Question about Manfrotto 503HDV Head and 351MVB2 Tripod Video Kit
My Manfrotto 701HDV camera head comes unscrewed from my tripod when I pan with my video camera. How do I secure my 701HDV camera head to my tripod? I've tried everything. I didn't receive an user manual when I purchased my camera head at Broadway in Vancouver, Canada
CompuGuy44
  • 432 Answers
SOURCE: Bogen Tripods, changing heads.
I searched around and all I can find is this: http://www.manfrotto.com/Jahia/site/manfrotto/pid/2477
Posted on Jul 03, 2007
SOURCE: How to Unscrew SLIK tripod head from the rest of tripod?
I found the info on the following site worked for a Slik 35D tripod, and I expect it would work for most tripods. http://eit.tamu.edu/TDD/tddtripo.htm
Posted on Sep 12, 2007
  • 24 Answers
SOURCE: Breakdown Manfrotto 3265 ball head from 190xb tripod
IT SOME TIMES TAKES A LOT OF EFFORT TO SEPARTE THE HEAD FROM THE TRIPOD. MAKE SURE YOU REMOVE THE 3 LITTLE SCREWS FROM BELOW THE HEAD, AND MAKE SURE THE TRIPOD AND HEAD ARE NOT COLD. IF THEYA RE WARM THEY WILL SEPARATE EASIER.
Posted on Jan 30, 2009
SOURCE: Removing Tripod head from center post on Manfrotto Modo 785B
I have the national geographic branded version. Here is how you remove the head.
(1) remove the center post from the tripod
(2) lock the ball head with the trigger lock
(3) grasp the body of the ball head with one hand and the center column with the other.
(4) turn counter clockwise.
If you're intending to replace the ballhead, be warned that the thread is non-standard. I have a new "plug" with a standard 1/4" thread made for free by the machinist at my job. I don't know how you would go about adapting it without such a capability.
Posted on Feb 06, 2009
SOURCE: Need a user guide for a Manfrotto Bogen 3265 grip action ball hea
Hi, This should get you to what your looking for, Go to this web site : http://www.manfrotto.com/Jahia/spareparts/site/manfrotto/cache/offonce
Posted on Feb 25, 2009
Whilst trying toromove the 168 ball head from my manfrotto art055 tripod the head became loose on the central column. How can I fix it back
There is a video at: http://bogentripodparts.com/repairs.htm
the one on the right shows you. It is usually remove the 3 screws and a little force to unscrew the head.
Apr 02, 2014 | Manfrotto Photography
How should fluid heads be stored?
Alisa: With all 'video tripod heads'...., regardless if the are the original 'true' fluid heads (that actually used a liquid (oil) to achieve 'fluid' type movements) or a modern professional 'fluid' head (that actually uses a clutch mechanism like a cars transmission) or a fluid effect head like the Manfrotto #501HDV (which used nylon discs sandwiching a ball bearing race)...., always store with the pan and tilt mechanisms unlocked!!!! This means the camera platform should be positioned in the 'rest' position (not tilted forward or backwards), also ensure that any counterbalance mechanism is released so as to eliminate strain on the internal mechanisms!!!!
If you remember to do this and don't overload the head..., you will extend the life of your gear significantly
Peter
Nov 12, 2013 | Manfrotto 501HDV Pro Video Head Tripod
There's a wiggle when I try to pan side to side (so there's always a slight **** in the video). This is a fairly new tripod (Manfrotto 7321yb), so not sure if it's a defect, or something that I need to...
The first thing that comes to mind with this issue is that this is not a real video tripod. This is a still tripod. With that said you might just want to try to make sure the pan/tilt locks are fully unlocked, then move the head back and fourth quickly (without the camera attached) for a few seconds to actually warm up the head.
Hope that helps!
May 03, 2011 | Manfrotto 7321YB Tripod
I can't unscrew my manfrotto 3433 tripod head. How do I do it?
Extend the center column to its fullest and look underneath, you will see three slotted set screws. Looses then off (they don't normally need to be removed but loosed well) and make sure the pan on the head is tight and just unscrew it from the column. You can have it off in less time then it took to write this solution. Cheers
Jan 30, 2011 | Cameras
The Pan Tilt Head cannot be removed from my Manfrotto CXPRO3
Extend the center column, there are 3 screws underneath that when unscrewed will allow the head to be tightened or loosened. The head is screwed on about 4 or 5 revolutions. You will need a flat head screwdriver. Take the center column out if you need to to be able to get to the screws.
Aug 24, 2010 | Manfrotto BOGEN 804RC2 Basic Pan Tilt Head...
I'm trying to attach a Canon EOS Rebel XS to a Manfrotto 190XPROB tripod, but the tripod socket on the camera is too small. How do I attach them?
You need a head. The tripod has a standardized screw for accepting a tripod head, which is a larger screw than for the tripod mount on the camera. There are a variety of heads available, ball heads, three-axis heads, geared heads, pan-and-tilt heads, and more.
Here's a page showing Manfrotto heads:
http://www.manfrotto.com/Jahia/site/manfrotto/cache/off/pid/1888?livid=80&idx=80
Aug 11, 2010 | Cameras
Which head do i buy with the manfrotto 055xprob
Any head that matches your requirements. Do you want a ball head? A tilt-and-pan head? How much weight will have it to support? The tripod comes without a head because no one except you can decide which is the best head for you.
Aug 02, 2010 | Manfrotto (701RC2055MFV) Tripod
Manfrotto 322rc2 tripod ball head
here is manfrotto's "How To" site, they have illustrated how to use almost all of their products.
http://www.manfrotto.com/Jahia/site/manfrotto/cache/offonce/pid/2475
hope this helps out. if you have other questions please lemme know
Nov 04, 2008 | Bogen Communication Bogen Manfrotto 322RC2...
Attaching head to tripod
video cameras come with a 1/4-20 threaded socket in the.  Make sure the 3066 has this size screw projecting form the place where the camer is attached.  The two Manfrotto should be compatible
The only time fitting together becomes a problem is if you are into the heavy duty professional equipment.
We especially like the Manfrotto fluid heads and have several in our facility.
Nov 01, 2008 | Photography
Manfrotto 503HDV Head and 351MVB2 Tripod Video Kit Logo
493 people viewed this question
Top Manfrotto Photography Experts
JP Services
JP Services
Mitch Davis
Mitch Davis
Are you a Manfrotto Photography Expert? Answer questions, earn points and help others
