Question about Frigidaire Washing Machines
Water is leaking out of the bottom of the tub. How do you take the machine apart to see where the leak is?
  • punky0518 Sep 16, 2010
    you have not helped me at all.
  • 2,272 Answers
There are two types in washing machine. 1) The front load washing machine. and. 2) The top load washing machine.----------------- Now in both load washing machine.There is a model number for the machine.You have not mentioned the details for your machine.So the exact details cannot be provided.But no worry.there is one online site.That will help you to give the detailed procedure to disassemble your washing machine.You just have to insert the exact model number of your Frigidaire Washing Machines and press the GO button.You will be shown exact disassembly diagram for your machine. Just click on the link directly:-- http://www.searspartsdirect.com/partsdirect/index.action ------------ In any case if you dont get the disassembly diagram for your washing machine.Please reply.-------------
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Sep 16, 2010
  • raj somaiya
    raj somaiya Sep 16, 2010
    Ok.But i have asked you about the model number of the washing machine.and which load it is.Please at-least give proper details.Then only i can give exact details.There are hundreds of Frigidaire Washing Machines .so of which washing machine you want details for taking apart.
    Please keep updated with proper details.Thanks.
  • 262 Answers
SOURCE: leaking water from bottom of tub
this is bad it needs a center seal/bearing kit this is qite common in the Amana / Maytag line.they are kinda hard to install you may need a service tech to do this for you the kit runs around 80.00 dollars and has instructions. if you need more help you can email me at familyappliancerepair@yahoo.com
Posted on Dec 07, 2007
SOURCE: leaks water frim front of the machine
how do i remove the front cover of washing machine???
Posted on Mar 02, 2008
  • 185 Answers
SOURCE: Leaky machine
check the pump and your hoses
Posted on Mar 31, 2008
aborcass
  • 2651 Answers
SOURCE: worn outer tub
yea youl need to replace the tub alright, cgances are the bolts holding the inner tub to the transmission shaft have also broken off, which is why the inner tub spun off kilter and rubbed a hole in the outer tub,. the bolts (2 of them ) woulds have benn locking the inner basket to the tranny shaft, visible after removing the agitator
Posted on Apr 15, 2008
Maytag317
  • 1136 Answers
SOURCE: leaking water from the bottom
Hi, If you coukd get me a model #, I could look this up and give you ideas om how to locate pump to see if it is leaking.
Vic
Posted on May 30, 2009
My GE topload washing machine is leaking
Check the hose that connects to the bottom of the tub to the drain hose. Make sure that hose is securely fastened.
May 29, 2012 | GE Washing Machines
Leaking water from bottom
Hello there:
If the washer leaks all the time, check these: Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate. Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician. Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it. Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub-
Apr 18, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer overflows after taking it apart
You may have missed something when putting it together. Take it apart again then check and properly install the following:
  1. Water inlet valve. It may not be able to shut completely when the electricity has been turned off. The valve may leak and drip water into the clothes tub. Water may accumulate substantially and overflow.
  2. Water level switch. This switch senses the water level in the clothes tub. It is usually a diaphragm device with a small clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the air pressure in the tube increases and activates the switch when the water reaches a certain level. When the switch is obstructed, it cannot tell the water to shut off and the machine overflows.Clear it from any obstruction.
Aug 23, 2009 | Kenmore Washing Machines
What is the model number? and year made?
Hose could be loose and leaking. Check and tighten all hoses first if problem persists, check if water valve is leaking. If not check the tub for leaks. If tub is leaking you may not want to fix as this is an expensive problem. If you want to fix use part number and call First Source Parts and as for a Washing Machine Tub.
Jul 05, 2009 | GE WNRD2050DWC 3.5 Cu. Ft. Commercial...
Leaking below washer
Sounds like you have a leak from the tub. Either the seal in the bottom of the tub or a hole in the tub.
When you run it again try feeling around the bottom center of the tub for water or try to see if water is leaking any where out of tub. Clear water would be from the supply line , soapy water would be from tub or a hose coming out of tub.
Jun 09, 2009 | Washing Machines
Ge washer leaks when you let it fill to top
feel in the back of your outter tub towards the top and chances are you will find a hole ge's love doing this if it is not under warranty you can repair with some JB weld with out replacing the tub
Oct 09, 2008 | GE WBSE2090A Top Load Washer
GE Top load washer.
Hello rschneeweis
Welcome,
Sounds like a seal or drain hose is leaking or the clamp on a hose has vibrated loose.
Water leaking out the bottom of the machine when washing machine begins agitation cycle. If the machine is turned off the water stops leaking even with the tub full of water.
Let me know if you found it and how you do.
Huuum
Please remember to leave a rating
Oct 04, 2008 | GE WBSR3140D Top Load Washer
Leaking water from underneath.
sounds like several problems. sounds like your boot stem/ seal is leaking and possibly the tub bearing is rusted. I generally replace both at the same time as long as the machine is apart anyway. As for the squealing and tub slamming to a stop, that is your brake package and bearing have dried and/or rusted and need to be replaced
Dec 25, 2007 | Maytag Ensignia 3.3 cu. ft. Top Load...
Washing Machines Logo
60 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
