Dump waste out of tank but the printer still will not print.
    President:
  • 2,571 Answers
It wont unless you now reset the waste ink counter.
Just google your printer model and reset waste ink counter
Posted on Sep 16, 2010
HP Officejet J5780 Waste ink tank full
Hello, if the waste tank is full, just take it out, and dump it out over a trash can. Do not waste money on a new one, because you can just empty this one. Just dump it out over a trash can and you should be good to go.
Thanks for using FixYa!
Aug 15, 2011 | HP Officejet J5780 All-In-One InkJet...
Canon BJC- 1000 LPT 1 printer. STATUS: the used ink tank is full. printer not performing.
HI,
Your printer has a built-in waste ink tank for the ink used during print head cleaning. As time goes by, the waste ink tank gradually fills. When the waste ink tank is nearly full, you should receive a "Waste ink warning" error when you print. Press the RESUME button on the printer to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, have the waste ink tank replaced.
Jul 08, 2008 | Canon Office Equipment & Supplies
How to clean waste tray
The printer uses an optical sensor to determine when the tank is full. There are clear plastic ports on the side of the tank that the light needs to penetrate in order for the printer to work, otherwise it will generate waste toner tank full error and stop printing.The easiest way to clean the waste toner tank, is to remove it from the printer, and dump the contents into a trashcan. Tap it a few times to get as much as you can. Then take some soap and water and partially fill the tank. Then take the green cap and place it over the tank opening. Shake the soapy water in the tank a few times to clean it. Then dump the soapy, toner water in the sink. Add some tap water into the tank and replace the cap and shake then drain. You don't need to get the tank completely clean, just enough to allow light to past through the clear plastic port. Dry the outside of the tank and and reinstall into the printer. Hope this helps you.
Dec 14, 2010 | Samsung CLP 300 Laser Printer
I keep cleaning the toner/printer waste tank cartridge and the printer continues to stop printing and the same error message displays saying "Replace/Install waste toner printer cartridge.
How are you cleaning the tank? Just dumping the contents into a trashcan may not work. The printer uses a light sensor to detect whether the tank is full. When the light does not shine through the clear window of the tank, the printer thinks that the tank is full. Sometimes cleaning the window with a cotton swab will make it work, but it can be difficult since the location of the window with respect to the opening of the tank is not a straight shot.
Another way to clean it would be dump the waste toner into ther trashcan. Tap the tank a few time to get as much of the toner out. Then add some soap and water into the tank and seal the tank opening with the green lid. Then shake the soapy water in the tank for a about a minute. Then dump the soapy toner/water out. Rinse again with just water and and allow it to dry. You don't have to get the tank completely clean, just enough to stop the waste tank error message.
Hope this helps.
Nov 17, 2010 | Samsung CLX 3160fn All-In-One Printer
Wont print
Usually with most samsung printers they have a toner waste bin in the printer. As you print, the waste toner dumps into this bin and fills up over time. Your printer manual may tell you where this is, but usually its right in the front of the printer when you open it up. It usually looks like a white or black plastic bin. There should be a plug on it that you can pop off and dump out the waste toner. After doing that put it back in your printer and it should get rid of the message.
Hope this helps :)
Apr 30, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
Tank absorber full and lights blinking
The POWER Lamp Flashes Orange Eight flashes: Waste ink tank almost full
The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, contact a Canon service representative.
Note
Canon recommends that you call for service as soon as this error occurs. Once the waste ink tank becomes completely full, printing will no longer be possible.
Sep 14, 2009 | Canon i350 InkJet Printer
My Canon I550 quit printing.
An error has occurred in the printer. The number of flashes indicates the type of error, as outlined below. Check the cause and take the appropriate action.
bullet.gif Two flashes: Out of paper or paper feed error
Replace the paper correctly and press the RESUME/CANCEL button.
bullet.gif Three flashes: Paper jam
If paper has jammed in the printer, clear the jam, replace the paper in the printer correctly and press the RESUME/CANCEL button.
See Paper Jams
bullet.gif Four flashes: Empty ink tank
If you press the RESUME/CANCEL button, it will continue printing with an empty ink tank. However, when printing is finished, replace the ink tank immediately. If you continue printing with an empty ink tank, it will be a cause of trouble.
See Replacing an Ink Tank
bullet.gif Six flashes: No print head installed
Install a print head.
bullet.gif Seven flashes: Defective print head
Contact a Canon service representative.
bullet.gif Eight flashes: Waste ink tank almost full
i_note_us.gif Note
Canon recommends to call for service as soon as this error occurs. Once the waste ink tank becomes completely full, printing will no longer be possible.
bullet.gif POWER lamp flashes alternate green and orange:
An error that requires contacting a Canon service representative may have occurred.
Turn the printer off and unplug the printer from the power supply. Plug the printer back in and turn the printer back on.
If the problem remains, contact a Canon service representative.
Apr 14, 2009 | Canon BubbleJet i550 InkJet Printer
Zebra LP2844 printer prints garbage
Sounds like you might be using a bad driver, or the printer is in dump mode.
Try hitting the green button and see if it says exiting dump.
If still having trouble, inside the printer it tells you that if you are having printing trouble:
  1. turn off the printer
  2. Hold down the feed button
  3. turn on the printer and at the third red flash release the feed button
  4. it will then feed some pagessome info and ask you to hit feed again to exit dump
  5. hit feed again and it will say exiting dump
This process re-reads the label length (so only do it with the labels you want to use in, or it will waste labels until you do it again with those in it) - but I'm suggesting it only because it enters and exits dump mode (which I have read can cause the garbage when you try to print).
Mar 06, 2009 | Zebra LP 2844 Thermal Printer
WASTE TONER TANK
1-Open the front panel below where the paper comes out (says Samsung on it).
2- On the lefthand side is a lighter gray/tan handle. Pull it. This is the waste toner cartridge. **BE CAREFUL** this stuff goes everywhere and make a mess!
3- Dump it somewhere the dust wont offend
Jun 12, 2008 | Samsung CLX 3160fn All-In-One Printer
Printer not printing
On the machine there is a sensor that looks trough the waste tank even though you have wiped it clean the likely thing is that the sensor cannot see through the plastic waste tank.
I suggest vacuum the waste tank out until all the toner has gone then install it. If you cannot get rid of all the toner then wash the tank out and leave to dry then install it.
Hope this helps you
Thanks J
Jan 05, 2008 | Samsung CLP-500 Laser Printer
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
