I have a sony Bravia KDL46VL150 lcd TV The tv Worked ok for a while but now it shuts off to standby and flashes 6 times it will turn on after a while but it keeps happening
After about a year my set developed this problem. I found that updating the firmware to Software Update Filename : ER4.12 46VL150.zip Version : ER4.12-E2 Last Modified : 08/23/2010. You can check the firmware version you are running via Menu - Set Up - Product support with your remote. Go to the Sony support site and search for KDL-46VL150 to find the file to download. Unzip it onto a flash drive, turn the set off, put the flash drive in the service USB port on the back and turn the set on. The sony site has detailed directions.
Posted on Feb 25, 2011
Sony Bravia KDL-46W3000 - Shuts off after 30 sec followed up with 6 red blinks.Last 3 days back cover off has been working fine. What board should I be replacing?
Sony Bravia TV kdl- red blinking led light error codes ...
? 10:28
https://www.youtube.com/watch?v=0KGysXbxnaU
Mar 28, 2015 - Uploaded by Tampatec
Sony Bravia LCD TV KDL models red blinking led light error codes & possible ... with perfect picture, no warning signs and it just shuts off. is it that quick? ... with the following problem: I connect the power grid lights Standby red light. ... the title before deleting, it is very fast after that flashes Standby 6 times.Missing: 46w3000 ‎30
Nov 18, 2015 | Sony BRAVIA KDL-46W3000 Television
Sony Bravia 46" The standby light flashes four
If tv model number is KDL-46S2000 then 4 times blinking standby light indicates back light failure problem in your tv.
Check/ replace back light inverter boards to solve its problem.
Thanks.
Dec 29, 2010 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
My KDL sony tv turns on briefly(displays menu) then shuts down, and standby led flashes 6 times then pauses then continues, does not respond to the on/off button or the remote
6 times blinking standby light indicates problem with Audio Section in tv
Check AU 15V output of G2 (power supply) board then check AU board as it has sound processor and sound output ICs.
If you are not familiar with electronics stuff repair then call local tv repairman to repair it for you.
Thanks.
Oct 29, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
My Sony Bravia, model KDL-46XBR4's standby light is flashing 6 times. We have reset it 3 times but after several days it shuts down and continues to flash the standby...always 6 times. Can anyone tell...
I am experiencing exactly the same problem. TV turns on but within 60 seconds the screen goes black and the red standby light blinks six times. Were you able to resolve this problem on your TV?
Oct 17, 2010 | Sony KDL-46XBR4 46 in. LCD Television
I have a KDL46VL150 that has started cutting off after viewing for a while. The standby lights blink a sequence of 6 times. Usually if i unplug or cycle power to off and wait a bit it will return to normal...
It indicates that there is an internal malfunction within the TV. You can try Power reset.
To Reset the TV, please disconnect the power cord for a short period of time (approximately 1 minute). Then, reconnect the power cord and power on the TV.
You can also try connecting the TV directly to the wall outlet.
If the issue persists, I suggest that you get the TV serviced to fix the issue.
Jul 12, 2010 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
No Display
mainboard damaged and need to be replaced
Jul 09, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Sony Bravia standby light flashing 6 times
there is a bad ground may on the cable check the voltage on the cable & set if on cable call the cable company. if tv call sony they may help with cost may be still under warranty
Jun 27, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Standby Indicator flashes red 6 times between 2 second intervals
My TV (Sony Bravia LCD KLV-32S310A) goes of after 20 seconds when it is switched on. The standby indicator then flashes (red) five (5) times then there is a two seconds break followed by another six flashes then two seconds break etc. What might have caaused this and what should i do?
Apr 13, 2009 | Sony Televison & Video
Televison & Video Logo
792 people viewed this question
Top Televison & Video Experts
