Question about Uniden Bearcat Pro PC68XL 40-Channels Base CB Radio
Radio has no forward power. I shorted something on the solder side of the board and now i have no forward power
  • trucker_dan1 Sep 17, 2010
    Thanks for your advice. I don't think the final is bad and I even went as far as to change the driver. It does have some power. I have a 3 way anttenna switch and if you have another radio kooked up it will transmit to the other radio but the audio souns real fuzzy but there is no forward wattage on my power meter. What transistor should I check. I'm pretty new to this radio repair thing and any advice you have is greatly appreciated
  • 22 Answers
You may have shorted the finals, especially if the location is to the edges of the chassis. Have the output transistors checked with an ohmmeter with the leads unsoldered. Without further details, anything on the board could have been shorted.
JTRadiojunkie
Posted on Sep 17, 2010
Intermittent no transmit not all the the time hw do fix ?
It sounds like you have a cold solder Joint on the Board of your radio. You will need a power supply, a watt meter, dummy load and a 30 to 40 watt soldering gun, solder and solder wick. Chem wick makes the best solder wick. DON'T buy the solder wick from Radio Shack.
Take a non Metalic item lke the handle of a screwdriver and tap around on the bottom side of the PC board litely untill you find the general area that is causing the problem. Start solder different points on the board until you find the joint that is causing the problem. If you accedentally put too much solder use the solder wick to remove the extra solder. This is time consumming and you must be careful as too not short out the radio. Also the solder gun must be isolated from ground.
This is not a job to be taken litely. I would reccommend taking the radio to an experianced Radio Technician unless you feel that you can handle the job.
Patrick
Jul 16, 2011 | Magnum Radio Communications
Matsui dabr103 radio display lites up blue with no onformation no sound Mine does that, plug it in just get the blue display. Nothing else.
First try unplugging the power cord for five minutes.
If it does not work try pressing power button for ten seconds.
If still no luck, then it is faulty.
Oct 18, 2008 | Audio Players & Recorders
Tip
Building Power Supplies
Get you a 12 to 15 volt Transformer. Buy two big power diodes from Radio Shack. A capacitor 100uf to 470uf that handles 16 volt or 20 v. Buy two 0.01uf Disc capacitors. Get you a board 6x6 inches. Bolt down transformer to board. Hook leads to Diode like this: One lead to Striped side of Diode(1). the other lead to Diode(2) opposite side. Use capacitor 470uf (+) to striped side of Diode(2). Use capacitor(-) to Black side of Diode(1). Make sure polarity is right + - etc..Solder 0.01uf capacitor across Diode(1) and Solder other 0.01 uf Capacitor across Diode(2). Parallel wise. This Bypasses Rf so you get no Hum. There you go simple 12 Volt DC current to run mobile radios indoors.
on Apr 01, 2011 | Radio Communications
When i turn it on ..... i see smoke pls help
Do you like your radio medium or well done?
You may have hooked your power wire up backwards at some point and blown the polarity protection diodes.
This requires opening the radio and using a soldering iron to remove and replace the blown diode.
You will need:
1. Soldering Iron
2. Solder
3. De-soldering braid
4. N1004 diode or better.
5. Phillips head screw driver.
Using the phillips head screw driver to take the bottom cover of the radio off being careful of the speaker wires. Using the soldering iron, heat the solder on the tabs of the speaker and pull off the wires. No need to use the de-soldering braid to remove the solder. You should do this to make it easier to handle the radio, and to avoid damage to the speaker or wires etc.
Now take the cover off the top of the radio. This will reveal the "Trace" side of the board. This is where all of the components are soldered to the board.
Now flip it to the other side where you can see all of the components and wires etc. Look at the back right of the radio by where the power socket is. Look for D23. its a big black diode. It will most likely be black and burnt. Some times it may not be.
Here is the tricky part. You need to locate the points at which this component marked D23 is soldered to the trace side of the board. Some times you can use a bright light and look at the trace side of the board while the light shines on the other side to locate the part.
Once you have located the points at which the diode is soldered too, do not de-solder it yet. Make note of which side of the diode the white band is on. This is important, putting the diode in with the wrong polarity will make the radio not work.
