
How do i restart my philips iqon computer from the recovery disc
Usually you just put the disk in the drive and boot/restart from it and follow any instructions. If it does'nt boot from the CD it may be that the Bios needs changing so it uses the CD Rom as the first boot device. If it is set to boot from the CD Rom and it still is'nt booting then maybe there is a program somewhere on the hard drive to start the recovery process. It could be on a seperate partition if you have one.
Mar 26, 2008 | Computers & Internet
Medion md40298 Notebook Logo
157 people viewed this question
Top Medion Computers & Internet Experts
John Anderson
John Anderson
Are you a Medion Computer and Internet Expert? Answer questions, earn points and help others
