Question about Kenmore Dryers
I have a kenmore elite gas dryer model # 70992990
  • Kenmore Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 16, 2010
Kenmore Elite 11072972101 gas dryer will not stay on after I push the start button. What is wrong and how do I fix it.
If you HOLD the start button down and the drier heats and runs, then your problem is most likely a relay which is supposed to energize (close contacts), which "latches" the condition when you push the start button. The most likely cause of such a failure, is a fuse or a thermal cut out, which has prevented normal operation. For safety reasons, being a gas appliance, I would NOT ATTEMPT to fix this problem yourself, unless you have licenses to service such equipment!
Apr 17, 2017 | Kenmore Dryers
Kenmore elite dryer that wont stay on and wont heat...I push the button it runs let go it stops and it doesnt heat up even after holding the button down
heatman101
Mar 19, 2011 | Kenmore Dryers
My kenmore elite dryer wont stay running after you push the push to start button. it starts runs only if you hold the button down. which i did for a shot period of time and also notice no heat starting...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer Repair - The
heatman101
Jan 16, 2011 | Kenmore 63942 Dryer
Dryer will not stay running
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
May 10, 2010 | Kenmore 63942 Dryer
CHECK THERMAL FUSE #3392519 @ $15.00...RDS
Apr 21, 2010 | Kenmore 63942 Dryer
My Kenmore dryer "Start" button does not stay depressed.
a complete model # from inside the door would be helpful, on wost dryers when this occures the motor is packed with lint so the sentrifisle switch cant move from the pastion to the run or the switch on the motor itself is bad, the run windings in the motor could be bad. some of thethe more complicated dryers have a relay on their control board than burns out. try blowing out the motor with compressed air or the blow end of a shop vac use the skinney attat. to concentrate air
Dec 08, 2009 | Kenmore Elite Oasis 6808 Electric Dryer
Kenmore gas dryer doesn't stay running have to hold button down.
POST MODEL NUMBER, BUT IT MAY BE THE MOTOR START SWITCH.
Apr 18, 2009 | Kenmore 73952 Gas Dryer
Kenmore elite dryer model #110.63952102 start button wont stay on everything else works
I have the same problem with my Kenmore Elite dryer (model#110.74992300), and I replaced both the motor and heater relay and the problem solved. You can get the relay from www.mouser.com for $3 each. The model for the relay is T9AP1D52-48. You may want to open up the dryer to verify the relay model, it is printed on the relay.
Sep 20, 2008 | Kenmore Elite 20972
Need help with OLD dryer
IF YOU MEAN THAT THE DRYER STARTS BACK UP WHEN YOU CLOSE THE DOOR, THE PUSH TO START SWITCH IS SHORTED. CHECK TO SEE IF THE PUSH TO START BUTTON IS STUCK PRESSED IN AND NOT SPRINGING BACK OUT.
IF IT IS STUCK, TRY WD-40 TO LOOSTEN IT. OTHERWISE, REPLACE THE SWITCH.
IF THE DRYER KEEPS RUNNING WHEN YOU "OPEN" THE DOOR, THE DOOR SWITCH IS SHORTED. REPLACE THE DOOR SWITCH.
Mar 31, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
115 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