After you take note of the white band you may now use the de-soldering braid to remove the solder from the trace side of the board. To do this, place the braid over the solder point. put the tip of the soldering iron on the braid and press it down to the solder point. You will see it **** the solder into the braid.
Once the solder is off both solder point, flip the radio and remove the bad diode.
Put the new diode in, making sure the white band is on the same side as the original diode.
Once again flip the radio over to trace side of the board and solder the new diode in. To do this place the tip on the solder point, making sure to touch both the solder point of the board and the wire from the diode. take the solder and touch it to the solder point, not the soldering iron tip. Once enough solder is on the point you can remove the soldering tip. Don't use too much solder.
Once both points have been re-soldered, solder the speaker wires back to the speaker. Red is positive, it connects to the tab marked by the positive symbol "+". The white wire is negative. It goes to the negative symbol, "-". You can just reheat the tab, and put the end of the wire into the melted solder and remove the solder tip while holding the wire in place until it cools enough harden again.
After the speaker is re-soldered, Put the covers back on. Now be very careful hooking up the radio to power. If you hook it up backwards again it will blow the diode again. Once the power wire is connected, turn on the radio, it should work fine at this point.
Good Luck!
Nov 16, 2010 | Cobra 29 WX NW ST 40-Channels Base CB...
I have a Cobra 19 plus that doesn't turn on what do I need to check?
You have hooked your power wire up backwards at some point and blown the polarity protection diodes.
You will need:
1. Soldering Iron
2. Solder
Now flip it to the other side where you can see all of the components and wires etc. Look at the back right of the radio by where the power socket is. Look for D10. its a big black diode. It will most likely be black and burnt. Some times it may not be.
Here is the tricky part. You need to locate the points at which this component marked D10 is soldered to the trace side of the board. Some times you can use a bright light and look at the trace side of the board while the light shines on the other side to locate the part.
Good Luck!
Oct 20, 2010 | Cobra 19 Ultra II CB Radio
When i hook up my cobra 29 Ltd to my pickup it keeps blowing fuses, red to postive and black to negative..Cannot figure out whats wrong
You will need:
  1. Soldering Iron
  2. Solder
Good Luck!
Oct 07, 2010 | Cobra 29 LTD CB Radio
When i plug it to the power cord it blows the fuse
You will need:
1. Soldering Iron
2. Solder
Now flip it to the other side where you can see all of the components and wires etc. Look at the back right of the radio by where the power socket is. Look for D93. its a big black diode. It will most likely be black and burnt. Some times it may not be.
Here is the tricky part. You need to locate the points at which this component marked D33 is soldered to the trace side of the board. Some times you can use a bright light and look at the trace side of the board while the light shines on the other side to locate the part.
Good Luck!
Sep 14, 2010 | Galaxy Radios DX-66V Base CB Radio
No power
You are so right, there is a short.. This is usually a result of hooking the power leads up in reverse-polarity. As a result, the protection diode shorts, preventing the death of the rest of the radio. This diode, a solder-in part, is found on the pc board, next to the red wire that connects from the DC power jack. A 1.5 amp general purpose diode will work. And don't use a 30 amp fuse.
Jan 23, 2009 | Cobra 25 LTD 40-Channels Base CB Radio
Magnum delta force
What you saw smoke was the protection diode. I do not have one of these radios and have not worked on one yet, but most radios are the same where the protection diode is located on the pc board, one the components side, close to where the wire from the main power positive pin is soldered into the pc board.
I will have to do a little research to see if I can come up with the number of the diode. I have a couple of diagrams and a schematic from cbtricks.com. If I can not located it from their informaiton, I can contact my supplier Monday to see if he can tell me the number. If you happen to located the burnt diode before I come up with the information, please respond so I will know.
Dean Pitts
Rollin CBs
Nov 01, 2008 | Radio Communications
Uniden Bearcat Pro PC68XL 40-Channels Base CB Radio Logo
199 people viewed this question
Top Uniden Radio Communications Experts
Jason
Steve
eradiostore
eradiostore
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
