Question about EliteGroup P4VMM2 Motherboard
My mobo pv4mm2 the onboard vga have problems it does not work. how can i entering bios set up for changing in video agp? actually i have a black screen.I can't enter into set up bios.
  • 105 Answers
Normally entering bios can be done in 2 ways
1.when u power on ur pc by pressing the power button, immediately start tapping f2 key continuously for some models
2.in some models we need to keep tapping f12->then go to system setup
Posted on Sep 16, 2010
Chaintech P35-121-16B9 need the manual or video jumper setting
Hi
Thank you for your query
Generally you dont need to disable the onboard VGA to AGP, all you need to do is to ensure that you plug the monitor lead into the AGP VGA card.
However if you wish to disable the onbaord VGA then please do the following
1) Ensure that the monitor lead is plugged into the onboard VGA card/port
2) Siwitch on PC then press F12, esc or del key to enter detup (When switching on there will be a message that says press X to enter setup)
3) This will present you with a blue BIOS screen, if yuo go through the menu there will be a option that says 'onboard/integrated peripherals'
4) choose that option and there will be a further option 'onboard VGA' this will be set to enabled. Set this to disabled and then save and exit
5) Note at this point you will have to move the VGA cable from the monitor from the back of the VGA prot to the AGP VGA card
I hope this has been helpful
Feb 28, 2010 | Computers & Internet
PCI Video wont work with Gigabyte GA-K8VM800M motherboard
hey try the removing cards.....
window 7 may took up it best when no such changes are around..
! Gb or 2 RAm is enough to get run your Win 7
and sound card is noot required untill you have 4 or more speakers
Feb 12, 2010 | Gigabyte GA-K8VM800M Motherboard
I bought Foxconn 755A01-6EKRS Motherboard for my HP pc replacement. i install my AGP VsionTek x1300 graphic card and turn it on and nothing show up on screen...then i put the graphic card back to my old HP...
Your new Foxconn motherboard Primary Graphics Adapter settings in set to onboard vga that is why there is no display in your monitor. Do not install yet your agp video card. Use first the onboard vga of the motherboard.
Power up your computer and go to the BIOS settings. Locate in bios about the Primary Graphics Adapter settings and then select AGP. Save changes and the exit. Turn off your computer and now install the agp video card.
Dec 16, 2009 | Foxconn 755A01-6EKRS Motherboard
Biostar u8668 grand does not power up when agp
Good Day sir, try to check the CMOS/BIOS setup, and go look for Initial Display First, there are several options, Onboard / AGP / PCI. OR, after you remove your AGP, clear the CMOS/BIOS setup. find the jumper wire near the battery this sets your motherboard to factory setup and uses the onboard VGA. test the pc without the AGP.
Oct 18, 2009 | Biostar U8668 Motherboard
My vga port will not work ?
IF the vga port is onboard on the motherboard you have the option to add a vga device to one of the 32 bit add in card slots. Once the add on vga card comes up you can see if the operating system sees the onboard card that is not seemingly working. Then post here what you see afterwards
Jul 26, 2009 | EliteGroup Goal 3 Plus/Sempron 3000+...
P4m800pro-m478 "No video"
if you have another pci slot install the card there
if that does'nt work
your card has probably gone
please rate me
thanx
Feb 02, 2009 | EliteGroup ECS P4M800-M Socket...
Videocard wont work
Hi jazzcowboy,
Your Asus P4GE-V uses an intergrated graphics card.
Onboard VGA [Auto] Page 4-22. User manual.
If the bios is set to Enabled, the onboard VGA is enabled.
When you add an AGP card your bios will not see it.
You must change the bios setting to [Auto] so the system will see your AGP video card.
To download your manual for the Asus P4GE-V Click the link.
http://support.asus.com/download/download.aspx?modelname=P4GE-V&SLanguage=en-us
Suggest you add to your favorites.
Enjoy!
Have more questions, feel free to ask.
Mike
Apr 24, 2008 | ASUS P4GE-V Motherboard
GeForce4 MX 420 Video Card
First question: Are you sure you have a PCI card?
there are several points here:
Make sure you have the monitor connected to the correct output on your computer. (In this case to the output of the graphics card, not to your onboard output)
If you have a PCI card set bios to PCI
Setting it to AGP means the computer is looking for a graphics card in you AGP-slot on you motherboard.
I cannot help thinking, that you actually have a AGP card in a AGP slot and that you computer is not working on onboard, but on AGP. But you can check which graphics device is used, in display properties (right-click Desktop, Properties, Settings)
Please post some feedback
Apr 04, 2008 | VIA P4MA Pro Motherboard
New graphics card not recognised
Peter, you need to enter your bios & make a change.
How to enter bios? Start the PC & begin pressing the Delete key every two seconds untill the display screen opens to the bios menue. Peter here at the main menue of your bios look to
Pg. 29 in your motherboard manual. If you do not have your manual download it from the link provided:
http://www.ecsusa.com/ECSWebSite/Products/ProductsDetail.aspx?detailid=62&DetailName=Manual&MenuID=1&LanID=9
In order to move about in the Bios look at the bottom of the screen. There you will see how to move about using your keyboard.
Take your time in the bios. It can be confusing, even for me!
On pg. 30 change the Video (EGA / VGA) to AGP if available.
If AGP is not listed do not change.
Go to Pg. 35&36
Advanced Chipset Features
AGP & P2P Bridg Control Change to AGP if listed.
VGA Share Memory Size Change to 0 if possible.
The onboard/intergrated AGP uses part your system memory to function.
AGP & P2P Bridge Control
Play it safe & change to the size of memory to 256Mb.
Which matches your FX5200 memory
AGP Fast Write to Enable
AGP Driving Control set to Auto
AGP Master WS Write to Enable & same for Read.
Save & exit bios. The system will re-start.
If after your system starts back up & enters into windows & you notice you do not have video switch the cable connected to the other VGA out-put on the FX5200. Your display should show up.
Install your software for your new card.
Enjoy!
If you have troubles Pete just post back here & I'll address them.
& please vote...
Feb 24, 2008 | EliteGroup L7VMM2 Motherboard
Need help
You need to enter your motherboards bios. As the system starts up press the Delete key every two seconds. Hopefully you'll have video doing this. If you do not have video display. You'll have to remove the new video card for a short while. Again enter your bios. Still have your manual? If not click the link & download it here. http://www.foxconnchannel.com/EN-US/support/downloads.aspx?ProductModel=865G7MC-ES&TypeID=en-gb0000001
Enter Advanced Chipset Features
Goto pg. 33
On-Chip VGA (Default: Enabled). Disable this.
Init Display First (Default: Onboard/AGP) Change to AGP/Onboard. The AGP is to load first before the onboard.
Save & shut down the system. Clean out the AGP slot. There can be a dust build up from not using it. Canned air works well.
Leave the side case off untill your sure the 7600 is running correctly.
Get to know your board alittle. Read the manual a wee bit.
Good Luck! Enjoy!
please vote
Feb 15, 2008 | Foxconn (865G7MC-ES) Motherboard
EliteGroup P4VMM2 Motherboard Logo
52 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
