Question about ASUS Eee 4G Notebook
Usb/sd My eee 4G was working fine yesterday but today says that I don't have permissions to access SD cards or USB drives. I'm not too familiar with linux, any ideas?
  • 2 more comments
  • Anonymous Jun 27, 2008
    Same problem, started today after working fine all year.
  • mittaljp2003 Aug 13, 2008
    I am not able to transfer any data from a USB stix to ASUS Eee PC working on Linux.Actually I want to project my powerpoint slides made earlier on windows powerpoint Platfom thru my light Asus Eee Pc.Can anyone pease help urgently Jai
  • mhar153 Sep 02, 2008
    Suddenly can't access USB devices
    Tried to load a power point presentation, not enough permissions!
  • memac Oct 01, 2008
    Mine too was working fine then all of a sudden it can't access SD cards and some USB Flash drives. It does still work with one of my flash drives but not the rest. I didn't do anything to change it. The one that still works comes up under 'All File Systems/Media/data' the ones that don't come up under '/home/user/MMC-SD'.
    Guru:
  • 155 Answers
Try opening a terminal (Ctrl + Alt + T) and type sudo bash.
This should give you access to everything.
If this does not work then I am not too familiar with linux either so I probably cannot help.
Mowcius
Posted on Jul 14, 2008
How connect the micro sd to a laptop
look on one of the online auction sites for a micro sd to usb adapter
Dec 19, 2013 | Maxell Electronics - Others
The Eee pc 701 has only 4g hdd and in order to extend the hdd memory it is advised to use an SD card of Min 16gb as windows 7 will take up 4gb, the comp is not recognising the sd card
in the commandprompt:
1.sfc /scannow
2.checkdisk
3.Control Panel - Device Manager - USB Serial Controllers - RIGHT CLICK on EVERYTHING and UNINSTALL
all except the category itself - REBOOT
Dec 18, 2013 | Cell Phones
I want to install windows 7 on my eee pc 701 and the 32Gb sd card does not show on the boot sequence
SD cards aren't able to boot, they only get activated once the operating system has loaded its driver. You will need to install Windows using a USB drive. To create the drive you will need to use the Microsoft USB tool found here.
Dec 17, 2013 | Cell Phones
I have a PNY usb 2.0 combo. The usb ports work fine and read external drives etc. The SD readers quit working. The SD cards read fine on the internal mounted reader. My PC recognizes the drives, and t
I bought a deer cam (trail camera) at Walmart and a PNY card with PNY Multi-Slot USB & Flash Card Reader P-UBSDRDR21K-RF. I can't make them all work for me. PNY card reader has no instructions on the package neither on their website and their support is a joke. When I plug in this multi-slot card reader into my PC (I tried two different PCs) something isn't right. I get no results, just empty folders. The card is new and has data on it. Both products come from PNY, both were purchased at Walmart and both are going back to Walmart for a full refund and I will never buy a PNY product ever again.
Feb 14, 2013 | PNY Memory Card Reader and USB Hub Combo
How can I backup files from a SD Card before formatting it ?
Put the card into a card reader, either built-in to your computer or attached via USB. The card will now appear to your computer as another hard drive. You can then use the operating system's drag&drop to copy the card contents to a folder on your hard drive. Or you can use any backup program.
Dec 19, 2012 | Sony 4gb Card Fit Cybershot Dsc-w310,...
Screen is broken. Phone works. Have SD card. Either need to know how to transfer internals to SD card or download app to transfer to computer. I am loyal lifelong customer to CASIO because it is the...
HI.In order for you to transfer files from the SD card ,you need an SD card reader.Just insert the SD to the card reader and connect it to the computer using a USB cable .Once done access that device on your computer.You can acces it through--My C0mputer--drive E:removable device.Thank you for choosing FIXYA.
Aug 11, 2011 | Casio G'zOne Rock Cell Phone
How do i take off the write protection off my sd card
not sure about sd card
USB drives can be write-protected by modifying the StoreageDevicePolicies Registry key and WriteProtect Registry value.
click Start>run>regedit to open Registry Editor. and press control+F to open the find dialogue box and type "usb device" or "driverdesc" to open usb mass storage device or type "usb mass storage device" in the search windows. And right click on it and delete. This will set the policy value to 0. then insert your usb device. It will work fine.
# Remember: do not delete any unknow files in the registry as this will make some programes not work as usual.
also
If you are running a Windows XP OS then you might be able to:
- click start right click on my computer select open
- Right click the icon of your Flash Drive (It should be F:/ or something)
- Click Properties in the menu that comes up
- Click the Sharing tab
- Click permissions
- And finally, click Allow next to Full Control.
hope this helps
don
Feb 21, 2011 | PNY 2GB microSD Memory Card
I have the same problem but does not have a sd card can a flash drive be used in the same way as the sd card
First, A netbook that use SD card doesn't same with the SD card at your hard. Second if you wish to make your SD card bootable, you need to make it a bootable. You may try to google on how to make a bootable USB pendrive. You may use the step to make your flash drive boot in the same way as the SD card in your netbook
Nov 09, 2010 | ASUS Eee PC 1000HE Netbook
Can i expand the HDD memory of my EePc 4g?
If you have the EeePC 4G (which I suspect you have, given specs, then I'm afraid the answer is no. The SSD (which is what is used as a 'hard disk in your netbook) is hard-soldered to the main board. You can, of course, add SD cards or USB Pens to increase your storage space.
In Windows, you can also set your "My Documents" folder to work from a different location, such as the SD card. This may help you too.
Aug 13, 2009 | ASUS Eee PC 4GB Notebook
Access data on 8Gb SD card
Some older card readers will not read the newer HC-SD cards all memory cards larger that 4gb are HC-SD. You need to get a new card reader that states HC-SD compatible. Office Depot sells them as well as many online sites. Then just plug the new reader into a USB port and go.
I Hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Jul 23, 2009 | Electronics - Others
ASUS Eee 4G Notebook Logo
153 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
